Author Topic: AOPO mechanical keyboard  (Read 21998 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Tue, 12 November 2019, 03:42:54 »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: AOPO mechanical keyboard
« Reply #1 on: Tue, 12 November 2019, 03:43:39 »
AOPO 87
SPECS
GK brand
87 keys
Rosewood case
RGB per-switch LEDs
Type-C USB
Hotswap Kailh sockets
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #2 on: Tue, 12 November 2019, 03:44:11 »
AOPO 108
SPECS
108-key full-size layout PCB kit
Rosewood case
High profile design
Per-key SMD RGB LEDs
USB-C connection
Hot-swappable Kailh sockets
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #3 on: Tue, 19 November 2019, 08:34:56 »
How is it assembled?
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #4 on: Mon, 25 November 2019, 00:57:52 »
What do you mean?
The keyboard is hot swappable.
« Reply #5 on: Tue, 26 November 2019, 13:00:02 »
What do you mean?
Where do the plate and PCB attach?
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #6 on: Fri, 13 December 2019, 03:58:30 »
What do you mean?
Attached in the case with screws.
