Author Topic: Best Springs For Spring Swap?  (Read 25396 times)
Offline filcomanfilthy
« on: Fri, 15 November 2019, 10:30:02 »
I am going to be using either gat ink blacks or c3 tangerines and am wondering what spring would be best to swap out for a low 70gf bottom out weight.
Filthy
Offline Leslieann
Re: Best Springs For Spring Swap?
« Reply #1 on: Sat, 16 November 2019, 04:50:08 »
Springs are subjective, there is no "better" spring, only the one who's rate/curve you like best.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #2 on: Sat, 16 November 2019, 09:52:16 »
I really like TX's springs & spring lube. They're high quality, consistent, & a great value with or without the lube & lube deck packaging. If you want them right now though you'll have to order from the intl. proxy since the US one only has 55g springs without the lube + deck in stock right now. https://txkeyboards.com/en/shop/us-store/tx-spring-intl-70g-cherry-detail
Offline treeleaf64
    • treeleaf64
« Reply #3 on: Sun, 17 November 2019, 08:43:19 »
For most people, Gateron yellow springs, 62g, 63.5, and 67g seem to be good
Everyone must pay the cat tax
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #4 on: Sun, 17 November 2019, 20:12:58 »
My Zealios switches are 65G and they are NEAR PERFECT to fidget with.
Just my thoughts
Offline Sintpinty
    • My Roblox Profile
« Reply #5 on: Sun, 17 November 2019, 20:13:45 »
I think, but 65G is good enough for me. Not too heavy and not too light.
Just my thoughts
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #6 on: Sun, 17 November 2019, 21:14:19 »
I have not used Ink switches so I can't compare,
but I'm using 65g SPRiT springs and so far I don't want to change springs anymore :p
Offline treeleaf64
    • treeleaf64
« Reply #7 on: Tue, 19 November 2019, 21:07:57 »
And, it seems people like 65g springs as well. I'm thinking of getting 65g springs for my vintage MX black switches.
