Author Topic: Identify me #2 - Treasure from the attic  (Read 9692 times)
Offline jensma
    • http://jensma.de/
« on: Fri, 25 June 2010, 05:58:14 »
Dang!
I searched the attic for some stuff and stumbled upon two keyboards of me ex-roommate. I have no idea what brand the first one is. Here are some pics of the cleaning process:
First, I popped it open. Literally, there weren't any screws.
Crumble-tastic!
The numlock, roll and capslock have integrated LEDs - nice! And yay, a spring!
Circuit board on the back. The IC reads Intel.
Sticker on the backside.
Decrumbled....
... and put together with every key cleaned seperatly.
The typing is very smooth and very quiet. Feels nice =)
Next one:
Obviously a Commodore.
No doubt - a Commodore ;D
... for Windows. Din AT-Jack. (What a crumbly mess, btw)
Unfortunatly, the Commodore is strongly yellowed.
That's all - have fun identifying the first one!
Offline sixty
    • http://deskthority.net
« Reply #1 on: Fri, 25 June 2010, 06:06:14 »
First one is a Fujitsu Peerless. There is only one thing to do with these switches. Burn it with fire, as soon as possible.
Offline jensma
    • http://jensma.de/
« Reply #2 on: Fri, 25 June 2010, 06:08:45 »
Quote from: sixty;196210
rofl, why that? I'm going to give it to a friend =D
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #3 on: Fri, 25 June 2010, 10:21:44 »
Quote from: jensma;196211
Won't be a friend for long...
BTW the second one looks like a rebadged BTC. Oughta be foil+foam capacitive, practically linear feel, and absolutely awful.
kishy.ca
Offline jensma
    • http://jensma.de/
« Reply #4 on: Fri, 25 June 2010, 10:29:02 »
Quote from: kishy;196269
I'm cleaning it right now - it has dome switches :|
It'll be at ebay this evening ;)
Offline spolia optima
« Reply #5 on: Fri, 25 June 2010, 12:23:24 »
It's a peerless.
I recommend 2 microdots of good acid and Pink Floyd's seminal classic "Piper at the Gates of Dawn" If you want to appreciate this magnificent keyboard.
keyboards!
Offline TexasFlood
« Reply #6 on: Fri, 25 June 2010, 15:49:40 »
Maybe a BTC 5140?
Offline ch_123
« Reply #7 on: Fri, 25 June 2010, 15:54:12 »
Those Peerless sliders remind me of the ones used in the Sun Type 5, except I'm pretty sure the Type 5 was just rubber domes.
« Reply #8 on: Fri, 25 June 2010, 17:29:01 »
Quote from: ch_123;196377
close, but no cigar.
the type 5 is pretty solid, I'd use one over a peerless anyday.
keyboards!
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #9 on: Fri, 25 June 2010, 17:29:43 »
Quote from: TexasFlood;196376
Maybe a BTC 5140?
That's what I was thinking. I've parted ways with one in the same housing with same odd-sized Esc key recently. That one wasn't domes though.
kishy.ca
Offline TexasFlood
« Reply #10 on: Fri, 25 June 2010, 18:18:15 »
Maybe a BTC 5140?
Quote from: kishy;196400
Yup, per the number on the label, it's a BTC 5140.
Offline gr1m
« Reply #11 on: Fri, 25 June 2010, 19:06:31 »
Inhaling dried mouse droppings can kill you.
Offline trievalot
« Reply #12 on: Fri, 25 June 2010, 19:08:45 »
Quote from: gr1m;196468
ill take the mouse droppings over your avatar in a dark alley anyday
[SIGPIC]
Offline gr1m
« Reply #13 on: Fri, 25 June 2010, 19:11:15 »
I only mentioned it because he's digging up very dirty items from an attic, and chances are some of the "crumbs" actually are dried mouse droppings.
As for my avatar... yes, I would take the mouse droppings too. This isn't just a normal bunchie. It's the custom Troll-face gr1m Edition bunchie.
Offline TexasFlood
« Reply #14 on: Fri, 25 June 2010, 19:11:43 »
True, there is at least Hanta Virus, not sure what else.  Even if there wasn't, you might die from the willies.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #15 on: Fri, 25 June 2010, 19:46:57 »
Only if you inhale so much mouse crap that if chokes you.
Offline gr1m
« Reply #16 on: Fri, 25 June 2010, 20:17:37 »
Quote from: microsoft windows;196500
I knew you were a troll but I didn't know you were full-blown stupid.
http://en.wikipedia.org/wiki/Hantavirus
Offline Oqsy
« Reply #17 on: Fri, 25 June 2010, 21:00:52 »
Inhaling the feces is different than inhaling the microbes sustained by the feces.  MS Win is not full-blown stupid, but your phrasing was.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline gr1m
« Reply #18 on: Fri, 25 June 2010, 21:10:26 »
I said inhaling mouse droppings can kill you. And the truth is, they can if they contain Hanta virus. My phrasing was fine?
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #19 on: Fri, 25 June 2010, 21:28:19 »
Quote from: gr1m;196525
Your phrasing is correct, but at the same time the air in a room containing (a large amount of) rodent feces is the same if not worse (because you can't see the threat).
kishy.ca
Offline Oqsy
« Reply #20 on: Fri, 25 June 2010, 22:24:49 »
I didn't say you were incorrect, just that your phrasing was full-blown stupid.
It's very doubtful that jensma is going to be inhaling mouse turds.  The particulates that are airborne and containing the virii are what you are most likely referring to.  While your statement was not incorrect, your phrasing WAS problematic because it did not CONVEY the message you intended.  Your phrasing made more than one person here imagine jensma sucking entire mouse turds by the mouthful to the point that it killed him.
It's not the mouse poop that kills, it's the virus.  It would be VERY difficult for the mouse poop itself to be the cause of death.  Aspiration or asphyxiation COULD do it, but it would take a lot of mouse poo or some really bad luck.
Now do you understand that MS Win was not trolling, and neither was I?  While it is helpful to point out the risks and dangers of dealing with rodent feces, it seemed as much like a trolling statement to the rest of us as any I've seen, especially considering the way it was worded.
Also, jensma is in Germany, and it appears the carrier of the variants of hanta in Deutschland are voles encountered by farmers, it is not that likely that any feces that MIGHT have been encountered (we still don't even know if there was any to begin with) would be infected with hanta.
« Last Edit: Fri, 25 June 2010, 22:27:16 by Oqsy »
Offline gr1m
« Reply #21 on: Fri, 25 June 2010, 23:27:37 »
I said inhaling DRIED mouse droppings. When it dries, it can crumble and the particles can be inhaled just like normal dust. It is most likely these dried, crumbled mouse-poop particles that contain the Hanta virus.
You're nit-picking to an excess. I did not accuse you of trolling, nor did I accuse you of saying that I was incorrect. However, I am sure my statement managed to convey exactly what I meant. Mouse poop containing Hanta virus can dry, disintegrate and be inhaled, killing the recipient.
Still, the story of the store clerk cleaning the stockroom and contracting a hantavirus is not preposterous. In fact, a scenario on the Centers for Disease Control and Prevention (CDC) website sounds similar, involving someone cleaning out a seldom used, rodent infested area, and contracting the virus after breathing in dust particles from the dried rat droppings. The excretions of diseased rats can indeed pose a health threat to humans (see resources below for cautionary information).
http://urbanlegends.about.com/library/blrats2.htm
« Last Edit: Fri, 25 June 2010, 23:29:50 by gr1m »
Offline jensma
    • http://jensma.de/
« Reply #22 on: Sat, 26 June 2010, 05:26:48 »
I inhaled the mouse droppings right after I munched dried rat turds.
Got a sick feeling now.
... just kidding, I'm fine.
Offline ch_123
« Reply #23 on: Sat, 26 June 2010, 06:03:28 »
How common is the Hanta virus?
Offline jensma
    • http://jensma.de/
« Reply #24 on: Sat, 26 June 2010, 06:33:12 »
Quote from: ch_123;196627
I never heard of it before :D
Offline ch_123
« Reply #25 on: Sat, 26 June 2010, 06:39:01 »
I have, but really only from American sources. I wonder how common it is elsewhere.
Offline Rajagra
« Reply #26 on: Sat, 26 June 2010, 10:14:18 »
The risk to a mouse when inhaling human droppings is far greater.
We win. Take that, puny rodents!
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #27 on: Sat, 26 June 2010, 10:24:21 »
Hantavirus has been found in Alberta, I remember reading recently. Originally, it was mostly found in the Four Corners area of the western United States.
Offline Oqsy
« Reply #28 on: Sat, 26 June 2010, 15:06:31 »
There are several strains of hanta virus, and not all are fatal, and not all are found in all places with rodents.  In the US there are roughly 40-60 cases of hanta in each of the four corners states per year.  That means four states out of 50, each with less than 100 confirmed cases.  On the whole, it's a VERY UNCOMMON virus in human populations in the US.  Let's go with the high end of the average for those states...
4 states x 60 annual cases = 240 cases total
307,000,000 people in the US / 240 cases/yr = 1 case per 1.28 million people
The chances are below one in a million that you'd contract Hanta in the U.S. in any given year.
Other nations have other strains with different characteristics, with far too many details to get into here.  Some are even able to be spread from human to human, but many of these do not have the fatal outcomes typically associated with Hanta.
Nice peerless.  I found an old style peerless at work a while back, and the backlash against peerless on this site was enough to make me pretend it never happened.  I left the board there and never looked back.
Offline jensma
    • http://jensma.de/
« Reply #29 on: Sat, 26 June 2010, 18:08:38 »
Quote from: ripster;196717
Yet another post turning into an advertisement for NIB keyboards.
Let's prevent it.
This thread is now about bananas:
Offline TexasFlood
« Reply #30 on: Sat, 26 June 2010, 18:21:55 »
Quote from: jensma;196762
Let's prevent it.
In a keyboard forum?
« Reply #31 on: Mon, 28 June 2010, 04:18:18 »
I really love how a thread about the fujitsu peerless was segued into a thread about hantavirus.
keyboards!
Offline Mental Hobbit
« Reply #32 on: Mon, 28 June 2010, 08:17:45 »
Haven't tried Hanta yet, but I doubt the Peerless is that terrible.
Typing on blues.
Offline TexasFlood
« Reply #33 on: Mon, 28 June 2010, 09:11:55 »
Quote from: spolia optima;197094
And bananas.
Ba-NA-na.
A yellow fruit. Also, a kind of pudding. A delicious pudding.
Anna Banana would like to hear "Venus" by Bananarama. Banana!
B-A-N-A-N-A. Banana.
When I go to Albertson's, I need to buy some Mitchum Ice Blast... and bananas.
Offline Oqsy
« Reply #34 on: Mon, 28 June 2010, 10:01:21 »
"The circle is now complete."
« Reply #35 on: Mon, 28 June 2010, 13:35:05 »
Quote from: TexasFlood;197146
And bananas.
Ba-NA-na.
Did you know that bananas are actually berries? Crazy huh.
The original American banana, the ones that your parents put in their cereal, was called the gros michel (big mike). It was longer, girthier, and far more delicious than the little chinese cavendish that we eat today. Unfortunately, the gros michel was wiped out by Sigatoga virus in the 50's, what a shame.
keyboards!
Offline jensma
    • http://jensma.de/
« Reply #36 on: Mon, 28 June 2010, 15:58:00 »
Quote from: spolia optima;197274
My parents did what?
Offline itlnstln
« Reply #37 on: Mon, 28 June 2010, 16:02:27 »
It was longer, girthier, and far more delicious than... that we eat today.
That's what she said.
Offline Oqsy
« Reply #38 on: Mon, 28 June 2010, 17:40:53 »
I like fruit with girth.
