Author Topic: Lily58 Help  (Read 3340 times)
Offline santi
Lily58 Help
« on: Sat, 11 April 2020, 18:52:00 »
Hello, I’ve been working on making a Lily58 pro, I made the first half and it all works, except for the shift, z, and x key, I’ve tried looking into their build guide for help, and I’ve tried all their suggestions (adding more solder to the sockets, adding more solder to the diodes, etc.) 239772-0
and it still won’t work, any ideas?
Offline Leslieann
Re: Lily58 Help
« Reply #1 on: Sun, 12 April 2020, 07:58:35 »
I can't tell in the pic due to the coating, but my guess is they are all on the same line which has been damaged.
Check the traces leading to them from the switch before. You may even want to try a temporary jumper and see if that fixes it.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
