Author Topic: [IC] Kavier FR4 Lube Station ($10!)  (Read 6200 times)
Offline .
« on: Wed, 01 April 2020, 03:52:36 »
Hey everyone, back again with another interest check!
My main problem with lubing is holding the bottom housings somewhere, but Qlaviers lube stations are super duper expen$ive! :(
That's why I thought of putting the bottom housings in a layer of FR4 that is milled specifically for this purpose. I call it the:
Kavier
The Kavier is the perfect lube station for lubing switches. It's made of high grade FR4. FR4 is very flexible, strong and lightweight and used in industrial applications.
Of course this lube station will be very cheap at just $10! It can hold up to 73 switches at a time as well,
making it perfect for lube jobs for up to 65% layouts which are the most common in this community.
They will be availabe in white.
I have done extensive testing to make sure that it can be used for any kind of switch without problems, which means some holes are smaller than normal while others are a bit larger.
Features
  • Fits in any standard 60% tray mount case
  • Holds up to 73 switches
  • Milled out of strong, high grade FR4 material
  • Super affordable at $10
Vendors
EU: maartenwut.com
US and rest: TBD
« Last Edit: Wed, 01 April 2020, 03:55:57 by . »
Offline fleeceman
Re: [IC] Kavier FR4 Lube Station ($10!)
« Reply #1 on: Wed, 01 April 2020, 04:03:47 »
Can't tell if April fools or not..
Sent from my Pixel 3a XL using Tapatalk
Offline bard
« Reply #2 on: Wed, 01 April 2020, 04:04:28 »
fine for me!  ;D
Offline .
« Reply #3 on: Wed, 01 April 2020, 05:24:40 »
Today is april fools day but this is no joke!
Offline Jaltr
« Reply #4 on: Wed, 01 April 2020, 09:52:32 »
If it's not a joke, I'm down.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #5 on: Wed, 01 April 2020, 13:24:01 »
nice klippe
Offline .
« Reply #6 on: Wed, 01 April 2020, 13:26:24 »
nice klippe
I did that board design in 10 minutes and my hourly wage is $1000 so it'll cost 300 usd in gb.
Offline nasp
« Reply #7 on: Wed, 01 April 2020, 13:50:56 »
Sure, but which part holds the stems?! How am I gonna use my special stem grabber without a place to put me stems?
Offline .
« Reply #8 on: Wed, 01 April 2020, 13:53:01 »
You're gonna have to get some bowl to put your stems in
Offline hkiri
« Reply #9 on: Wed, 01 April 2020, 13:54:53 »
Will the bowl be part of the GB?
Offline .
« Reply #10 on: Wed, 01 April 2020, 15:35:09 »
I can have a bowl manufactured by the guys who manufactured the keycults for $1000
Offline saesh
« Reply #11 on: Fri, 03 April 2020, 07:30:46 »
At $10 this is a no brainer. Thanks for making this!
