Author Topic: [GB] GSKT-00 (Shipping almost finished, 80% done)  (Read 1160490 times)
Offline nachie
    • KapCave
Re: [GB] GSKT-00 (Shipping almost finished, 80% done)
« Reply #1850 on: Fri, 01 December 2023, 12:35:33 »
Not the update post you were looking for, sorry.
I keep receiving DMs every now and then about spare pcbs. I'm going to place an order for some other pcbs, so thought Id check if people still want this and add that to the order. This won't be a group buy, just trying to gauge interest before I order stock.
If you want one, please fill this out. Will keep it open for a week-ish, and if we have more than 25 then place the order.
https://forms.gle/p46vieiSvzbmffYB8
PCBs are in-stock on https://littlecraftery.com/products/gskt-00-pcb
Those that filled out the IC form earlier have been invoiced and stock set aside for them, rest of the stock is listed on the site. There should be plenty extras, but I don't plan to restock these once these are gone.
Again, I have no stake in this GB other than having designed the PCB, just trying to make sure whoever needs an extra gets one.
AHKB | GSKT-00 | Arya | Båge | Paladin64
Offline krautcat
  • local the flammable man without identity
« Reply #1851 on: Fri, 01 December 2023, 13:07:19 »
I lost hope to get either my GSKT-00 or money (I'm from Russia).
Offline cdhoffmann
« Reply #1852 on: Fri, 01 December 2023, 13:18:25 »
This GB was such a joke.
Offline frosty
  • jukebox hero
« Reply #1853 on: Mon, 12 February 2024, 04:00:15 »
4 years on and still waiting... :(
edit: got my refund
« Last Edit: Sun, 25 February 2024, 12:55:53 by frosty »
Offline jrs
« Reply #1854 on: Fri, 29 March 2024, 10:58:12 »
Has anyone used MT3 keycaps with their GSKT-00?  Do they fit?  I remember hearing that SA keycaps don't fit, with the back row colliding with the case.
Offline loud_asian
« Reply #1855 on: Sat, 06 April 2024, 20:39:48 »
I'm able to mount SA caps without a problem. The number row is a bit tight though, the wire from a keycap puller sometimes doesn't fit (cherry profile or SA profile), but their isn't any binding when typing.
Offline Noni51
« Reply #1856 on: Wed, 13 November 2024, 04:00:56 »
Does anyone know if any universal 60% plate would work with the GSKT? For example: https://mechboards.co.uk/products/60-universal-alu-plate?variant=40295771275469
Offline toniwonkanobi
« Reply #1857 on: Wed, 13 November 2024, 08:15:09 »
Doesn’t work. Need the board-specific plate.
