Author Topic: Case options for Boardwalk  (Read 7715 times)
Offline Robosculpts
« on: Thu, 05 December 2019, 18:18:23 »
Hey all, I was wondering if any of you could recommend a case for the Boardwalk.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: Case options for Boardwalk
« Reply #1 on: Fri, 06 December 2019, 09:54:31 »
As far as I know it will fit in most 60% cases; the problem is you would almost always need to get a custom plate made.
Offline Robosculpts
« Reply #2 on: Fri, 06 December 2019, 11:21:36 »
Awesome, thanks for the reply. It looks like you can still order plates from MKUltra. But it says sold out when trying to buy the pcb + plate combo. I emailed them to make sure.
