Author Topic: Post Your Cerakoted Keyboards  (Read 17331 times)
Offline MMKB
« on: Fri, 06 December 2019, 14:24:26 »
Time for a change
Offline MMKB
Re: Post Your Cerakoted Keyboards
« Reply #1 on: Fri, 06 December 2019, 14:34:53 »
Khers' X60 in Bazooka Pink.
https://geekhack.org/index.php?topic=35864.msg2830336#msg2830336
Tyson's DMG-themed X60.
https://geekhack.org/index.php?topic=98153.msg2831652#msg2831652
Yet another X60 in Light Sand by yours truly.
Offline chayu
« Reply #2 on: Thu, 23 January 2020, 19:12:22 »
This is my Tofu in Polar Blue 234182-0
Offline wholypantalones
  • text and icon mods plz.
« Reply #3 on: Thu, 23 January 2020, 21:34:02 »
Okee doke.
Mech27 proto - Cobalt Kinetics Slate
LZ CLS - Tungsten and satin aluminum
Noxary 268 - Semi gloss satin aluminum
LZ CLS - Satin mag and sandblasted weight
« Last Edit: Thu, 23 January 2020, 21:53:28 by wholypantalones »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #4 on: Mon, 27 January 2020, 05:33:55 »
Okee doke.
The shop you're using does some really clean work. How much are these costing you and what kind of lead times do they have?
« Reply #5 on: Mon, 27 January 2020, 06:42:44 »
Okee doke.
They usually charge about $80-ish for tkl with a two week lead time. Great guys and they do a great job, I had a good experience with them leading up to the last time I had my CLS redone, they put some dings in the bottom of the case (not really noticeable, but still there) and didn't seem to want to take responsibility for it when I asked what happened. I'd obviously recommend them, but there's no guarantee that your board won't get dinged.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #6 on: Mon, 27 January 2020, 06:44:59 »
Okee doke.
Not bad! I will inquire further if/when the time comes to do so -- thanks for the details!
Offline MMKB
« Reply #7 on: Mon, 02 November 2020, 17:03:21 »
Duck Viper V3 in H-312 Frost. https://www.cerakote.com/shop/cerakote-coating/H-312/frost My failed attempt at mimicking Freedom Gundam. Might try again with other accents.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #8 on: Fri, 06 November 2020, 03:43:24 »
Lovely. Clean look. Seems like you've been hooked on the cerakote for some of these boards!
