Author Topic: [GB]E8.5 - 80% custom keyboard(Start shipping Group 8 )  (Read 280657 times)
Offline wholypantalones
  • text and icon mods plz.
Re: [GB]E8.5 - 80% custom keyboard( 11:00 am EST,PC case FCFS)
« Reply #50 on: Sat, 23 November 2019, 10:08:05 »
so if i didnt get an email, I didn't get in?
did you check "send me copy"?
Offline DetectiveNio
« Reply #51 on: Sat, 23 November 2019, 10:08:33 »
Let's wait for Exclusive to release the list *pray*
Offline excluisve
  • Making & Thinking.
« Reply #52 on: Sat, 23 November 2019, 10:11:51 »
I will send email to first 50 orders,plz wait while
Offline DonkeyD
« Reply #53 on: Sat, 23 November 2019, 10:16:31 »
no i panicked lol
Offline enfer
« Reply #54 on: Sat, 23 November 2019, 10:25:49 »
Oh my god
Offline marme358
« Reply #55 on: Sat, 23 November 2019, 10:38:05 »
I guess it's wait and see now.
Offline Nothatso
« Reply #56 on: Sat, 23 November 2019, 10:41:00 »
The list of people who got in to the PC GB was posted in discord. Exclusive said emails will go out Soon™.
« Reply #57 on: Sat, 23 November 2019, 10:52:13 »
you got that discord link?
Offline excluisve
« Reply #58 on: Sat, 23 November 2019, 10:54:02 »
PC order list :
form already send out ,check list if you not get plz check the 'spam'
email pending wait it patiently
Appreciate that who filled the form ,thanks every one !
Offline Visionaire
« Reply #59 on: Sat, 23 November 2019, 11:04:15 »
Edited.
Offline Raravin
« Reply #60 on: Sat, 23 November 2019, 11:12:30 »
So wait I am confused the actual GB doesnt start till tomorrow right?
« Reply #61 on: Sat, 23 November 2019, 11:27:54 »
this was for the 50 spot polycarbonate fcfs.
Offline Visionaire
« Reply #62 on: Sat, 23 November 2019, 11:31:45 »
Aluminum buy will be open tomorrow and run for 2 weeks. :)
Offline excluisve
« Reply #64 on: Sat, 23 November 2019, 19:19:30 »
Plz filled the PC form in time ,if not received the mail check the spam or pm me double check
Offline excluisve
Re: [GB]E8.5 - 80% custom keyboard( 24th 11:00 am EST,Alu cae)
« Reply #65 on: Sun, 24 November 2019, 02:16:35 »
One mistake ,on the pc form we find extra sandblasted brass plate was 38+35 but correct was 38+17 already fixed
extra brass plate was $55
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #66 on: Sun, 24 November 2019, 08:28:54 »
What kind of colour / finish will the titanium plate have?
Offline excluisve
« Reply #67 on: Sun, 24 November 2019, 09:52:39 »
Sandblasted
Offline excluisve
Re: [GB]E8.5 - 80% custom keyboard(24th 11:00 am EST,Alu)
« Reply #68 on: Sun, 24 November 2019, 09:57:07 »
Alu case :http://bit.ly/34infLD
you can edit after you submit,if you have submit twice plz not at last let me know which one was correct
Offline anduin
« Reply #69 on: Sun, 24 November 2019, 10:32:27 »
祝海外大卖!哈哈
Offline Lockkkk
« Reply #70 on: Sun, 24 November 2019, 10:42:28 »
Black/white and pvd accent  :p
Offline alanskiii
« Reply #71 on: Sun, 24 November 2019, 11:02:38 »
SOON™ HYPE
Offline coffeeshopcoder
« Reply #72 on: Sun, 24 November 2019, 12:37:04 »
did I miss the ALU GB form link ? Or its not posted yet ?
(Sorry I did not read through every comment - just skimmed through it...)
Offline d00deitsnik
  • Grails: SA Olivia, 1800 w/ only Latriualum keycaps
« Reply #73 on: Sun, 24 November 2019, 12:59:11 »
Here you go.  (:
Offline redeyez88
« Reply #74 on: Sun, 24 November 2019, 14:41:07 »
So, if we want to get multiple (gift), should I just fill out another form? Or would that just remove my initial submission?
Offline excluisve
« Reply #75 on: Sun, 24 November 2019, 17:13:28 »
You need mark at last blanket ,let me know is you second purchase not repetitive
Offline redeyez88
« Reply #76 on: Sun, 24 November 2019, 20:15:47 »
Thank you!
Offline EternaL7
« Reply #77 on: Sun, 24 November 2019, 21:15:48 »
Before I join the GB can someone tell me if 6.25 spacebar is compatible with the hot swap Pcb?
Offline SmithersDotTV
« Reply #78 on: Sun, 24 November 2019, 21:43:30 »
So I filled out the form for the alu case, will there be a confirmation email when the GB closes?
Offline jooobe
« Reply #79 on: Sun, 24 November 2019, 21:54:13 »
Got my green with pc plate and black accents and weight
Sent from my SM-N960F using Tapatalk
Offline bball2
« Reply #80 on: Sun, 24 November 2019, 22:31:18 »
Should be a 6.25 spacebar if you with the WK layout.
Offline Visionaire
« Reply #81 on: Sun, 24 November 2019, 22:34:19 »
We'll do an order check before sending out invoices to allow folks to confirm their choices.
Offline excluisve
« Reply #82 on: Sun, 24 November 2019, 22:47:03 »
PC form check :http://bit.ly/2XKo8Kk
Change request form:https://forms.gle/gJbb1Z6kGNdPuyDn6
(PC)EOD 11/26
Invoices on 11/27
Alu case
Change request form:https://forms.gle/nGAH37zEqRQN3j3E7
ID :tintaps and arrowarrow1 still not filled the PC form plz do it in time
« Last Edit: Sun, 24 November 2019, 23:01:27 by excluisve »
Offline Hamel
  • KBDLAB
« Reply #83 on: Mon, 25 November 2019, 07:07:11 »
Just filled in a form for Alu. Looking forward to it!
(typed on E7-V1  :thumb: )
Offline zian_
« Reply #84 on: Mon, 25 November 2019, 07:18:12 »
In for alu!
Offline grundlemere
« Reply #85 on: Mon, 25 November 2019, 08:42:45 »
Will there be a form check for Alu?
Offline Visionaire
« Reply #86 on: Mon, 25 November 2019, 08:58:56 »
Yep, soon!
Offline Wolfman_21
« Reply #87 on: Mon, 25 November 2019, 09:05:01 »
Finally made an account just to join this group buy!
When the Alu order list be up?
Offline jooobe
« Reply #88 on: Mon, 25 November 2019, 09:06:15 »
End of gb
Offline grundlemere
« Reply #89 on: Mon, 25 November 2019, 09:06:52 »
Offline Arithmetics
Re: [GB]E8.5 - 80% custom keyboard(Groupbuy open for two weeks )
« Reply #90 on: Mon, 25 November 2019, 12:20:02 »
Is there a way to get the shiny silver accent color for the back weight / triangle thing?
Offline mrkantz
« Reply #91 on: Mon, 25 November 2019, 12:28:45 »
Nope, E mentioned he didn't want to do PVD silver on the weight since the failure rate of PVD is too high
Offline Arithmetics
« Reply #92 on: Mon, 25 November 2019, 15:43:01 »
oof thanks.
Offline excluisve
« Reply #93 on: Mon, 25 November 2019, 19:30:41 »
Check PC form ,invoice will be send tmr
Offline Stich
« Reply #94 on: Tue, 26 November 2019, 00:15:32 »
Hi, I'm new to custom mechanical keyboards looking for some help. May I ask if the add on inner middle is the same thing as a gasket? The gasket is supposed to make typing feel bouncier right? Is it worth getting?
Offline ywcsam
« Reply #95 on: Tue, 26 November 2019, 00:34:26 »
The inner trim is for the gasket to sit on. If you want gasket mount, you need to get that trim. It does give more room for the plate to move, but at the end it's all preference. I would say get it so you can try both and see which one you like.
Offline lanyusea
« Reply #96 on: Tue, 26 November 2019, 01:07:32 »
OP must hired a Project Manager this time
HHKB Type-s / 4x KMAC Happy / 3x Duck Viper v1 / 2x Duck Viper v2 / 4x Duck Viper Duck TCV3 / Red Scarf 77 / 2x Infinity 60 / 2x ALF HHKB / LZ-CE / FJELL / Canoe / Canoe PC / Canoe FE / ARES Prototype / 2x Ares / LC-CLSh / TX60 / YODA2 / E6-V2 / E6-V2 FE / CAMP LC60 / 2x EM 7 / 4x Leaf 60 / UHK / Project F / Polaris / 4x Duck Viper v3 / TX60 v2 / Thermal / Matrix Falcon / TX60 v3 / 2x TMO50 / 2x Dolice / Dolphin 65 / Dolphin 60 / Plenty of keycaps
Offline excluisve
« Reply #97 on: Tue, 26 November 2019, 04:09:20 »
If you need change PC or Alu order
plz filled change request form ,also you can check you submit go through or not and check dealing with the situation
(PC)EOD 11/26
Invoices on 11/27
Alu case form check:https://bit.ly/2KThX1y
« Last Edit: Tue, 26 November 2019, 08:09:35 by excluisve »
Offline Stich
« Reply #98 on: Tue, 26 November 2019, 05:46:42 »
Thank you for the reply! I think I'll get it to try it, thanks!
« Reply #99 on: Tue, 26 November 2019, 07:41:14 »
Change request form:http://bit.ly/2XKo8Kk
(PC)EOD 11/26
Invoices on 11/27
The change request form goes to the form check document.
