Author Topic: Spray painting keyboards  (Read 4860 times)
Offline rac
« on: Mon, 18 November 2019, 12:58:30 »
Has anyone tried to spray paint their keyboard? How did it turn out? Any pointers?
I really want a 60% WKL in Rose Gold but it is hard to find, so I am considering buying a black one off KBDFans and (carefully) spray painting it.
Offline Sup
Re: Spray painting keyboards
« Reply #1 on: Mon, 18 November 2019, 13:56:41 »
So long you are spray painting plastic it would turn out good but i doubt it would look good if you spray paint a aluminum case and be durable.
If you where planning to spray paint a aluminum case cerkakote it instead of spray paint.
current
Coming soon
« Reply #2 on: Mon, 18 November 2019, 14:28:43 »
I have painted a few, both plastic and aluminium. Spray paint wears off on edges and corners. That applies to all materials but especially aluminium. Aluminium primer adheres well only to freshly sanded bare aluminium - it does not bite on anodised aluminium.
Metallic spray paint often lacks luster, and is almost never comparable to the real thing.
« Last Edit: Mon, 18 November 2019, 14:30:29 by Findecanor »
Offline rac
« Reply #3 on: Mon, 18 November 2019, 14:55:48 »
I was planning on painting an aluminum keyboard. I'll look into cerakoting, thanks!
Offline ju6ju8Oo
« Reply #4 on: Tue, 26 November 2019, 07:06:50 »
I spray painted on resin (dactyl manuform). The lower part paint that I sometimes touched wear off. The other parts are still good.
Offline 4sStylZ
« Reply #5 on: Tue, 26 November 2019, 08:33:19 »
I never get a good result wich spray paint on my 3d printed wrist-rest / case, even with primer coat and varnish. Every time, with weeks of use I destroy the varnish and after that I destroy the paint.
So… good luck !
Bépo user here : AEK64 White linear dampened, XD75 Cherry Blue Jailhoused, TypeMatrix2030 black skin, Lenovo 0B47200 w/ trackpoint, G13, G512. Kensington Expert Trackball & Orbit, Magic touchpad 2.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #6 on: Tue, 26 November 2019, 09:02:18 »
I don't think its a good idea as it ruins the style and texture. If you mess up you could put it on the keycaps or even the PCB
Just my thoughts
