Author Topic: Keyboard for stepmania?  (Read 8880 times)
Offline Izlude77714
« on: Sun, 27 June 2010, 00:47:04 »
http://www.amazon.com/Logitech-Illuminated-Ultrathin-Keyboard-Backlighting/dp/B001F51G16
"KEYBLOCKING
I want to mention also that I have not had any issues with the phantom key blocking that a reviewer mentioned and demonstrated by video. Which is not to say that the key blocking does not exist. But from what I understand, nearly all modern keyboards use phantom key blocking as a feature to prevent phantom input. And yes, there is a drawback when certain key combinations are pressed, you must lift one of the depressed keys in order for the next key to register. I type between 70-85WPM on average. Maybe I'm not a fast enough typist but I tried typing the problem combinations as fast as I possibly could and did not once register a problem. I read a few professional reviews online and did not see a mention at all of key blocking being different on this keyboard compared to others. I used keyscan and can verify that the blocking combinations that the other reviewer found do exist but they did not cause any errors for me. I can't see this being an issue for a majority of users personally. I wrote this entire review with it and I intend to keep it."
I heard this uses the same system as the danivo (so that would not help either)
afew years back I got the fatal1ty keyboard and that would only register 2 arrows at the same time making it impossible to play stepmania with
so basically is there a keyboard with scissor keys that would allow me to hit triples/quads on stepmania and NOT limit my keystrokes?
thanks
Offline Phaedrus2129
« Reply #1 on: Sun, 27 June 2010, 00:53:27 »
Not scissor switches I think, but mechanical switches, yes. Any mechanical keyboard with NKRO can support any number of keys with no blocking.
What's your budget?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Izlude77714
« Reply #2 on: Sun, 27 June 2010, 06:26:44 »
Quote from: Phaedrus2129;196856
What's your budget?
how much of an advantage would you say something like that would have over the typical keyboard in terms of speed?
if I can find what I want then I am willing to spend quite a bit
price does not matter because I am willing to spend anything but obviously I would it to cost less
edit: please post several of them but the keys MUST be easy to press
also I really really would need a wired
« Last Edit: Sun, 27 June 2010, 08:42:07 by Izlude77714 »
Offline Izlude77714
« Reply #3 on: Sun, 27 June 2010, 09:34:59 »
XD lol
yeah I know all about that
http://www.youtube.com/watch?v=k1iq0iAJ1GM#t=2m54s
http://www.youtube.com/watch?v=5gZLpKhxK9w
I am talking about stepfiles of this difficulty though
do you think it could handle something like that? and do you have any other suggestions for scissor/mechanical keyboards? I want to see what my options are
but I want to 100% know that it does not have an issue with registering keys and can handle  4+ key presses at a time no problem
it took me ages to find a decent keyboard that can do this stuff but its time for a new one and I want to get something more expensive to replace it with but I want to know its an upgrade in performance
edit: cant get the stupid youtube function working to post vids sorry please just click link
« Last Edit: Sun, 27 June 2010, 09:50:22 by Izlude77714 »
Offline Izlude77714
« Reply #4 on: Sun, 27 June 2010, 10:27:23 »
alright I looked at it
if I am understanding it correctly than basically any of these will be my ideal keyboard?
Cherry (MX Brown) - 45g
Cherry Keyboard G80-3000LXCEU-2 (US with Euro symbol, Available for $97 at DataCal.)
Das Keyboard Model S Professional Silent (available for $135 direct)
DSI Modular Mac Keyboard KB-MODMAC-U-Non
Filco FKBN87M/EB ($121 at Elitekeyboards, also comes in 104 key)
iRocks KR-6230 (as low as $70 on Ebay)
Compaq MX 11800 (trackball) (Commonly available on Ebay)
Topre Capacitive Switch - varies from S model 30g to 45g (most keyboards) to 55g - see Topre Wiki
Happy Hacking Keyboard Pro 2 (note: the HHKB Lite is rubber dome) (Elitekeyboards for $254)
Realforce 87U (55g available for limited time at Elitekeyboards for $255, Variable 35/45/55g model available at GeekStuff4U for $327)
the lower the g the better right? so basically anything on that list thats 45g or less? or only stuff on the cherry brown list?
Cherry (MX Blue) - 50g
Filco FKBN87MC/EB tenkeyless (available from EliteKeyboards for $121)
Cherry Keyboard G80-3000LSCRC-2 (has US and Chinese Characters ) $66 at Gemini Computers SOMETIMES has in stock - sells quickly out
Das Keyboard Professional Model S (recommend you buy direct for 30 day guarantee - $129 direct) Note: Media Key version discontinued
Adesso MKB-135B (full size) and MKB-125B (compact layout but large Enter key) Provantage MKB-135b for $73, MKB-125B for $62 and other resellers stock.
DSI Modular Mac Keyboard KB-MODMAC-U-Click
iOne Scorpius M10
could I use any of those then basically and it would be an improvement? I just hate normal looking keyboards and want something more fancy or appealing to look at
« Last Edit: Sun, 27 June 2010, 10:40:25 by Izlude77714 »
Offline Henry
« Reply #5 on: Sun, 27 June 2010, 11:49:02 »
I gave away a G80-1800 with blacks to my brother who plays Stepmania a lot, and he is very happy of it despite the 2-kro and pretty poor matrix.
Offline Izlude77714
« Reply #6 on: Sun, 27 June 2010, 15:27:08 »
Quote from: Henry;196925
there is no way I could use something like that
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #7 on: Sun, 27 June 2010, 15:29:02 »
How about this:
http://www.youtube.com/watch?v=1PTI3E70ml4
Someone with a Déck Legend playing stepmania.
« Last Edit: Sun, 27 June 2010, 15:40:35 by JaccoW »
|||My other keyboards :
x
Offline AvengeR
« Reply #8 on: Sun, 27 June 2010, 16:09:33 »
SM players tend to use the logitech ultra x keyboard (i think it has another version but can't recall the name of it).
ofc you can play stepmania flawlessly with a 2kro kb. Almost all good players use ZX and ,. keys which do not have any blocking problems at any combo including all 4 at the same time, and most importantly you won't get tendinitis caused by using the arrow keys.
« Last Edit: Sun, 27 June 2010, 16:17:32 by AvengeR »
Offline Izlude77714
« Reply #9 on: Sun, 27 June 2010, 16:16:46 »
Quote from: AvengeR;196989
ofc you can play stepmania flawlessly with a 2kro kb. Almost all good players use ZX and ,. keys, and most importantly you won't get tendinitis caused by using the arrow keys.
2kro means it can only register 2 keys at a time right? if so they are not playing real files
and yeah playing with the normal arrow keys sucks
I use Q/W/8/6 on the num pad
Quote from: JaccoW;196985
How about this:
someone in the comments said it works for sm on that vid so that seems like a pretty good choice so far
still hoping to see what all my options are before I make a purchase though
I want to know what light up keyboards I have to choose from
thanks for all the help btw guys lol
« Last Edit: Sun, 27 June 2010, 16:23:33 by Izlude77714 »
Offline AvengeR
« Reply #10 on: Sun, 27 June 2010, 16:21:52 »
Quote from: Izlude77714;196990
nope. It means that the kb will register 2 keys at the worst combo possible (for example ASX), but at other combos it could go a lot more (easily 6+ considering modifiers)
more importantly than that concept my recommendation is that you should try that combo first, and if it has any problems then search for another kb.
Offline Izlude77714
« Reply #11 on: Sun, 27 June 2010, 16:28:13 »
Quote from: AvengeR;196992
what do you mean by "the worst combo possible"?
I dont know anything about keyboards so thats why I am asking for help here lol sorry :P
Offline AvengeR
« Reply #12 on: Sun, 27 June 2010, 16:36:28 »
Quote from: Izlude77714;196995
try ASX for example. Most probably the last key won't register, but if you try ZX,. at the same time it won't have any problems even if you press ZX,. ;  .,XZ ; etc combination. That's why I suggest you first try those keys (or others) before searching for another kb.
http://random.xem.us/rollover.html
(wanted to post a good stepmania video)
« Last Edit: Sun, 27 June 2010, 16:39:37 by AvengeR »
Offline Izlude77714
« Reply #13 on: Sun, 27 June 2010, 19:39:27 »
Quote from: ripster;197026
The Cherry blacks may be a bit stiff for typing but that Deck Legend with Cherry Blacks sure sounded a lot better than that wimpy laptop.  I'd look of something LOUD and FUN since subtlety doesn't seem to be the key here - you're always bottoming out!
what do you mean by stiff exactly? the keys are supposed to be pretty easy to press arent they?
Offline AvengeR
« Reply #14 on: Sun, 27 June 2010, 20:41:33 »
I had JUST gotten that  J-pop  song out of my head before this post came along.
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="500" height="405">[/youtube]
watch the video I posted before (the one I could not get embed): cherry blacks would be a highway to tendinitis.
Offline Mazora
« Reply #15 on: Fri, 07 January 2011, 12:40:08 »
If I remember correctly, in Stepmania you sometimes have to hold 3 keys ... how would that work with 2-kro ?
HHKB Pro 2: black case white keys
Filco Masjestouch v2 / MX-Reds / hard lending pads /Dye-sub keycaps
RF-87UW
Offline bakageta
« Reply #16 on: Fri, 07 January 2011, 13:20:11 »
Stepmania is traditionally arrow-key oriented, but a lot of people remap the keys. I still use the arrows, myself, even though it makes certain patterns harder.
Offline bakageta
« Reply #17 on: Fri, 07 January 2011, 14:18:39 »
Until I got my Filco, I was using a Logitech netplay keyboard, originally meant for playstation 2. It was only 2kro, but all four arrow keys worked at the same time, thankfully. Using the arrows just reminds me more of DDR, the patterns that are difficult on a pad are also hard on the arrows, needing either doublesteps or crossovers.
