Author Topic: Re: [IC] GMK Demon Sword - GB is live!  (Read 208442 times)
Offline konstantin
  • Formerly constexpr
Re: [IC] GMK Demon Sword - GB OCTOBER 2020 & PRICING!
« Reply #150 on: Sat, 22 August 2020, 07:24:21 »
Updates
8/2/2020 (Ready to dissembark)
GB Date Announced - October 2020
Kits Finalized
Announced Kit pricing!
The kits are good for the most part, barring a few small oversights. Kitting is final though, so that's that.
However, one thing that can still be fixed without affecting final pricing/quotes are the legends. I say this because some of the Japanese sublegends used in this set are incorrect.
A bit of background as to why it's possible to fix the legends even at this point: During the Yugo IC/GB, we were able to change one of the legends that was incorrect way after we had finalized the kits (we realized too late that it was incorrect). FaKe_VirTual recently did the same with GMK Sumi, fixing several Japanese sublegends that were off (similar to this set). As long as it isn't adding or removing keys, changing their sizes, or introducing new legend molds, the quotes are still valid and GMK are very open to discussing changes like that, since, at the end of the day, it results in a better product for the customer.
Now, what exactly is wrong with the legends in GMK Demon Sword?
  • The R3 #~ and R4 \| ISO keys in Base are missing their sublegends.
    • These are supposed to be R3 む and R4 ろ, respectively. Examples: GMK Bentō R2, GMK βeta, GMK Deku, kana sublegends reference.
    • In addition, since you are offering just basic ISO compatibility, you can use R3 \|, R4 <> instead of R3 #~, R4 \|, for consistency.
    • In summary, you have two options:
      • keep primary legends as is, just add sublegends: R3 #~む, R4 \|ろ (like GMK Deku);
      • change primary legends and add sublegends: R3 \|む, R4 <>ろ (like GMK Bentō R2 and GMK βeta).
  • Unfortunately, the Oath kit is missing the R3 ISO key altogether, but this probably can't be helped at this point.
    • Since Oath can't be used with ISO at all for this reason, the best you can do at this point is to change the otherwise useless R4 \|む key to an Alice second Bこ.
    • A second B is currently missing from the set altogether, as others have pointed out. This way it will at least be present in one of the kits.
    • In summary, change R4 \|む to Bこ in the Oath kit.
  • The set is inconsistent in its use of quaternary (top-right) sublegends.
    • The most important quaternary sublegends, the ones on the number row, E and Z keys, are missing; yet the less important ones on the punctuation keys (「 」。、・) are included.
    • If you chose not to use quaternary sublegends in this set for aesthetic reasons, please make the set visually consistent by removing the ones on the punctuation keys as well.
    • In summary, remove the top-right sublegends from the following keys, in both the Base and Oath kits: [{, ]}, ,<, .>, /?.
In the end, you should end up with legends and sublegends like in this reference image. Naturally, molds for all of the legends mentioned here already exist.
Again, communicating this with GMK shouldn't be a problem and should not affect the existing pricing. Let me know if you have any questions.
« Last Edit: Wed, 02 September 2020, 14:08:17 by konstantin »
Offline engyshow
« Reply #151 on: Mon, 07 September 2020, 16:03:25 »
I'm in! :D
Offline Raravin
Re: [IC] GMK Demon Sword - GB in 4 Days - Pricing Finalizzed
« Reply #152 on: Sun, 27 September 2020, 17:24:16 »
Updates
9/27/2020 (Raising the Anchor)
Prices Finalized
MOQ Placed on IC
Added TX66 Renders
Offline crzone
Re: Re: [IC] GMK Demon Sword - GB in 4 Days - Pricing Finalized
« Reply #153 on: Wed, 30 September 2020, 04:15:11 »
As an owner of DSA Royal Navy and SA Royal Navy, I'm considering getting this, especially since GMK Royal Navy did not happen.
Offline Varus27
« Reply #154 on: Thu, 01 October 2020, 12:10:31 »
Just put in my order, super excited and good luck!
Offline Krolyk
« Reply #155 on: Thu, 01 October 2020, 13:41:04 »
take my money
Offline Ramzh
« Reply #156 on: Sat, 15 January 2022, 06:06:25 »
Any update on this?
It's Jan  2022....
Got mines from mykeyboard EU and still says on pending...
Offline Fraaaan
« Reply #157 on: Sat, 15 January 2022, 06:10:19 »
Any update on this?
It's Jan  2022....
Check the GB thread for updates. IC threads stop being updated as soon as the set goes live.
Offline Traveler
« Reply #158 on: Sat, 15 January 2022, 11:34:02 »
Any update on this?
It's Jan  2022....
Keep an eye on the Mekibo website. They were the USA vendor. They have a page for the status of group buys and it’s updated fairly regularly. The page was recently updated saying that the keyset is still stuck in queue for production and that current estimates are that it’ll finish production sometime in Q2.
