Author Topic: Any wireless charging mouse pad recommendations?  (Read 7011 times)
Offline senjo
« on: Mon, 13 April 2020, 05:02:39 »
wanna set up my desktop space nicely. Do you guys have any wireless charging mouse pad recommendations?
Offline Leslieann
Re: Any wireless charging mouse pad recommendations?
« Reply #1 on: Mon, 13 April 2020, 07:46:25 »
There is very few, this means options are even slimmer and the good ones are not cheap.
I'm not prone to worry about wifi but leaving my hand sit on a charging system like that concerns me a bit, especially when there are good alternatives.
My advice, do this instead, it's what I did for my G900 and it works fantastic (Skip to about 1minute).
Just make sure you get an oval shaped one, not a round one as it may be too tall. I also tape the receiver under the desk for close signal and out of sight.
Note, the one he uses has troubel when flipped I guess, I use this one from Amazon and it seems to work just fine on anything at least for charging, not sure about data when flipped which is a problem for some but I don't recommend these for data transfer anyhow.
« Last Edit: Mon, 13 April 2020, 07:51:27 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
