Author Topic: [GB]E8.5 - 80% custom keyboard(Start shipping Group 8 )  (Read 280633 times)
Offline excluisve
  • Making & Thinking.
« on: Fri, 22 November 2019, 10:00:13 »
Group Buy for E8.5 - 80% custom keyboard.
IC link :https://geekhack.org/index.php?topic=102901.0
Hello everyone Excluisve here
In the past three years, I have had a lot of sadness and tears. I am very glad that have been here for three years. also very grateful to my friends who have supported me for three years and hope that my keyboard can get your love. This time brings a new TKL design it is a completely different design.
make sure you want get FE(full brass edition) Form :http://bit.ly/2saZEP3
                                                      Fe orders check :http://bit.ly/33ep76S
                                               PC(ploycarbon) form: http://bit.ly/2rhB0vu
                                         PC form check :http://bit.ly/2XKo8Kk
                                   Change request form:https://forms.gle/gJbb1Z6kGNdPuyDn6
        Alu case :http://bit.ly/34infLD
                                 Alu case orders check :https://bit.ly/2KThX1y
                                                Change request form:https://forms.gle/nGAH37zEqRQN3j3E7
                                                              request form close on 15th
Features:
*Polycarbonate / Aluminium / Pvd accent are available
*7 degrees slope,the leds above arrow cluster was rgb
*Inner middle for gasket mount (base kit was top mount)https://i.imgur.com/cV5BfbO.jpg
*Solder pcb layout:already add split backspacehttps://i.imgur.com/Pj6VjJn.png Hotsawp layout:already add step capshttps://i.imgur.com/ZBmKbUd.png
*QMK with  USB C
Color for each parts :
Alu Case :Purple/grey/green  E-white /E-black/E-pink
Plate:    green /E-white /E-black/E-pink/E-yellow/sand brass (e-clear)/Ti/pc
Top accent: green /E-white /E-black/E-pink/E-yellow/sand brass (e-clear)/pvd silver/pc/light blue
Side weight:  green /E-white /E-black/E-pink/E-yellow/sand brass (e-clear)
Estimated price :                     Start at $365
Third Anniversary Version FE    10 kit Raffle ($888)
Upgrading
TI plate + 55
brass plate (sand) +$35
Brass side weight (sand)+$40
Brass accent (sand )+$15
Brass accent (pvd silver)$25
Get alu inner middle (black or white )+45  for gasket mount
Extra
Pcb : $48
Alu /pc plate $38
Brass plate (sand) $55
Alu accent :$15
Brass accent(sand):$20
Brass accent(pvd silver):$30
Brass accent(pvd black):30 only FE
Brass accent to e white $25 only FE
Brass accent to e black $25 only FE
alu side weight : $38
Brass side weight(sand) :$58
Brass side weight to e white $60 only FE
Brass side weight to e black $60 only FE
Brass side weight(pvd silver)$70 only FE
Brass side weight(pvd black)$70 only FE
No extra inner middle ,no extra ti plate
Extra accents max 3
More pictures :
                       - E white        :https://imgur.com/a/iHrFC6W
                       - More color  :https://imgur.com/a/Q17GLxg
                       - Accents      : https://imgur.com/a/F7tYgHf
                       - Rendering   : https://imgur.com/a/Aw5B8qy
Schedule:
Groupbuy launch time :
                                   FE Raffle   22th, 11:00am EST
                                   PC FCFS    23th, 11:00am EST
                                   Alu            24th, 11:00am run two weeks
                                   I am use this time zone https://www.timeanddate.com/time/zones/est
                             ETA : Early of June 2020          .
FE Edition - Raffle
+ A Google Forms link will be provided via GH and Discord prior to opening
+ Form will open and start collecting responses at 11:00 am EST on 11/22 (form will contain all options for the order)
+ Responses will be collected for 22 hours until 9:00am EST on 11/23
+ (10) Winners will be drawn and announced by 10:00am EST on 11/23
+ Forms can be edited for 3 days through 11/25
+ Invoices will be generated and sent out via PayPal on 11/26
+ Payments will be due by 11/27
+ If payments are not received in time, another winner will be redrawn from the pool
PC Edition - First Come, First Serve
+  Prior to opening, a Google form link will be shared via GH and Discord
+ Form will be a single field and submit = your GH or discord name
+ Form will activate at 11:00am EST on 11/23
+ The first 60 people who submit the form will be collected
+ Those people will then be given a longer Google form to complete all choices for their order
+ Those choices can be edited for three days until 11/26
+ PayPal invoices will be generated for the first 50 people in the list between 11/27 - 11/28
+ Payment for invoices will be due by 11/30
+ Any user who does not pay their invoice by 11/30 will be passed up and invoices will be generated for the next person in line (#51, 52, 53, etc)
Aluminum Edition - Unlimited
+ Form will contain all options for the order
+ Form will open and start collecting responses at 11:00 am EST on 11/24
+ GB will be open for 2 weeks through 12/6
+ Submitted responses will be available for editing options for 5 days and close on 12/11
+ PayPay invoices will be generated and sent out between 12/13 - 12/16
+ Payment for invoices will be due by 12/19
Note: Some timelines may be adjusted as needed to improve experience (Like invoice people who are ready before the prescribed invoicing period)
FAQs
+ For the founder's edition, there are e-white and e-black options to choose from
+ For the PC version, you can also choose a PC top accent piece
+ Can I mix and match colors? For the Aluminum version, you can choose different colored top and bottom half of the case if you'd like.
+ Can I match a PC top/bottom with an Aluminum one? - Not in one order. You must buy either a full PC case or a full Aluminum case.
+ The inner middle to support gasket mount is an optional piece and is an upcharge (pricing soon). It comes in Aluminum e-white or e-black only
+ Sandblasted brass parts have a clear e-coating for protection applied to them
+ What is e-coating? https://clearclad.com/products/what-is-e-coat/
+ What does a gasket do? Provides more flex & bounce to typing experience than mounting the plate to the top or bottom of a case.
+ How much is shipping and when is it charged? Shipping is calculated (and invoiced) once the manufacturing process is completed and the end product is ready to be sent out. Price varies by country being delivered to
+ How many units will be made? Founder's Edition - 10 (raffle). Polycarbonate - 50 (FCFS). Aluminum - Unlimited
+ Can i buy two spots ? there was no limited on alu case you can buy much you want ,but for PC case one per person
statement:
Each boards cant be 100% but i will try my ability do it perfectly .
if you cant accept a little Inevitable ,especially PVD stuff (Quality is hard to control )please thinks twice before purchanse
For some orders i will consider to sale .thanks evryone : )
Free to leave suggestion and question.---
Thanks all!
Fellow me on Ins  https://www.instagram.com/exclusive1993/
« Last Edit: Sat, 10 October 2020, 20:15:59 by excluisve »
Offline excluisve
Re: E8.5 - 80% custom keyboard
« Reply #1 on: Fri, 22 November 2019, 11:17:14 »
Reserved  :thumb:
Offline Visionaire
« Reply #2 on: Fri, 22 November 2019, 11:18:13 »
Hurray! GB time has arrived!
If you want to try for the all-brass founder's edition, here's the link for the raffle. OPEN NOW. 10 winners chosen tomorrow.
« Last Edit: Fri, 22 November 2019, 11:21:57 by Visionaire »
Offline 9force
Re: [GB]E8.5 - 80% custom keyboard
« Reply #3 on: Fri, 22 November 2019, 11:19:30 »
HYPE !!
good luck everyone.
祝大家好运!
Offline Steezus
  • Keeper of Facts
« Reply #4 on: Fri, 22 November 2019, 11:21:57 »
Excited for this GB! Best of luck to all entering the raffle.
Offline SolidCactus
« Reply #5 on: Fri, 22 November 2019, 11:22:30 »
Just entered! Best of luck all!
Offline Boy_314
« Reply #6 on: Fri, 22 November 2019, 11:24:40 »
« Last Edit: Mon, 04 August 2025, 02:24:18 by Boy_314 »
Offline nhto
« Reply #7 on: Fri, 22 November 2019, 12:02:15 »
Good luck everyone!
Offline Popopro
« Reply #8 on: Fri, 22 November 2019, 12:07:58 »
its finally here! so excited!  :D
Offline PotatoTM
« Reply #9 on: Fri, 22 November 2019, 12:15:09 »
Going to get in on the alu board, GLWGB!
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10 on: Fri, 22 November 2019, 13:11:41 »
Are there any photos of green anodized samples?
Offline NoxNoxNox
« Reply #11 on: Fri, 22 November 2019, 13:18:09 »
Soon(TM) is now.
Offline iaman
« Reply #12 on: Fri, 22 November 2019, 13:33:15 »
The “more colors” link has a grey-anodized board with a green-anodized accent piece but that’s it.
Offline Nigolski
« Reply #13 on: Fri, 22 November 2019, 13:38:57 »
i'm interested
Offline hiko13
« Reply #14 on: Fri, 22 November 2019, 13:40:43 »
I need that purple in my life.
Offline Visionaire
« Reply #15 on: Fri, 22 November 2019, 13:53:49 »
Green shown here as an accent in the top right corner
Should be similar to this color, I believe (from E6.5 buy)
« Last Edit: Fri, 22 November 2019, 13:56:29 by Visionaire »
Offline liquidvel
« Reply #16 on: Fri, 22 November 2019, 14:08:19 »
Can anyone explain the google form to me? Where can I choose the colors (purple, red, etc.)?
Will the polycarb version me more expensive?
Offline Visionaire
« Reply #17 on: Fri, 22 November 2019, 14:14:28 »
The google form that is out there right now is only for the founder's edition. Its an all brass version of the keyboard.
There will be a FCFS form tomorrow for 50 pcs of Polycarbonate case. That link will be shared prior to an 11:00am EST opening.
On Sunday, there will be a form that is for Aluminum cases. That will be open for 2 weeks and will have a 3rd link.
So stay tuned if interested in PC or Aluminium cases. They happen on the 23rd and 24th.
Offline DetectiveNio
« Reply #18 on: Fri, 22 November 2019, 14:20:48 »
Is there an option for blank back accent? or all of them will have the main man's name on it?
Offline hiko13
« Reply #19 on: Fri, 22 November 2019, 14:30:19 »
This will be my first GB and custom so bear with me but...all I'll need to finish this are switches and keycaps, right, and with the hotswap option there's no need for soldering?
Offline iaman
« Reply #20 on: Fri, 22 November 2019, 14:35:05 »
Stabilizers, too.
Offline 8six753o9
« Reply #21 on: Fri, 22 November 2019, 14:35:40 »
In case people are confused...
ONLY FE (all brass case) order form is open now (Nov 22) and winners will be chosen tomorrow (Nov 23)!
PC case form opens Nov 23 11am EST- countdown.
Aluminum case form opens Nov 24 11am EST - countdown - Gray, Purple, Green, e-White, e-Black, e-Yellow, e-Pink.
Offline hb_swift
« Reply #22 on: Fri, 22 November 2019, 14:38:49 »
That's correct!
Offline consumer
« Reply #23 on: Fri, 22 November 2019, 14:44:18 »
Will you be making different color accents available aftermarket?
Offline hiko13
« Reply #24 on: Fri, 22 November 2019, 15:09:19 »
Stabilizers, too.
Plate mounted, I presume?
Offline A57RO
« Reply #25 on: Fri, 22 November 2019, 15:44:38 »
Is there any renders for the FE boards at all in brass etc? Not comfortable dropping $$ on something I can’t see prior to buying (if I was to win a spot)
Offline iaman
« Reply #26 on: Fri, 22 November 2019, 15:50:55 »
Stabilizers, too.
I think either plate-mounted or PCB-mounted should be fine, but I don't think E has shared any shots of the PCBs to confirm. Visionaire might know?
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #27 on: Fri, 22 November 2019, 15:57:58 »
Stabilizers, too.
You'll need PCB mount stabilizers for this.
Offline Solotov
« Reply #28 on: Fri, 22 November 2019, 16:11:20 »
Excited for this board!
Flex is love, flex is life.
Offline flippanteer
« Reply #29 on: Fri, 22 November 2019, 16:37:01 »
Yes! Alu side weight extra option! Awesome.
Current boards: FLX Virgo w/ NK Drys, E8.5 w/ NK Drys, LZ Physix w/ H1s,  Moon TKL w/ MX Zilents, HAD66 [Alice layout] w/ NK Creams, KBD75v1 w/ Zealios 67g v1
Purchased boards: Infinitum
Past boards: Trinity w/ Tealios v2, Lubrigante w/ Holy YOK Trash Pandas, Kumo w/ Novelkeys Cream, Diverge 2 w/ MX Browns, Planck w/ MOD-H, Anne Pro w/ MX Blue
« Reply #30 on: Fri, 22 November 2019, 20:24:11 »
very excited for this and odds are good that i order one
Offline excluisve
« Reply #31 on: Fri, 22 November 2019, 20:50:31 »
The FE  form will close at 10:00pm EST,since we have already hit much ppl
thanks all .
Offline Rob27shred
« Reply #32 on: Fri, 22 November 2019, 20:53:42 »
Same here, I'd love to get a polycarb one. Although the limited run on them probably means I'll end up with an alum. one if I can pull the cash together soon enough. That might be for the best anyways, I went alum. on the E6.5 & couldn't be happier with the board!
« Reply #33 on: Fri, 22 November 2019, 21:08:16 »
alu is best anyway
black/yellow or bust
Offline outerspace
« Reply #34 on: Fri, 22 November 2019, 21:18:59 »
Do we have a picture of e-white with e-yellow accent & side weight? Can’t decide between that and e-white/green accents & side weight.
Also, I assume this will be shipped from China? Would it be reasonable to budget ~$50 in shipping?
« Reply #35 on: Fri, 22 November 2019, 22:36:47 »
to US?
probably more given the issues between US and china right now
i'd say 65-75
Offline Aznguyen316
« Reply #36 on: Sat, 23 November 2019, 05:02:59 »
Think6.5 from China via DHL which was literally 2 day shipping was $42. It was initially supposed to be SF or something that's cheaper, but DHL due to concerns with SF shipping.  DHL is super fast and more expensive.  So I would hope no more than $50 for a TKL.
Offline zekth
« Reply #37 on: Sat, 23 November 2019, 07:39:15 »
There is still red in renders but seems like there is no more in the description of the GB. Is red color for alu abandonned?
Offline excluisve
« Reply #38 on: Sat, 23 November 2019, 07:52:59 »
FE(full brass edition) winner :
MetallicCharles
andrewregal
Olivia
SolidCactus
foo#4542
smittysteve
Phatty
icyincake
mgsickler
japanesehorrorwriter
Thanks all to fill this form ,hope you can in next time
Offline 8six753o9
« Reply #39 on: Sat, 23 November 2019, 08:08:02 »
Correct. Red is no longer an option, just gray, green, purple, eblack, ewhite, and epink for aluminum cases.
Offline hiko13
« Reply #40 on: Sat, 23 November 2019, 09:09:06 »
Thank you!
Offline excluisve
Re: [GB]E8.5 - 80% custom keyboard( 11:00 am EST,PC case FCFS)
« Reply #41 on: Sat, 23 November 2019, 09:21:59 »
For the PC form: Please be sure you are SIGNED INTO Google. It will require this so that the form will limit to one response per person. This does NOT have to be the same email as your PayPal.
PC form: http://bit.ly/2rhB0vu
I will click the buttom on 11:00 am EST
time check
https://www.timeanddate.com/countdown/taxday?iso=20191123T11&p0=263&msg=Time+until+Exclusive+E8.5+PC+Edition+form+open&font=hand&csz=1
Offline Rob27shred
« Reply #42 on: Sat, 23 November 2019, 09:38:27 »
Offline Solotov
« Reply #44 on: Sat, 23 November 2019, 10:00:55 »
The form even went down for a few seconds... Hope I still made it  :'(
Offline Steezus
  • Keeper of Facts
« Reply #45 on: Sat, 23 November 2019, 10:02:06 »
Yeah, the form went down for me too, once I was finally able to get in the orders were filled. Congrats to the winners.
Offline donut_sauce
« Reply #46 on: Sat, 23 November 2019, 10:02:09 »
that was fun
Offline mononokay
« Reply #47 on: Sat, 23 November 2019, 10:03:02 »
Same. Oh well
Offline wholypantalones
  • text and icon mods plz.
« Reply #48 on: Sat, 23 November 2019, 10:05:54 »
what's the cutoff time?
Offline DonkeyD
« Reply #49 on: Sat, 23 November 2019, 10:06:43 »
so if i didnt get an email, I didn't get in?
