Author Topic: [GB] Duck Viper & Eagle V3 Kustom Keyboard (60%)  (Read 184987 times)
Offline Etherealsound
Re: [GB] Duck Viper & Eagle V3 Kustom Keyboard (60%)
« Reply #400 on: Wed, 19 August 2020, 23:45:42 »
Can anyone update on whether the pcbs included work with via?
Offline amirhosein
« Reply #401 on: Wed, 19 August 2020, 23:47:29 »
Yeah works perfectly fine.
Sent from my SM-G988U1 using Tapatalk
Offline amirhosein
« Reply #402 on: Sat, 22 August 2020, 14:04:43 »
If anyone strips their screws like I did you will need, M2.5 6mm and 10mm flat torx screws.
« Reply #403 on: Sat, 22 August 2020, 23:01:27 »
I just finished building everything and realized they didn't include enough screws for me.... What are the case screw dimensions...
Offline jiezhou
  • https://jiekb.com
    • JIEZHOU
« Reply #404 on: Sun, 23 August 2020, 07:06:56 »
For plate: M3 5mm * 7
For case:M3 15mm * 4, M3 10mm * 2, M3 6mm * 2
Offline amirhosein
« Reply #405 on: Sun, 23 August 2020, 11:09:17 »
I'm pretty sure the 4 15mm are m3 and the rest are m2.5. I need TR10 for those and TR8 for the rest.
Offline jiezhou
  • https://jiekb.com
    • JIEZHOU
« Reply #406 on: Sun, 23 August 2020, 21:58:30 »
It's easy to measure and get the dimensions.
« Last Edit: Sun, 23 August 2020, 23:16:33 by jiezhou »
« Reply #407 on: Mon, 24 August 2020, 12:24:31 »
Hold on, so is it M3 or M2.5? I feel like screw dimensions should be part of the GB details considering how often I get kits with missing screws...
Offline amirhosein
« Reply #408 on: Mon, 24 August 2020, 12:29:57 »
It's m3, I just changed mine yesterday. The 4 15mm's that go on top don't screw in with the same driver for me but looks like the thread size is the same so it should be good for those as well.
Offline jiezhou
  • https://jiekb.com
    • JIEZHOU
« Reply #409 on: Tue, 25 August 2020, 23:53:06 »
For sure the dimension is M3. I had a dozen of duck eagle/viper in various versions and various colors. I bought more than a hundred of extra screws according to this dimension and they fit well. Since I found the bolt holes of M3 5mm screws coming along the kits are not very well fit to my screw driver, I usually use these extra screws for assembling.
It's common for a kit to have the same diameter on all screw holes for one part of the construction. If you design a kit or manufacture it, you will realize it's unnecessary complicated, and silly to use different diameters for screw holes in this situation. So it's impractical to have both M3 and M2.5 in this viper/eagle case.
« Last Edit: Tue, 25 August 2020, 23:55:01 by jiezhou »
« Reply #410 on: Wed, 26 August 2020, 23:11:22 »
Got around to building everything. Tealios v2 lubed with 3204 on plastic plate. Sounds and feels great
Offline clasicks
  • Formerly KeyboardUser4
« Reply #411 on: Fri, 28 August 2020, 05:52:36 »
Mines stuck in NY hope it had the right address pray
Offline KingOfMemes
« Reply #412 on: Fri, 28 August 2020, 08:24:00 »
****'s about to get lit tomorrow
Offline KingOfMemes
« Reply #413 on: Fri, 28 August 2020, 14:16:49 »
Nvm, USPS coming in clutch a day early
« Reply #414 on: Fri, 28 August 2020, 23:18:51 »
Anyone got a half plate they are willing to trade for an alu full plate?
Offline MyManMart
« Reply #415 on: Sat, 29 August 2020, 16:59:11 »
For anyone that's ported to VIA do you know if the indicator LEDs are still supported? Love them and would prefer to keep them working.
Offline amirhosein
« Reply #416 on: Sat, 29 August 2020, 17:01:10 »
Yes they work perfectly fine.
Offline KingOfMemes
« Reply #417 on: Sun, 30 August 2020, 13:18:40 »
Does anyone know what the defaults are for the status indicator LEDs at the top? I caps lock is the second position from left to right, but I don't know what the other ones represent.
Offline amirhosein
« Reply #418 on: Sun, 30 August 2020, 13:19:32 »
I think it's the 3 locks, power and then all of the rest are layers.
Offline gfreeman11898
« Reply #419 on: Sun, 30 August 2020, 14:13:37 »
Looking to trade a steel half-plate for a steel full-plate.
Offline MMKB
« Reply #420 on: Sun, 30 August 2020, 15:13:40 »
Just finish building the Viper with a plastic full plate, retooled MX Blacks, 50g springs and lubed with 3204. Sounds really great with minimal case echo. The anodization turned out a little coarse but still very consistent. PCB is easy to program via QMK -- I used the key map file for the V2 PCB just fine. The bottom case does expose some cutouts for the screws so it isn't as seamless as it could be but I can live with that.
Quite happy about the Viper and the GB overall. Zero delay despite COVID. Thanks Elton for organizing the GB!
Offline clasicks
« Reply #421 on: Sat, 05 September 2020, 06:51:22 »
Looks awesome!
My red one arrived, gotta unbox it sometime :P
« Reply #422 on: Thu, 29 October 2020, 11:31:53 »
Does anyone have the plates files for this? Specifically the half plate file.
Offline cfox21
« Reply #423 on: Fri, 13 November 2020, 09:44:00 »
Is there anyway to get replacement PCB's?
Offline Visionaire
« Reply #424 on: Fri, 13 November 2020, 09:53:33 »
Snow is doing an international GB for his PCBs right now.
https://discord.gg/h6XaF5e3jZ
« Reply #425 on: Fri, 13 November 2020, 10:23:45 »
Sweet, btw does anyone happen to have plate files for this?
Offline Phanboy
« Reply #426 on: Tue, 23 February 2021, 22:46:10 »
Would it be possible to receive replacement diffusers at this point? I've sold my viper and have just been made aware that the diffusers are of different thickness and are also made of different materials https://imgur.com/a/Qcryh95
« Last Edit: Wed, 24 February 2021, 03:39:09 by Phanboy »
