Author Topic: Newbie here, a few questions about buying my first custom keyboard  (Read 2984 times)
Offline vanora
« on: Tue, 12 November 2019, 09:48:49 »
I've always owned off the shelf keyboards and I think it's time for a change.
Currently, I'm considering the KBD75v2 and the Tofu65. I'm planning on getting Tealios v2 switches.
I'm just not too confident in the whole soldering thing so I have a few questions:
* Is the Tofu65 hot-swappable? (probably a dumb question, I know but couldn't really seem to find a concrete answer)
* Any good keyboard assembly services that don't cost an insane amount? (Would be nice if they offered lubing and clipping)
* Anything I should note about my first ever "custom" keyboard?
Feel free to enlighten me on anything. I'm really interested in getting to know this stuff :D
« Last Edit: Tue, 12 November 2019, 09:59:23 by vanora »
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: Newbie here, a few questions about buying my first custom keyboard
« Reply #1 on: Tue, 12 November 2019, 11:47:08 »
The Tofu65 on KBDFans website does not mention anything about hotswapability. However, you might like the DZ60 as that is hotswappable. KBDfans has their own assembly service but i'm not sure how much it costs.
Just my thoughts
Offline vanora
« Reply #2 on: Tue, 12 November 2019, 13:21:36 »
Thank you for the relply :)
I really want those dedicated arrow keys so the DZ60 won’t really be an option for me. I saw the KBDFans assembly service but can’t seem to figure out if they offer lubing and clipping.
Offline Gampela
« Reply #3 on: Tue, 12 November 2019, 13:59:44 »
This one at least has a hotswappable PCB:
https://kbdfans.com/collections/diy-kit/products/dz68rgb-customize-keyboard-diy-kit
You can always ask them about their assembly service but there will be a bit of a language barrier. With hotswap PCB you shouldn't need any extra services and you can do the stabs yourself.
Offline Leslieann
« Reply #4 on: Tue, 12 November 2019, 14:54:09 »
Why?
Not being rude, seriously, why do you hope to accomplish?
If it's a special layout, fine. If you're wanting it for "coolness" or internet points, I'd stop and ask why that matters and lastly, what is the end result you hope for. If this is to be your daily driver you may want to consider sticking to off-the-shelf. Customs are not necessarily better, they tend to have less tested, less warranty, and once out of production can mean trouble finding replacement parts if something goes wrong. There's nothing wrong with wanting one, just keep in mind it's kind of like a show car, every scratch devalues it, a problem can mean a very costly repair, if it can be fixed. If you break a Cooler Master you can replace the whole thing relatively cheap but you also may be able to get a replacement part from them, the same cannot be said for a limited run custom.
I'm not saying customs are better or worse, just that they come with different problems.
Soldering switches in is dead simple, de-soldering is where it gets a bit more difficult (depending on skill and equipment). If you're buying a board without switches, you can do it yourself pretty easily in a few hours, there is plenty of guides and the equipment you need is pretty cheap. You don't need a Hakko to assemble a board, in a pinch I've soldered using irons I bought at a dollar store and even hacked together makeshift irons.
Of course just installing switches means buying something devoid of switches, but if you are going to contract this out anyway it doesn't matter much.
You call it an "insane amount" and yet you aren't willing to do it yourself.
Soldering can be an hour for switches in a small board or several hours if you make a tiny mistake. De-soldering is tedious, (a little) risky (to the board and switches) and can take several hours. You say it's expensive but this is (somewhat) skilled labor and desoldering often involves special tools they had to pay for. If you think that's bad, try opening 100 teeny tiny switches, brushing expensive lube onto teeny contact points, putting them back together, ensuring everything works, and then soldering them into place.  Most of it isn't difficult work, especially if they've done it a lot but it's still specialized and more importantly, tedious work. After all that they still then have to repackage it and ship it back to you, multiply that by your hourly rate.  Are they still asking too much?
The cost of a person to do what you want is their time and labor, it is not tied to your end result, learn to separate the two.
(Everyone is guilt of this at times, I'm not trying to bash you for it)
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
