Author Topic: RealForce vs Leopold (Topre Switch)?  (Read 6655 times)
Offline edithnut
« on: Sun, 09 February 2020, 12:18:16 »
Thinking of getting a silent keyboard for work.
Having a hard time deciding between the RealForce TKL PFU Limited Edition and Leopold FC980C. Any ideas?
I actually prefer smaller size board so I could have my arms closer.
The only reason I'm considering the FC980C is due to its shorten layout.
BTW, do they both use PBT key cap? Would that be difficult to find some key cap replacement?
Cuz I'm assuming I could use them for a long period of time.
« Last Edit: Sun, 09 February 2020, 12:22:46 by edithnut »
Offline rxc92
Re: RealForce vs Leopold (Topre Switch)?
« Reply #1 on: Sun, 09 February 2020, 21:44:49 »
All Topre boards besides the Type Heaven are PBT, and new Realforces and I believe all Leopolds have PBT spacebars (older ones have ABS spacebars). HHKB has an ABS spacebar.
The R2 silenced is, in my opinion, superior to HHKB Type-S, and much quieter than the original silenced Realforce models. Would recommend a TKL R2 silenced.
Offline edithnut
« Reply #2 on: Sun, 09 February 2020, 23:24:51 »
Thanks for you input. Would you recommend Realforce more than Leopold in general?
« Last Edit: Sun, 09 February 2020, 23:26:34 by edithnut »
Offline rxc92
« Reply #3 on: Sun, 09 February 2020, 23:29:21 »
No problem, and I'd say now that the R2 is released, I would always recommend it over Leopold. Their offerings are in some ways superior to the original Realforce boards (especially since Leopold boards are more modern) but the R2's new software and superior case design, especially in silencing, makes it better in my book. However, I haven't tried an unsilenced R2; comparing that to Leopold is more difficult.
Offline nc0de
« Reply #4 on: Mon, 10 February 2020, 02:44:21 »
The new HHKBs that dropped in 2019 have a PBT spacebar.
Offline rxc92
« Reply #5 on: Mon, 10 February 2020, 10:35:04 »
Hybrids or all models?
Offline nc0de
« Reply #6 on: Tue, 11 February 2020, 10:22:24 »
Had to check. All new models (Hybrid, Classic) have the 'PBT space bar' listed as a new feature on the PFU online shop.
Offline edithnut
« Reply #7 on: Tue, 11 February 2020, 14:02:14 »
Where do you guys find those key cap replacement thats fit RF keyboard?
Offline rxc92
« Reply #8 on: Tue, 11 February 2020, 14:05:41 »
You can buy them from kbdfans here, they have a nice clean look to them. If you mean just the spacebar, they were sold on Massdrop a long time ago and they do reruns every now and then I believe.
