Author Topic: [IC] GMK Sumi | GB live! | 15th July to 15th August  (Read 445646 times)
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
Re: [IC] GMK Sumi | GB moved to 15th July | Last changes were made
« Reply #350 on: Tue, 14 July 2020, 10:57:12 »
any updates on the price?
Offline FaKe_VirTual
    • Virtual Designworks
« Reply #351 on: Tue, 14 July 2020, 12:45:19 »
I will release the pricing with the start of the Group Buy in a couple hours!
Offline ..//dexx
« Reply #352 on: Tue, 14 July 2020, 14:32:49 »
I'm just obsessively refreshing. ;D
Offline konstantin
  • Formerly constexpr
« Reply #353 on: Tue, 14 July 2020, 18:47:32 »
The bonsai deskmat is a thing of beauty, along with most other things in this project. This is shaping up to be one heck of a GB!
Offline iFuwy
  • Aquarium and keyboard enthusiast!
    • @pump_upp - best crypto pumps on telegram !
« Reply #354 on: Wed, 15 July 2020, 02:31:53 »
I love this set so much. First time I'm buying kits + mat + rama. Thank you!
Offline Ookamice
« Reply #355 on: Wed, 15 July 2020, 11:17:43 »
It doesn't look like its on Candykeys yet even tho it's on the other vendors :c
Maybe I'm just blind...
Offline hrco999
« Reply #356 on: Wed, 15 July 2020, 11:20:06 »
https://www.reddit.com/r/mechmarket/comments/hrljw1/gb_gmk_sumis_group_buy_is_live/
It goes live at 7pm CET
Offline Ookamice
« Reply #357 on: Wed, 15 July 2020, 11:33:31 »
 :thumb: my bad
Offline majes
« Reply #358 on: Thu, 16 July 2020, 12:57:52 »
Love the set. Do you think you will ever make pbt versions of it in future? Or is it hard to achieve these colors in pbt
Offline OtherAndrew
« Reply #359 on: Thu, 16 July 2020, 16:12:11 »
thank you for putting ¥ on pipe, i noticed that it was missing from the 1u pipe however
