Author Topic: [IC] GMK Sumi | GB live! | 15th July to 15th August  (Read 445642 times)
Offline harlekein
Re: [IC] GMK Sumi | Update No.3 | Added Renders and RAMA WORKS Collaboration
« Reply #150 on: Tue, 24 March 2020, 04:33:05 »
Only the first time I am looking into this. It's beautiful. I am very interested in Hiragana mono alphas kit and 40s.
Why is there PgUp and PgDn in 40s? This should be lower/raise. Having Caps in there makes no sense to me either. Who uses Caps on 40s?
I also find the additional `"` keys very strange since these are copied from the alphas kit. The only way this would apply is if they were mod colored for symmetry instead of alpha colored.
Please also consider adding an R2 1u Novelty like the circle for R1. This would be a beautiful accent key for 40s and I'd pick up that kit for that and the 1.5u R4 keys.
Offline stoffelduss
« Reply #151 on: Tue, 24 March 2020, 07:24:44 »
not sure if I'm going to get this, but if I did, I'd want to use it with a numpad with split plus. you offer the - and + keys for the positions of the 2u plus, but there are no black mods that I could put above the minus key then (except for the F13, which doesn't feel like it would belong there). can you add a black = key or something like that for that position?
also, did you intend to only put beige 6u spacebars in the spacebar kit? it seemed like black would be the "standard" color for spacebars here.
what's the reason for 2 1u Fn keys in base? I find 1.5u super support in base also questionable...
Offline FaKe_VirTual
    • Virtual Designworks
« Reply #152 on: Tue, 24 March 2020, 08:07:27 »
I might consider adding another 6U alpha colour spacebar to it.
60s support and the 1.5U Supers are for HHKB support. I'd like to cover as much Layouts as possible with the Base kit so this choice was made.
Offline jerrolds
  • Discord "jerrolds | deskhero.ca#0379"
    • Deskhero.ca
« Reply #153 on: Tue, 24 March 2020, 09:33:59 »
These new renders are so good
Re: [IC] GMK Sumi | Update No.3 | Deskmat Render and minor changes
« Reply #154 on: Tue, 24 March 2020, 10:12:43 »
I've added a Deskmat Render and reworked the Base- and Spacebar Kit.
Offline i luv chuletas
« Reply #155 on: Tue, 24 March 2020, 11:11:51 »
I'm not really crazy about Rama caps, but this one is screaming "put me on your keyboard" at me and I can't seem to ignore it.
Crazy good update mate, and hell of a lot of love for hiragana and 40's kit.
monochrome mods kit, by any chance?
Will be getting this for sure.
Offline AEN
« Reply #156 on: Tue, 24 March 2020, 11:16:40 »
God that looks sweet im so down.
Offline konstantin
  • Formerly constexpr
« Reply #157 on: Tue, 24 March 2020, 12:28:05 »
You can use the blank R1 1u black key.
+1 for this. Most sets' spacebar kits opt to go with an accent color for the 6.25u and 7u spacebars, and alpha color for the 6u spacebar since one isn't included in the base kit.
Yep, I don't think there should be two 1u Fn keys.
Offline YangYoga
« Reply #158 on: Tue, 24 March 2020, 13:56:50 »
In in in in
Offline FTR_Beat
« Reply #159 on: Tue, 24 March 2020, 15:11:09 »
I see you updated the kit to fit the FC660M =) The set is looking awesome.
Any plan for additional Alphas (e.g. reversed color)?
« Reply #160 on: Tue, 24 March 2020, 15:22:25 »
No, I don't think that I will add reversed alphas. This is because I think there are enough completly white Sets out there and the all white theme wouldn't fit sumi-e in my opinion.
Sorry.
Offline konstantin
« Reply #161 on: Tue, 24 March 2020, 16:04:40 »
It just occurred to me that it seems kind of weird to have quaternary legends on the [{, ]}, ,<, .>, /? keys but not have them on the number row, E and Z. If you don't like the quaternary legends, you might want to remove them completely.
Offline vurtomatic
« Reply #162 on: Tue, 24 March 2020, 16:23:35 »
Sorry.
What about black mods?  :p
Offline arkaell
« Reply #163 on: Tue, 24 March 2020, 21:01:56 »
This set just keeps getting better. I can’t wait for July!
Offline Missingnumber
« Reply #164 on: Tue, 24 March 2020, 22:07:26 »
I posted some comments in the Reddit thread, but I wanted to quickly say that I love the Rama caps. I'm definitely in for the 墨 one and the base set.
Good work on the vendors too! I've had good experience with thekey.company. I'm excited about July.
Offline amarotea
« Reply #165 on: Tue, 24 March 2020, 23:31:31 »
I'd definitely get a deskmat—or two
Offline TonyPia
« Reply #166 on: Wed, 25 March 2020, 11:28:28 »
I guess 墨 means black ink? Why is it red in the RAMA keycap?
« Reply #167 on: Wed, 25 March 2020, 11:49:40 »
It's a reference to the signature you can see on the Deskmats.
Offline TonyPia
« Reply #168 on: Wed, 25 March 2020, 12:25:01 »
Hmm... interesting. It looks good with the mats but not sure about artisan cap but still you probably want to keep red in the escape spot. Tough.
« Reply #169 on: Wed, 25 March 2020, 12:34:52 »
I could offer a red version of it with black infill like this:
Offline TonyPia
« Reply #170 on: Wed, 25 March 2020, 12:41:17 »
Dude, this is sick. But complying your theme how about red cap with white letter even though the letter itself says black? Not confident if it would look good enough.
« Reply #171 on: Wed, 25 March 2020, 16:08:19 »
The white cap with red character makes sense. It's a reference to hanko, or Japanese style stamp seals. Artists make their own, and put the seal on their works. The name of this set is "Sumi", so having the kanji for sumi (墨) be written in red on white makes perfect sense, to reference hanko stamps. If you can make the white similar in color to the mod keys it would be best, but I like it a lot as-is.
Edit:
That being said, stamps that create red background with white text are also used commonly in art, so that would make sense as well. I guess my only argument is that it shouldn't involve black, even if the word means black ink.
« Last Edit: Wed, 25 March 2020, 17:35:16 by Missingnumber »
Offline deathwalker113
« Reply #172 on: Wed, 25 March 2020, 19:58:11 »
The RAMA red version look like Urushi lacquer finish
Offline kokugatsu
« Reply #173 on: Thu, 26 March 2020, 05:42:07 »
The Kanji text on the second row of novelties look very jarring, plus they don't fit the theme or make much sense to native speakers. Would prefer a different font and different text.
Circular brush stroke is dope though.
Offline arkaell
« Reply #174 on: Thu, 26 March 2020, 06:02:51 »
I'm in on that red cap, but I do agree that the black should be white instead.
Offline FTR_Beat
« Reply #175 on: Fri, 27 March 2020, 10:38:28 »
I agree with kokugatsu's feedback. Other font for the Kanji may look nicer.
Love the inked brushed one!
« Reply #176 on: Fri, 27 March 2020, 10:56:33 »
I will soon release another Update with fixed Novelties!
Offline TopreMoon
« Reply #177 on: Fri, 27 March 2020, 14:02:30 »
I would definitely be in for some deskmats. Love the keycaps, but I only have topre :'(
Good luck!
Offline FTR_Beat
« Reply #178 on: Fri, 27 March 2020, 15:08:54 »
Good luck!
Nice, I have a Topre form daily use. But also have a cherry profile keyb to play with keycaps. Perhaps something to thing about; but watch out for the rabbit hole (not saying you should get another keyb though :))
Offline Dorney
« Reply #179 on: Fri, 27 March 2020, 22:24:23 »
Very nice keycap set, I'd buy the keycaps but personally dont want the sublegends on the alphas.
Will definitely be picking up a deskmat or two!
"Zambumon Mald" title="Zambumon Mald"
Offline DuellM
  • Keyboard Fatty
« Reply #180 on: Sun, 29 March 2020, 14:53:22 »
Wow That Red Rama With Black Infill Is Beautiful  :eek:
Offline joonia
« Reply #181 on: Tue, 31 March 2020, 02:12:49 »
ramas and deskmats  :eek: :eek: :eek: :eek:
Offline TopreMoon
« Reply #182 on: Wed, 01 April 2020, 12:22:05 »
I'm greatly considering a Tokyo60 or something for a MX compatible HHKB D: But they cost more than a HHKB!
Offline trustworthy
« Reply #183 on: Fri, 03 April 2020, 18:26:08 »
When??
Offline arrowM
« Reply #184 on: Sun, 05 April 2020, 05:23:48 »
This feels like the set I've always been waiting for. Looks incredible!
Offline NICOTINE
« Reply #185 on: Sun, 05 April 2020, 21:16:01 »
I'm in for everything this set offers. So beautiful! Well done and good luck with GB!
Offline Radium
  • Newbie
« Reply #186 on: Sun, 05 April 2020, 23:58:41 »
Awesome deskmat. Well done! I just woner when GB is started?
Offline Pach
« Reply #187 on: Mon, 06 April 2020, 10:30:30 »
So many deskmat options. And they all look amazing!
Offline 2QT2BSTR8
« Reply #188 on: Mon, 06 April 2020, 17:38:32 »
July 1st according to Candykeys Instagram.
Offline ecbob
« Reply #189 on: Tue, 07 April 2020, 00:56:01 »
Prefer when the F1-4 and F9-12 are the same color as the alphas and the F5-8 are the same color as the mods. Basically reverse the F key colors
Offline nettoxx7
« Reply #190 on: Tue, 07 April 2020, 12:46:46 »
Definitely a buy for to mix and match with gmk metaverse, even the RAMA cap is a beaut  :thumb:
Offline eupho
« Reply #191 on: Thu, 09 April 2020, 01:45:52 »
Definately in for the base, RAMA keycaps and deskmats.
Probably also the hiragana set, but feel it would go better with a kanji only modifier set.
Offline Hanabi
  • Falling into a black hole.
« Reply #192 on: Thu, 09 April 2020, 02:34:25 »
Love the artisan and deskmat!
Offline phinix
« Reply #193 on: Thu, 09 April 2020, 17:49:38 »
OK, let's start this GB, come on:)
Offline konstantin
« Reply #194 on: Fri, 10 April 2020, 03:38:33 »
The Spacebar Kit - Man of Culture 文化の男
I think this is far too many 6u spacebars. And don't get me wrong, I like and use 6u more than most people (4 boards and counting), but 4 of them in a spacebar kit is too many. You should be fine offering just one (black, centered stem), in fact, or two at most (either one black centered, one black off-centered; or one black centered, one white centered).
« Reply #195 on: Fri, 10 April 2020, 04:42:23 »
I will soon be releasing an Update with all relevant news to GB, Kit updating and so on.
I'm considering this for the final Update. Thanks for the advice!
« Reply #196 on: Fri, 10 April 2020, 07:54:17 »
While I agree the number of 6u space bars may be excessive, I love the split spacebar options. So many kits don't include a 1.25u convex key, and this one has two.
Offline nudoh
« Reply #197 on: Sun, 12 April 2020, 18:25:59 »
I would love to see how this looks on a Milk U80
Offline Ryukote
« Reply #198 on: Fri, 17 April 2020, 03:59:59 »
You will post updated info here or there is some other dedicated place for that?
I am new to this hobby, so I don't want to miss this info.
Tnx.
« Reply #199 on: Fri, 17 April 2020, 05:40:04 »
Is in the works!
Yes, I will post any type of Update in this geekhack thread and in my discord. You can join it if you don't want to miss anything!
