Author Topic: [IC] Prophet - 60% Keyboard  (Read 126970 times)
Offline westfoxtrot
    • Cable Car Designs
« on: Sun, 19 January 2020, 11:46:07 »
GB thread is live here: https://geekhack.org/index.php?topic=105670
There is no upper limit for the GB, it will continue to run past the close date if minimum order quantity is not met
If something is written in an update it supersedes any contradictary information from the original post
edited: cleared up confusion around MOQ
Update 2
Hi, sorry for the long delay in getting an update - obviously the current global situation has affected this.
Group Buy is currently being pushed to start 15th April with a kit price of $325 + local taxes + shipping.
A kit includes: 1 top, 1 bottom, 1 pcb, 1 plate
Vendors
US - Cannon Keys
EU - mykeyboard.eu
OCE - dailyclack
SEA - iLumkb
Colours selected as per poll:
Black
E-White
Dark Blue (should be very similar to the Satisfaction75 blue)
Unfortunately we are limited to 3 colours due to manufacturing requirements.
The bottom will be available in either black or matching your top.
PCB colour will be Matte Black
Extra Tops, PCBs and Plates will be available (pricing TBD)
Plates will be available in Nylon, Polycarbonate, & Polypropylene
The GB has an MOQ (Minimum) of 150 and will remain open until April 30th or until we reach 150 units. If this number is looking unrealistic after 2 weeks we will re-evaluate what we are able to do.
PLEASE NOTE
Due to the current situation in China my factory has not returned to work and it's very possible (looking likely) that we will have to push the start of this back slightly so we are able to fully finalise details with them (was in the process of final quotes when CNY started) I really hope I don't have to do this and we can get it going on time.
GB will be delayed until the factory is able to confirm: timeline/prices. Sorry for the delay - very much out of my hands
Update 1
Excited to annouce a partnership with koen for GMK Perestroika, if you buy the keyset you can enter to win a prophet! this will take place before the prophet buy starts so you can still get both if you don't win :-D. Full details here
Hello,
Prophet is a “pin-mount” seamless 60% keyboard. Here’s an image that showcases the construction:
there is no pressure from the top half of the case on the plate. There are 4 pins in the corners of the base that hold the plate in place and it rests on the lip of the base. The theory is that the lack of downward pressure allows the plate more freedom of movement towards the center whilst still retaining an even pressure around the edge of the board
Here is the interest check form
Originally my intention with the design was to create something simple that had a consistent sound profile and type feel and I am more than pleased with the results. The design has been through several small iterations but for the most part is largely unchanged from the initial drawings.
It will be manufactured from 6063 Aluminium and anodised in a choice of 3 colours. All boards will come with a black base. There will be HHKB, WKL & Standard Tops available.
The angle of the case is 6°
It includes a custom PCB designed by me that supports ISO/ANSI layouts with a 7u(Tsangan) bottom row only. The case also supports any standard 60% PCB with a type-c usb port. Mini will likely also work but it depends on the cable.
Plate materials will be: Polycarbonate, Polypropylene, and Nylon. Both full and half plates will be available. ISO plates will likely be made available in a single material only. Plate files will be released so you can make/modify your own as you like.
The current target price is $350 though this is subject to change. This will include at least 1 plate and PCB.
The current target timeline is to open March 1st for 2 weeks. Shipping should then take place in June-July.
MOQ of 50, no upper limit. Each different top has an MOQ of 15.
Additional plates and PCBs will be available during the group buy stage though there is no pricing currently available for this.
Mykeyboard.eu will be handling the buy and shipping, if you would like to act as a proxy for your region please feel free to get in touch with me here or by any contact method listed here: Reddit, Geekhack, email, discord.
If you have any questions or comments about the case/pcb/buy structure please ask here or by any of these contact methods:  Reddit, Geekhack, email, discord.
Here is an album of images
Thank you for your time
Max
here are some soundtests/typing videos of R1/Original proto
Koen on youtube
Koen on youtube
TopClack on youtube
invis on youtube
invis on clyp.it
Aly on youtube
Chris on youtube
« Last Edit: Wed, 15 April 2020, 03:27:52 by westfoxtrot »
Offline hansichen
Re: [IC] Prophet - 60% Keyboard
« Reply #1 on: Sun, 19 January 2020, 11:52:29 »
My all time favourite board. Looking forward to the group buy  :thumb:
Offline jonowarren94
« Reply #2 on: Sun, 19 January 2020, 12:08:47 »
Very interested. Can I make the suggestion/ask that the ISO only plate be the nylon variant as its easier to get other materials? Where as I have never seen another board with a nylon plate let alone where to get one.
Offline kabocha
« Reply #3 on: Sun, 19 January 2020, 12:10:26 »
Was just chatting about this last night. Looking forward to the GB!
Offline ChrisSwires
« Reply #4 on: Sun, 19 January 2020, 12:30:59 »
 :p
Offline fleeceman
« Reply #5 on: Sun, 19 January 2020, 12:48:56 »
Very interested and may I suggest that the ISO plate be polypropylene if it is only offered in 1 material.
Offline keyberzerker
« Reply #6 on: Sun, 19 January 2020, 12:58:50 »
Interested!  :thumb:
Offline pr0ximity
« Reply #7 on: Sun, 19 January 2020, 13:12:47 »
Can you describe what you mean by “pin-mount”? I can’t quite tell based on the provided images, is the plate pressed between the bottom and top halves of the case?
Offline Pwner
  • soon™
« Reply #8 on: Sun, 19 January 2020, 13:24:20 »
Yes.  Thanks.
Online LightningXI
  • PPD
    • ArtisanMacro
« Reply #9 on: Sun, 19 January 2020, 13:42:30 »
Interested. Thanks.
Offline westfoxtrot
    • Cable Car Designs
« Reply #10 on: Sun, 19 January 2020, 13:55:31 »
there is no pressure from the top half of the case on the plate. There are 4 pins in the corners of the base that hold the plate in place and it rests on the lip of the base. The theory is that the lack of downward pressure allows the plate more freedom of movement towards the center whilst still retaining an even pressure around the edge of the board.
I will add to this first post and sorry for the confusion
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #11 on: Sun, 19 January 2020, 14:06:27 »
This looks awesome. The mounting looks pretty unique as well :thumb:
Offline pixelpusher
« Reply #12 on: Sun, 19 January 2020, 14:32:43 »
Not sure how it will sound without pressure from the top.  Interested though
Offline 002 DC
« Reply #13 on: Sun, 19 January 2020, 14:46:30 »
Sugoi
Offline westfoxtrot
    • Cable Car Designs
« Reply #14 on: Sun, 19 January 2020, 14:52:11 »
There are a couple of videos/clips of it here:
Koen on youtube
Koen on youtube
TopClack on youtube
invis on youtube
invis on clyp.it
Aly on youtube
Chris on youtube
« Last Edit: Sun, 19 January 2020, 14:58:28 by westfoxtrot »
Offline modeseven
« Reply #15 on: Sun, 19 January 2020, 15:32:34 »
The sound tests make my ears happy. Very interested.
Offline Mcnos
    • GMK Fuyu
« Reply #16 on: Sun, 19 January 2020, 15:44:04 »
Ah yes,
I've been waiting for this
« Reply #17 on: Sun, 19 January 2020, 15:45:23 »
I like this
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #18 on: Sun, 19 January 2020, 16:39:24 »
Best board I've felt. Join this or you are really missing out bois
Offline FredBananaz
« Reply #19 on: Sun, 19 January 2020, 17:12:53 »
Anyone able to explain how the different plate materials sounds/feel relative to alu/POM? I've not been in the hobby long enough to join a meetup and feel the difference for myself...
Offline Mcnos
    • GMK Fuyu
« Reply #20 on: Sun, 19 January 2020, 17:14:07 »
This has a pretty decent write up on the details you are asking about
https://brianlee.blog/2018/11/23/guide-keyboard-construction-explained/
Offline Robosculpts
« Reply #21 on: Sun, 19 January 2020, 17:37:07 »
hella down for this!
Offline pancake
    • mizuena.com
« Reply #22 on: Sun, 19 January 2020, 18:03:24 »
this thing sounds poppin
edit: blue-gray please thanks
« Last Edit: Sun, 19 January 2020, 18:52:25 by TheMagicPancake »
SA Bisoromi | GMK Gregory | GMK Stonks | GMK Faceless | GMK Gregory 2
HHKB Snow 25th | RS | RS60 | RS65 | TGR Jane v2 CE
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #23 on: Sun, 19 January 2020, 18:12:29 »
Will there be an option for a brass base?
Offline Macmutant
« Reply #24 on: Sun, 19 January 2020, 18:14:51 »
Been wanting one since my friend got one from the first round. In for sure.
Offline noorejji
« Reply #25 on: Sun, 19 January 2020, 18:31:40 »
Hoping for blue-grey or dark green. :D
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #26 on: Sun, 19 January 2020, 19:12:51 »
How is this different from a typical bottom-mount keyboard like the KBD67 v1?
Offline Ryanticz
« Reply #27 on: Sun, 19 January 2020, 19:17:27 »
YESSSS. Been waiting for this! And no upper limit, can't wait!
Offline Quriosity
« Reply #28 on: Sun, 19 January 2020, 20:00:56 »
Definitely interested and glad to see the IC up
Offline Zeelobby
« Reply #29 on: Sun, 19 January 2020, 20:31:35 »
Do have to admit. No upper limit is so relaxing considering there's so many boards I currently want with limits.
Sent from my Pixel 3 XL using Tapatalk
Offline bthezebra
« Reply #30 on: Sun, 19 January 2020, 21:04:38 »
Also interested, especially after understanding the unique mounting.
Offline Darth WTF
« Reply #31 on: Sun, 19 January 2020, 21:08:45 »
best 60% ever, don't @ me
Offline dantambok
« Reply #32 on: Sun, 19 January 2020, 23:18:14 »
I like rectangles
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
« Reply #33 on: Mon, 20 January 2020, 03:18:57 »
+1 for brass base option pls :)
Offline belgium_waffles
« Reply #34 on: Mon, 20 January 2020, 04:40:06 »
Please consider daily clack as oce vendor!
Offline pockydavid
« Reply #35 on: Mon, 20 January 2020, 04:52:17 »
+1 to Daily Clack.
Look forward to this board!
Offline octix
« Reply #36 on: Mon, 20 January 2020, 05:02:27 »
+1 to Daily Clack.
+1 for this too
Also great board!
Discord: octix#0478
Offline aeryxz
    • aeboards
« Reply #37 on: Mon, 20 January 2020, 05:50:46 »
keen
Offline westfoxtrot
    • Cable Car Designs
« Reply #38 on: Mon, 20 January 2020, 06:04:08 »
On bottom mount you have fixed rigid points on the assembly where the plate screws in, this has no fixed points on the assembly which allows the whole assembly some freedom of movement
I like rectangles
thanks me too
@Darth?
I have not personally used POM, in this board I have tried CF but not alu and I'd roughly equate them for feel though not for sound. For CF I personally think it's a touch rigid though I definitely prefer a softer bottom out. here is what I said about the plate materials on discord:
Both are softer than acrylic and PC. PP has a much lower rating in terms of hardness which gives it a really soft bottom out and a lighter note. Nylon has a slightly deeper note than that and is also slightly firmer. The advantage in both is they are soft enough to dampen vibrations from hitting switches
Fwiw nylon is my preferred material in this case
I will reach out to them and see if they are interested.
Offline westfoxtrot
    • Cable Car Designs
« Reply #39 on: Mon, 20 January 2020, 06:06:27 »
Most likely not this time. Sorry to dissapoint.
Offline koenoe
    • My YouTube channel
« Reply #40 on: Mon, 20 January 2020, 06:08:33 »
POM is pretty nice in the Prophet! It has a much softer bottom out than for example brass (I haven't tried alu plate), but not as soft as PC. Sounds good too.
A few of my Prophet builds for sound reference:
POM:
Brass:
PP:
Offline ddnomad
« Reply #41 on: Mon, 20 January 2020, 06:25:37 »
Please OP, do not break my heart! That brass bottom is SeX I want it :D
Offline Crack85
« Reply #42 on: Mon, 20 January 2020, 06:40:30 »
In sounds awesome
Offline noorejji
« Reply #43 on: Mon, 20 January 2020, 06:47:42 »
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #44 on: Mon, 20 January 2020, 06:54:46 »
consider my interest checked
gimmie
Offline westfoxtrot
    • Cable Car Designs
« Reply #45 on: Mon, 20 January 2020, 07:02:53 »
the brass base is not something I ever particularly considered part of the vision for what this board is. 3 were previously made and personally I am not sure I see the benefit of it. The board is perfectly weighted as it comes and in order to keep SKUs to a minimum we won't be including it this time though we may revisit this in future once I have had some time to experiment with materials.
Offline ddnomad
« Reply #46 on: Mon, 20 January 2020, 07:14:44 »
Heh, I get it, though lookz with the brass base are top notch :)
Will be most probably joining this keyboard anyway, cause it sounds just outstanding :)
Offline Steezus
  • Keeper of Facts
« Reply #47 on: Mon, 20 January 2020, 07:17:38 »
Very interested! I like brass bottoms too but definitely not a deal breaker.
Offline koenoe
« Reply #48 on: Mon, 20 January 2020, 07:31:09 »
I'd like to add that I opted for a brass base in the private run, because of aesthetics only. After trying both, and playing with different plate materials on both, I think the board sounds better with an aluminium base.
Offline ddnomad
« Reply #49 on: Mon, 20 January 2020, 07:37:19 »
Thanks for the feedback :) That kinda convinces me lol
