Author Topic: Your own secret for a quieter keyboard  (Read 5761 times)
Offline chanmin kang
« on: Tue, 11 February 2020, 23:05:49 »
I prefer a quiet keyboard.
I want to know a lot of efforts you know to try to suppress all the sounds on the keyboard as much as possible.
Are there any better ways besides using a cherry silent red switch or filling the inside with a sponge? Please share!
« Last Edit: Tue, 11 February 2020, 23:09:35 by chanmin kang »
Offline nmur
  • ಠ_ಠ
Re: Your own secret for a quieter keyboard
« Reply #1 on: Tue, 11 February 2020, 23:27:55 »
put board on a deskmat, if not already
Offline yuppie
« Reply #2 on: Tue, 11 February 2020, 23:53:05 »
Silent Cherry switches are the first step. Swapping the springs and housings and then lubing can get you to another level.
The band-aid mod on your stabs really helps too.
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
« Reply #3 on: Wed, 12 February 2020, 00:56:13 »
I think uniform lubrication is key. It is a bit difficult to make all the switches completely uniform.
Offline fanpeople
« Reply #4 on: Wed, 12 February 2020, 00:56:59 »
Put deskmat on desk prior to putting board on deskmat for optimal ergonomics.
Offline mode
« Reply #5 on: Wed, 12 February 2020, 01:06:59 »
SA or other mega thick keycaps, the bassier sound just doesn't travel like thin caps do, it's also really pleasing.
I used to use an AEK with original caps at work, recently switched to SA and there're significantly less antisocial.
Offline bananasplit_00
« Reply #6 on: Wed, 12 February 2020, 01:14:19 »
One of those THICC deskmats, not the cheap thin stuff. Zilent or Tacit switches, or at least lube the springs. Pick a softer plater material too.
*edit*
Oh and lubed and clipped stabs, makes a huge difference
« Last Edit: Wed, 12 February 2020, 03:52:04 by bananasplit_00 »
Offline audiosl4ve
  • Just slave
« Reply #7 on: Wed, 12 February 2020, 01:19:42 »
not mine but use costar stabilizers. So much more silent then regular ones
Offline Maledicted
« Reply #8 on: Wed, 12 February 2020, 08:58:58 »
Put on some metal with a decent surround system, and crank the volume. You won't hear a thing. Works even with unmodified Model F keyboards.  :thumb:
Offline BlissOnTap
« Reply #9 on: Wed, 12 February 2020, 10:02:47 »
I like the way you think https://gfycat.com/warpeddescriptiveflatcoatretriever
Offline zslane
« Reply #10 on: Wed, 12 February 2020, 11:49:03 »
  • Start with a Topre board.
  • Add silencing rings to the sliders.
  • Lube the stabilizers.
  • Install thick, high-quality keycaps.
  • Add a thin sheet of sorbothane inside the case, on the bottom.
  • Place on a soft desk mat.
Offline Maledicted
« Reply #11 on: Wed, 12 February 2020, 16:28:53 »
Thank you. That video is perfect, lol. What the hell?
Offline Sup
« Reply #12 on: Wed, 12 February 2020, 16:43:51 »
Yeah pretty much first step is to use silent switches if you don't want a loud keyboard. There is no really other option if you want a real quit keyboard since switches just make sound when the plastics clack with each other. Dampening mat and lube will make it less loud but won't make it classified to be a silent keyboard like a rubber dome or topre. Still loud enough for your co workers to bash your head in or love it as asmr on of those   :D
current
Coming soon
« Reply #13 on: Wed, 12 February 2020, 21:22:47 »
Unfortunately the coster is not well compatible. It is a pity
Offline nathanchere
« Reply #14 on: Thu, 13 February 2020, 04:15:43 »
Put deskmats both under and on top of the board for optimal silencing.
Offline wholypantalones
  • text and icon mods plz.
« Reply #15 on: Thu, 13 February 2020, 06:48:18 »
Use headphones while typing or jam some ear plugs in your holes.
Offline fanpeople
« Reply #16 on: Thu, 13 February 2020, 06:57:14 »
Instructions not clear, earplug now in pee pee hole.
Offline nathanchere
« Reply #17 on: Thu, 13 February 2020, 07:11:56 »
No, instructions were perfectly clear. You nailed it.
Offline 4sStylZ
« Reply #18 on: Thu, 13 February 2020, 08:03:28 »
I have a keyboard with jailhoused blue. First my clicky switchs become tactiles only but also the JL spacer dampen the downstroke and probably a little bit the upstroke.
On a wood case with a single one very large rubber keyboard foot I don’t need more silence. My keyboard is more quiet than chicklet keyboard or common membrane boards.
Bépo user here : AEK64 White linear dampened, XD75 Cherry Blue Jailhoused, TypeMatrix2030 black skin, Lenovo 0B47200 w/ trackpoint, G13, G512. Kensington Expert Trackball & Orbit, Magic touchpad 2.
« Reply #19 on: Thu, 13 February 2020, 08:36:07 »
You picked a hole and went for it, instructions followed perfectly.
« Reply #20 on: Thu, 13 February 2020, 09:07:16 »
Filling voids in the case can be a help. I use felt fabric or rubber "waffle" material such as sold for drawer liners. Wherever possible I cut flat layers to fit, then for taller cavities I cut rectangles of fabric which I roll into cylinders to fit each hollow as closely as possible. These will compress, of course, so you can get nearly complete fill if you try.
A mat under the keyboard is essential. The best but most expensive and difficult to get is sorbothane, the cheapest and easiest is a folded towel.
- D Trump 2026-09-28
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #21 on: Sun, 16 February 2020, 20:59:45 »
Uniqey QMX clips can significantly reduce sound, but they also shorten key travel and add a mushy/soft bottom-out feel that you might dislike. It's still better than the old o-ring method.
