Author Topic: [IC] GMK Mudbeam  (Read 48287 times)
Offline pleasega
Re: [IC] GMK Mudbeam
« Reply #50 on: Tue, 12 May 2020, 04:31:07 »
like the colorway, dirty! is there vendor for asia as well?
Offline ilikerustoo
« Reply #51 on: Tue, 26 May 2020, 22:19:17 »
I want
Offline pupper125
« Reply #52 on: Sun, 07 June 2020, 02:56:16 »
Love the colours, super clean and really portrays the theme!
Offline konstantin
  • Formerly constexpr
« Reply #53 on: Sun, 07 June 2020, 09:34:13 »
Base
I see some potential improvements that can be made to this base kit:
  • R1 End and PgDn should be moved to the numpad kit as they are only useful on boards that have a numpad (1800, CP, 96-key).
  • R1 1u mod colored \| isn't really useful and should be removed.
  • R1 1u Backspace can be removed as it's a seldom used key, and you already have a R1 1u Delete that can cover for it.
  • The two R4 1u Code keys should be 1u Ctrl and Alt instead.
  • R3 PgUp and R4 PgDn should be added to help cover some popular 65%/75% right column options.
  • The off-centered stem 6u spacebar can be safely removed, or moved to the spacebars kit.
All of this still applies. In addition, I would recommend having at least basic 4-key ISO support in the base kit (ISO Enter, 1.25u Shift, R3 \|, R4 <>). Finally, I recommend dropping the mod-colored 6u spacebars and all of the 1.75u space keys from the spacebar kit, as they are not very common (1.75u is only used on a couple of rare 40% keyboards, nowhere else).
Offline scud80
« Reply #54 on: Sun, 07 June 2020, 22:21:30 »
Thx, I'll be sure to keep those suggestions in mind when revisiting what to include in the kits.  Currently planning to do that in August.
Offline NathanielGoodtimes
    • n/a
« Reply #55 on: Fri, 12 June 2020, 20:03:46 »
Looks amazing!
Offline lowfidelic
« Reply #56 on: Tue, 16 June 2020, 08:16:22 »
Loving this set and look forward to be contacted for a GB  :thumb:
Offline gunth
« Reply #57 on: Sat, 04 July 2020, 03:23:53 »
i'am in, really love the colors
Offline BaliBae
« Reply #58 on: Tue, 14 July 2020, 12:26:57 »
2nd post for this awesome colourway! waiting for the GB  :thumb:
Offline princedynamite
« Reply #59 on: Wed, 22 July 2020, 10:30:16 »
love this set, i'm in for sure. any change we can get a Rama collab? for instance, a metal cap in one of the accent colors w/ the detonator, or the TNT bundle would be really cool
Offline Congree
« Reply #60 on: Fri, 07 August 2020, 07:46:07 »
I feel like it’s missing a yellow spacebar in the standard kit or in the spacebar kit and some more yellow keys. It looks nice, but some more yellow options would make it better. Definitely having an extra kit only for yellow spacebar is a big no.
« Last Edit: Fri, 07 August 2020, 07:52:02 by Congree »
Offline scud80
« Reply #61 on: Wed, 09 September 2020, 14:45:28 »
Well, this is a couple weeks later than I was planning for an update, but here we are.  I've just submitted kits, and pricing is being determined now.  Still on schedule for GB starting in about four weeks.  Once I have renders for the kits I'll post pics here, as opposed to using KLE images.  Proxies will be NovelKeys, mykeyboard.eu, DeskHero, and Daily Clack.  There will likely be a deskmat GB a few months after the keyset GB, so that they fulfill around the same time.  Matching artisan raffles will happen a week or two after the GB concludes.  I'm still finalizing the roster for that, but there will be solid artisan support.
Offline Suavity
  • Smile more! 🙂
« Reply #62 on: Sat, 03 October 2020, 15:38:23 »
Is there a set date of when the GB will go live?
Offline mgsickler
« Reply #63 on: Sat, 03 October 2020, 18:07:21 »
October 9! Working out some final details.
Offline zedbraxmen
  • Sheesh
« Reply #64 on: Sun, 04 October 2020, 20:26:19 »
whew, i thought this set was dead in the water, glad to see a GB date!
HHKB Kei | Constellation
Offline scud80
« Reply #65 on: Mon, 05 October 2020, 17:32:29 »
Yes, the GB will be running from Oct 9-Oct 30th with NovelKeys, MyKeyboard.eu, Daily Clack, zFrontier, and DeskHero.  I'll post a link here to the GB thread when it goes up on Friday.  That post will have all the info on pricing, renders, artisan collabs, and giveaways.  The time is nigh!
« Last Edit: Tue, 06 October 2020, 15:17:37 by scud80 »
Offline vi0till
« Reply #66 on: Tue, 06 October 2020, 10:40:33 »
Seems like Asia region will be covered by DailyClack?
Offline scud80
« Reply #67 on: Tue, 06 October 2020, 15:17:14 »
zFrontier is now covering Asia.  I hadn't spoken with them directly, but NK arranged it.
Offline nvh2092
« Reply #68 on: Tue, 06 October 2020, 15:37:01 »
Any news on pricing?  :)
Offline scud80
« Reply #69 on: Tue, 06 October 2020, 19:04:29 »
Yeah, I'll post the final kits with the GB post.  For example, base kit now includes numpad/ISO and will be 135 in the USA (it's a pretty large base kit).  There are 6 other kits that range from 25 to 65.
Offline zedbraxmen
  • Sheesh
« Reply #70 on: Tue, 06 October 2020, 21:32:35 »
Yay! Thanks for including the numpad / ISO in the base kit!
Offline ben56k
« Reply #71 on: Fri, 09 October 2020, 05:02:04 »
I'm waiting for your GB post but the novelties at 66 € is a bit hard.
Offline consumer
« Reply #72 on: Fri, 09 October 2020, 15:26:26 »
In the Super Duper kit, what row number are the keycaps? Are they all R1?
Offline DevilZmods
    • Etsy Shop
« Reply #73 on: Tue, 20 October 2020, 14:31:44 »
We just had a bit of discussion on the ace keyboard co. discord and i whipped these two up:
254136-0
254138-1
They're not 100% accurate as I only changed around the colours on my existing renders but i thought i'd leave them here.
