Author Topic: [IC] KBM - Pbeater - AceCables Collab Announcement  (Read 41614 times)
Offline Raravin
« on: Sat, 11 March 2023, 13:10:43 »
This set has been reworked from its original IC and has been stale for 6+ months that a new one is being made! Inspiration is taken from SAO Kirito and is my second SAO set after EPBT Sniper (hopefully shipping soon)
(Please select images to see legends, the set is meant to be a dark on dark color)
Deskmats
Renders
  Elucidator - Project W
  Austin - Drift Mechanics
  Amano - H40.io
Pricing
Collabs
Use the IC form or Discord to recommend me any! Happy to work with almost anybody!
TBA
Links
Thanks
https://www.instagram.com/notgustiarp/ - For my awesome Sara Drawing! Stellaidoscope - For the novelties
iinko - For the renders KBM - Otaben & jack for all the work and back and fourth on this project!
Scott L and Maxim Potkin for the Starburst Mat Shidanesayo - For the Sara mat
[/size]
Banner
Code: [Select]
[url=https://geekhack.org/index.php?topic=119778.0][img height=120]https://i.imgur.com/QndJnQd.jpg[/img][/url]
« Last Edit: Mon, 27 March 2023, 08:30:15 by Raravin »
Offline Raravin
Re: [IC] KBM - Pbeater - IC Start
« Reply #1 on: Sat, 11 March 2023, 13:12:14 »
Things to fix
  • Spacebar kit - add more same color units
  • Novelties - Fix render for alternating swords (2x of each sword for enter and shift)
3/27 Update
3/25 Update
  • Fixed spacebar Kit
  • Fixed novelties render
3/15 Update
  • Added SEA Vendor - Pantheon keys
  • Added Global Vendor - Otakeebs
« Last Edit: Mon, 27 March 2023, 08:30:58 by Raravin »
Offline AnonyMoose_
« Reply #2 on: Sat, 11 March 2023, 13:27:54 »
colors look pretty cool but what is going on with spacebar kitting overall? Only one of each colored 3u spacebars? 3 6.25u black spacebars total? seems like some weird overlaps and some other things not accounted for.
Offline Raravin
« Reply #3 on: Sat, 11 March 2023, 13:31:20 »
Wow I didnt even realized I overlooked that I was just looking at sizing, will get updated renders and the kitting for both! There is only 2 6.25u will make sure the things are updated properly.
Offline TyPo.mk
« Reply #4 on: Sat, 11 March 2023, 14:08:00 »
Pb eater
Offline Neely_12
« Reply #5 on: Sat, 11 March 2023, 15:03:25 »
Pretty cool set. Will there be any samples before GB? Also why are there two of each color enter and shift novs of the same design? Also since this set is mono, please consider accents caps lock like pictured below
Offline Raravin
« Reply #6 on: Sat, 11 March 2023, 15:06:21 »
That is a render mistake, original layout has one of each design, will fix it when I get the space bar done.
In terms of samples - I have rough samples I can show that the process is is doable they are slightly scuffed due to my own rough handling at this point. I will be getting full base kit samples before GB date.
Offline Cylent
  • Formerly cylentshadows
« Reply #7 on: Sat, 11 March 2023, 17:05:54 »
Strange to have such a large novelties kit with no accent esc options.
Offline DuellM
  • Keyboard Fatty
« Reply #8 on: Sun, 12 March 2023, 09:48:26 »
Hopefully there will be a Hibi Novelty of a that blue rose. That would be sweet  ^-^
Offline Raravin
« Reply #9 on: Sun, 12 March 2023, 13:13:01 »
Honestly everything I tried with it for the novelty I just didnt like it D:
 :-X
Offline niakulah
« Reply #10 on: Mon, 13 March 2023, 07:29:33 »
IC Starto!
Offline Raravin
« Reply #11 on: Wed, 15 March 2023, 08:37:00 »
3/15 Update
Offline Akele
« Reply #12 on: Wed, 15 March 2023, 13:47:25 »
How does the quality of KBM caps compare to other manufacturers like PBTFans, SP and PBTFans? I'm liking the design of this set, but don't know anything about KBM.
Offline AmethystDCVR
« Reply #13 on: Thu, 16 March 2023, 22:51:10 »
is this the first time in human history where you can buy just alt alpha + alt mod and actually be able to create an entire kit up to tkl without being still dependent on like 4 keys from the full priced base set
jokes aside, this is an awesome looking set. GL and hope to see it in GB soon  :thumb:
Offline elongatedmusk
« Reply #14 on: Fri, 17 March 2023, 02:19:29 »
Into BoB/Darkgrey on Black colored keysets lately, please consider 6u spacebar!
GLWIC :thumb:
Offline Raravin
« Reply #15 on: Fri, 17 March 2023, 11:52:08 »
I have KBM love dective 40s kit on my main keyboard and I have overall liked the quality. I havent used PBTFans to much to compare. We are working on getting IRL base kit samples to try to provide to some people to review.
Thank you! Will be releasing GB information soon, and after GMK Demon Sword it has been my goal to either A make the base kit have enough keys or something where people can by the alt kit and only 1 other kit (base or alt mod) to make a full keeb.
GLWIC :thumb:
Thank you! and the 6u spacebar should be in the spacebar kit!
Offline luiG0929
« Reply #16 on: Sun, 19 March 2023, 14:30:35 »
Can't wait for this one, a really good fit for the vertex angle r2 fog
[Glacier80][Angle from VERTEX]
Offline Raravin
« Reply #17 on: Sat, 25 March 2023, 13:23:32 »
3/25 Update
« Last Edit: Sat, 25 March 2023, 20:55:06 by Raravin »
Offline Raravin
Re: [IC] KBM - Pbeater - AceCables Collab Announcement
« Reply #18 on: Mon, 27 March 2023, 08:30:30 »
Collab Announcement
Offline Evasive
« Reply #19 on: Sat, 15 April 2023, 08:49:10 »
love the novelty designs, glwic!
