Author Topic: [GB] KAT Space Cadet - Delivering to US customers  (Read 305220 times)
Offline Matt68
Re: [GB] KAT Space Cadet - April 2020
« Reply #100 on: Mon, 27 April 2020, 04:45:16 »
<> and *µ keys from french kit should be blue like the mod keys because they occupy the spot of a mod key, if they are grey, the blue triangles formed by the mod keys wont be triangles anymore, with some grey keys in the middle, it would be ugly
the problem for the backspace key is that it has to be 2u in french layouts, even the most compact one, so you have to buy the 60 mods kits even for small builds
Offline eskimojo
    • KeycapLendar
« Reply #101 on: Mon, 27 April 2020, 07:07:25 »
Exactly 0 ISO layouts have done this.
Very confused about what about French makes it any different in backspace size to any other national layout - additionally, how many "small builds" provide support for the apparently compulsory 2u backspace?
Not to mention that it's not actually possible to add a 2u backspace to the kit, as the set is already in GB and thus quotes are final.
Offline Matt68
« Reply #102 on: Mon, 27 April 2020, 11:41:53 »
If you keep those keys grey, a french build would look like this :
It totally f*cks up the blue diagonal pattern and looks awful. And they did it for the ² key which is a character key sitting in a mod spot too, so why not for the <> and the *µ which are also in mods spots ?
And because of the ISO enter key, the backspace has to sit on the top row, and on the french layout there is only 2 special characters keys after the 0 key, so you usually put a 2u backspace (where the | \ and the hand keys are on the picture above)
« Last Edit: Mon, 27 April 2020, 11:45:49 by Matt68 »
Offline tominabox1
« Reply #103 on: Mon, 27 April 2020, 11:52:49 »
Thanks for the suggestion but we will not be changing the colors of the ISO kits in the manner you are suggesting. The row 5 2u backspace is the one included in the 60s+ kit already.
Offline Fredington
    • Instagram
« Reply #104 on: Mon, 27 April 2020, 13:15:02 »
That's how ISO keyboards are and have always been:
« Last Edit: Mon, 27 April 2020, 13:17:45 by Fredington »
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #105 on: Mon, 27 April 2020, 14:17:16 »
Going all the way back to the IBM Model M
Offline dvorcol
« Reply #106 on: Mon, 27 April 2020, 15:06:17 »
MOQ has been met.  All kits will be made!
<-- progress
« Last Edit: Thu, 30 April 2020, 18:43:50 by dvorcol »
Offline tominabox1
« Reply #107 on: Mon, 27 April 2020, 15:09:29 »
Folks if you have not yet, Go check out the deskpads/deskmats/giant mouse pads at mkultra.click!!
Just a few more days to get your orders in so don't hesitate! (Desk pads will be available for order through May)
« Last Edit: Mon, 27 April 2020, 15:31:27 by tominabox1 »
Offline fugounashi
Convex caps?
« Reply #108 on: Mon, 27 April 2020, 17:07:43 »
Which caps in which sets are convex? I'm looking for 1u and 1.5u convex thumb keys in particular. Thanks!
Offline tominabox1
« Reply #109 on: Mon, 27 April 2020, 17:09:18 »
The ortho mods have what you are looking for!
Offline hrolf
« Reply #110 on: Mon, 27 April 2020, 17:12:06 »
I'm new to the custom keycaps scene but i'm an emacs junkie of many years and very much want to get in on this.
I have an Ergodox EZ that I bought premade from https://ergodox-ez.com/ .
Do i understand it correctly that I should order ONLY the "Ergo Legends" set? Or are more keys required? I've found it pretty challenging to figure out what combinations of which sets I'd need, and would love some guidance.
Offline tominabox1
« Reply #111 on: Mon, 27 April 2020, 17:13:34 »
You need an alpha kit:Grey, blue, or mono legends, and the Ergo legend or Blank set
so one alpha set, and one mod set!
Offline hrolf
« Reply #112 on: Mon, 27 April 2020, 17:20:11 »
Perfect.  And when mkultra says "do not add other items to cart" it means that exactly those two sets should constitute my order and nothing else, right? (this is extremely helpful, thank you)
Offline FearsomeCubedWarrior
  •  Post Reporting Timeout
« Reply #113 on: Tue, 28 April 2020, 01:50:37 »
« Last Edit: Mon, 15 April 2024, 20:59:16 by FearsomeCubedWarrior »
Offline harlekein
« Reply #114 on: Tue, 28 April 2020, 03:57:48 »
Will there be extras after GB fulfillment?
Most likely, but you will have to be very lucky to get your hands on them before they sell out and/or you will pay more than what you would be paying now. The GB is still live, so if you are interested, it's better to get in on it now.
If you change your mind later, I'm sure you can always sell your kits on /r/mm.
Offline tominabox1
« Reply #115 on: Tue, 28 April 2020, 07:46:49 »
Correct
Offline hrolf
« Reply #116 on: Tue, 28 April 2020, 08:04:03 »
Correct
excellent. i went a little wild, so maybe i’ll have some spares to put on the atreus i also preordered...
thanks for the help again!
Offline fugounashi
« Reply #117 on: Tue, 28 April 2020, 18:13:28 »
Which caps in that set are convex?  How about other sets such as spacebars?  I can't tell from the pictures and I can't find any info about it in this thread.
Offline dvorcol
Re: [GB] KAT Space Cadet - April 2020 EXTENDED to May 9
« Reply #118 on: Wed, 29 April 2020, 16:49:05 »
<-- progress
« Last Edit: Fri, 01 May 2020, 17:00:26 by dvorcol »
Offline tominabox1
« Reply #119 on: Wed, 29 April 2020, 20:14:57 »
All of the gray space keys are convex Except for 1.75u.
Offline heliar_mk
« Reply #120 on: Thu, 30 April 2020, 05:51:22 »
Will all kits be made?
Offline tominabox1
« Reply #121 on: Thu, 30 April 2020, 06:30:17 »
« Reply #122 on: Thu, 30 April 2020, 06:55:53 »
« Last Edit: Mon, 15 April 2024, 20:59:44 by FearsomeCubedWarrior »
Offline dvorcol
« Reply #123 on: Thu, 30 April 2020, 18:40:14 »
There are no individual kit MOQs for KAT & KAM group buys.  Instead, the MOQ is the total number of keycap units sold.  A standard alpha counts as 1u, a standard RETURN is 2.25u, a standard spacebar is 6.25u, etc.  KAT Space Cadet's MOQ is 54,000 units, and as of 29 April 72,200 units have been sold.  MOQ has been met, so all kits will be made.
Offline fugounashi
« Reply #124 on: Fri, 01 May 2020, 01:23:44 »
I'm sorry but I still don't understand.  Can you please state clearly exactly which caps in which sets are convex?  Thanks.
Offline tominabox1
« Reply #125 on: Fri, 01 May 2020, 06:00:52 »
All Space Bars Are Convex Except 1.75u
Offline eskimojo
    • KeycapLendar
« Reply #126 on: Fri, 01 May 2020, 08:29:42 »
For future reference, it's pretty common to mark convex keys with a "c".
It also doesn't help that the flatlays use concave tops.
Offline dvorcol
« Reply #127 on: Fri, 01 May 2020, 16:59:50 »
<-- progress
« Last Edit: Wed, 06 May 2020, 17:16:38 by dvorcol »
Offline Joaquox
« Reply #128 on: Sat, 02 May 2020, 07:12:57 »
I have a question, not intended as criticism at all, how did the novelties and up almost the same price as alphas? Is it more expensive to dye somehow?
Offline eskimojo
    • KeycapLendar
« Reply #129 on: Sat, 02 May 2020, 07:24:42 »
The alpha kit is 54 units (51*1u + 2*1.5u), and the novelties are 52.5 units (26*1u + 6*1.25u + 6*1.5u + 2*1.75u + 1*2u + 2*2.25u). This means that the kits will likely use a similar amount of plastic to make.
Offline Joaquox
« Reply #130 on: Sat, 02 May 2020, 07:41:19 »
Makes sense, it looked smaller but I didn't bother to actually count the u's. Thanks!
And I'm in for weirdo alphas, ortho and novelties kit  :D
Offline umberts
« Reply #131 on: Sat, 02 May 2020, 09:03:09 »
Entered the group buy at the last moment with Grey Alphas, 60+ Mods and Yellow Accent!
First GB, is it the start of the slippery slope?
Offline tominabox1
« Reply #132 on: Sat, 02 May 2020, 09:21:34 »
 ;D For sure is! Thanks for joining in, I hope we can make it smooth as ever for you and everyone else.  Few more days to go guys!
Offline Yilk81
« Reply #133 on: Mon, 04 May 2020, 05:47:38 »
What's the discord server for this GB? I'm trying to find someone who might be willing to let go of two 1u keys from the yellow accent kit. I'm a discord newbie, excuse my ignorance.
Offline fugounashi
« Reply #134 on: Mon, 04 May 2020, 07:05:34 »
Do you mean the spacebars kit? Wouldn't everything in that kit be convex, otherwise it would just be a blank not a spacebar? Also, do you mean the only convex caps in this set are in the spacebars kit? How about the ortho mods kit you mentioned earlier? Or do you mean all the grey blanks in every kit except 1.75u?
« Last Edit: Mon, 04 May 2020, 07:11:07 by fugounashi »
Offline tominabox1
« Reply #135 on: Mon, 04 May 2020, 08:04:05 »
Every space bar in every kit is convex except 1.75u which they have no convex mold for. I'm sorry I don't know how to be any more clear.
Offline wil
« Reply #136 on: Mon, 04 May 2020, 09:32:46 »
you are being perfectly clear, and i'm thankful for your clarification. i am happy to see 1.5u and 1u convex in the ortho kit. cheers, can't wait to get this!
Offline dennismdc
« Reply #137 on: Tue, 05 May 2020, 08:57:28 »
Hi everyone. This will be my first time to order a keycap in a group buy.
Would a set of gray alphas, 60s mods, and a numpad cover my 96 keyboard layout?
« Last Edit: Tue, 05 May 2020, 09:18:52 by dennismdc »
Offline clik_clak
« Reply #138 on: Tue, 05 May 2020, 09:25:59 »
As long as you went with a standard build on the 96, it should cover everything just fine.
Offline fugounashi
« Reply #139 on: Tue, 05 May 2020, 19:04:03 »
Thanks.  So that means, for convex caps up to 2u, they are:
40s Mods: Grey 1x2u.
Ortho Mods: Grey 2x2u, 2x1.5u, 2x1u. Blue 2x1u.
Spacebars: Grey 1x2u, 1x1.25, 2x1u. Blue 1x2u, 1x1.25, 2x1u.
Accents: Yellow 1x2u.
Ergo Blanks / Legends: Grey 2x2u. Blue 2x2u.
None of the printed blue r1 1u with legends in Ortho Mods are convex.
If I want 2x1.5u and 4x1u, say for a crkbd, I could get the the Ortho Mods and have grey 2x1.5u, 2x1u and blue 2x1u, but if I want >4x1u I can't get that from one kit.
Offline Djmm
« Reply #140 on: Tue, 05 May 2020, 19:13:38 »
Just want to double check before the GB closes, to fill TKL such as Rama U-80 I just need to pick the base + alpha right?
Offline IOVERCALLHISTIOCYTES
« Reply #141 on: Tue, 05 May 2020, 19:30:13 »
Yes.
Offline dvorcol
« Reply #142 on: Wed, 06 May 2020, 17:15:53 »
<-- progress
« Last Edit: Mon, 01 June 2020, 18:33:28 by dvorcol »
Re: [GB] KAT Space Cadet - April 2020 EXTENDED to May 9 MOQ MET
« Reply #143 on: Sat, 09 May 2020, 11:56:42 »
« Last Edit: Mon, 15 April 2024, 21:00:11 by FearsomeCubedWarrior »
Offline tominabox1
Re: [GB] KAT Space Cadet - April 2020 - CLOSED
« Reply #144 on: Sun, 10 May 2020, 06:47:54 »
And we're closed! Thank you for all the support! We'll keep you posted as things continue and get dvorcol the last numbers soon.
Offline rockydbull
« Reply #145 on: Thu, 28 May 2020, 09:18:06 »
Well boys I dun messed up. I got blue alphas and didnt realize that there is no blue spacebar in the mods kit. Would have needed to get the spacebar kit...
Thoughts on all blue with a grey spacebar?
Offline r4bbl3d4bbl3
« Reply #146 on: Thu, 28 May 2020, 15:12:32 »
Oof, I did the same, I was looking for a total blue setup...
Offline rockydbull
« Reply #147 on: Thu, 28 May 2020, 20:31:26 »
I brought my big brain move to the 40s discord and they said there will be extras so fingers crossed!
Offline octol
« Reply #148 on: Mon, 01 June 2020, 02:15:40 »
Oh no I did the same as well, missing the blue spacebar :(
Offline dvorcol
« Reply #149 on: Mon, 01 June 2020, 18:32:54 »
Edit: added prices
« Last Edit: Fri, 02 May 2025, 02:46:26 by dvorcol »
