Author Topic: [IC] Shogōki Switch [ You Can (Not) Wait ]  (Read 78493 times)
Offline ertisan
Re: [IC] Shogōki Switch [ You Can (Not) Wait ] (Added IC Form for Stabs)
« Reply #100 on: Fri, 28 August 2020, 15:05:12 »
Tactile switches based off one of my favorite animes? count me in.
Offline SnowyMinion
Re: [IC] Shogoki Switch
« Reply #101 on: Fri, 28 August 2020, 20:46:42 »
lol EVA-01 is 'shogouki' not 'shogoki'
kek
Offline EdgeOfInfinity
« Reply #102 on: Thu, 03 September 2020, 01:18:39 »
really excited for this to come to life, will be in for at least 100  :cool:
Offline lakeboredom
« Reply #103 on: Thu, 03 September 2020, 01:49:40 »
Didn't know about stabs, people just aren't checking the post for a JWK switch that often. They will likely do very well considering the Eva keyset and other switches that ran.
Offline hottrout
  • I'd Hit Dat Key
« Reply #104 on: Thu, 03 September 2020, 04:40:02 »
EU Vendor?
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline Kyosurai
« Reply #105 on: Thu, 03 September 2020, 06:36:01 »
Latest update:
The protos should technically be done 2 weeks later. I'll continue updating when I have photos!
Thank you everyone for your patience :)
Offline Kyosurai
« Reply #106 on: Thu, 03 September 2020, 06:46:38 »
EU Vendor?
I will try to find a vendor for each region :)
Will keep everyone updated on this! :D
Offline HungerMechanic
« Reply #107 on: Mon, 14 September 2020, 12:47:02 »
Rara vs. T1
Here's what the designer of RARA, '43,' said in a Drop post about Rara vs T1:
I'm 43, RARA is  a physically different design, the spring/ and leaf ping is more quite. RARA is not the T1 clones.
It is very similar to 62g mx clear,more smooth.
So these are supposed to be similar to MX Clear in intensity, but with JWK smoothness.
A variation of the T1 stem with different materials.
In image's left side is rara's stem ,and the right side is KBDFANS T1's stem,
the red line at T1's stem is the point where T1 create tactile
,but the black line at Rara's stem is where rara create tactile
yeah,the difference in structure is small, but the difference in feel is obvious
Thats the difference between t1 and rara,
the stem which at the front is t1, rara is behind it
they all line up and cling at each other
Force Diagram:
Chinese typing test:
https://www.bilibili.com/video/av77160874?from=search&seid=11444903851290698992
You can read what the designer said, in this Drop thread:
https://drop.com/buy/jwk-rara-tactile-custom-mechanical-switches/talk/2562222?utm_source=linkshare&referer=BPKDQH
Reviews indicate that the switch [in the original JWK Rara housing] feels good, but may have ping.
« Reply #108 on: Mon, 14 September 2020, 13:00:29 »
There is supporting evidence that the designer was correct about the changes to the T1 stem.
'43' said that the T1 stem had been modified to reduce the overall tactile intensity, with the higher-tactility curve being pushed further down the tactile leg.
One review seems to corroborate this:
Okay, now that I'm home, I tried some Raras against T1s (Red stem, smoky housing), Koalas, and Lilacs. Each switch had Sprit 63.5 Slow springs in them, no lube or film added.
Raras definitely are prelubed on stem and bottom housing rails.
In terms of stock smoothness, my experience was T1s>Raras>Koalas=Lilacs.
For sound, Raras are lower pitched and bassier than T1s, and are slightly more muted than Koalas, less bassy than Lilacs. The upstroke of the Raras sounds to be the quietest of all 4 switches.
In terms of feel, Raras feel like they have more pretravel than T1s. Holding them side by side and pressing gently till I start to feel the bump, I can definitely see the Rara stem press down more than the T1 (seems like it goes twice as deep, in my rough totally-not-professional guesstimate). The tactile bump also feels less sharp and less pronounced than the T1s. I can see what the 43 means by the Ergo Clear comparison. An interesting tactile option that I hope is more widely available, feels and sounds like a bit of a "stealthier" (but not silenced) tactile option in the JWK lineup.
So this might be a more polite 'T1' more comparable to MX Clear, as advertised. Sure would be interesting to buy them in these Shogoki housings.
Offline Kyosurai
« Reply #109 on: Mon, 21 September 2020, 02:48:17 »
[Update]
Enjoy!
Offline posph
« Reply #110 on: Mon, 21 September 2020, 02:57:29 »
When i see an Evangelion theme im hyped!  :eek:
Offline Fantaku
« Reply #111 on: Mon, 21 September 2020, 02:59:16 »
 :eek: :eek: :eek: VERY excited!
Offline Kyosurai
« Reply #112 on: Mon, 21 September 2020, 13:36:23 »
I will be updating the vendors soon! :)
« Reply #113 on: Mon, 21 September 2020, 15:17:28 »
nice
Offline isioisi
« Reply #114 on: Mon, 21 September 2020, 18:20:43 »
I'm ready
Offline FinalEleven
« Reply #115 on: Wed, 23 September 2020, 18:01:59 »
yes.
Offline pewpewnii
« Reply #116 on: Wed, 23 September 2020, 22:58:47 »
YES PLZ
Offline hottrout
  • I'd Hit Dat Key
« Reply #117 on: Thu, 24 September 2020, 04:55:09 »
Waiting
Systems -
  Keyboards -
« Reply #118 on: Thu, 24 September 2020, 18:44:29 »
the colors look great, even more hyped!
Offline Kyosurai
« Reply #119 on: Sun, 27 September 2020, 04:21:51 »
Current the vendors I can confirm are:
Asia: ThicThock
US/Canada: ApexKeyboards
EU: MyKeyboardEU
UK: Proto[Typist]
OCE: TBA
Pricing will be released shortly in a few days time.
GB will happen in October! :)
« Last Edit: Sun, 27 September 2020, 04:32:40 by Kyosurai »
Offline jdecker
« Reply #120 on: Mon, 28 September 2020, 01:31:34 »
let's gooooo
it's happening
Offline SadisticReap
« Reply #121 on: Mon, 28 September 2020, 23:14:42 »
Whats turn around looking like?
Offline Kyosurai
« Reply #122 on: Tue, 29 September 2020, 06:23:45 »
Should be around 3-4 months after GB ended :)
Offline isioisi
« Reply #123 on: Tue, 29 September 2020, 19:01:21 »
I've got a giant pile of EVA themed stuff for my keyboard on the way, if I gotta wait another month or two for these switches I suppose that's okay.
Offline Fantaku
« Reply #124 on: Tue, 29 September 2020, 19:08:48 »
Ooh, other EVA themed keeb stuff?  :eek: please do tell  ;)
Offline isioisi
« Reply #125 on: Tue, 29 September 2020, 19:11:08 »
It's gonna hurt to tell you because the GB is over, but
https://geekhack.org/index.php?topic=100396.0
I got that, a dark purple KBD 100%er coming, and I've made custom coiled Green/purple cabling.
Offline Fantaku
« Reply #126 on: Tue, 29 September 2020, 19:44:26 »
Ah, just the mech set. Good thing I was in day 1  ;D I should make a custom coiled cable too  :thumb: the question is... What keeb will I put my switches and caps on?
Offline isioisi
« Reply #127 on: Tue, 29 September 2020, 19:48:19 »
Haha smart. I'm partial to KBDFans, but I specifically wanted a full size keyboard because this will be used for games at home, and many games require a full range of keys. Having to press multiple things just to activate something in game is kind of a pain.
The 75% is used for work (Also with the SA Berserk Unit-02 themed keycap set :p)
Offline fakedSkill
« Reply #128 on: Wed, 07 October 2020, 12:01:10 »
Excited! How long will production roughly take for those?
Offline Jesus
« Reply #129 on: Wed, 07 October 2020, 14:24:45 »
These look sick, ill cop 110 easy. Finally some more purple switches
Offline William_S_Jones
  • Best Prime Ever!!!
« Reply #130 on: Wed, 07 October 2020, 16:11:51 »
I hate that I missed this GB. Hoping extras were ordered, so I can get a shot at them.
Offline _prjctZero
« Reply #131 on: Wed, 07 October 2020, 16:22:42 »
Asia: ThicThock
EU: MyKeyboardEU
UK: Proto[Typist]
OCE: TBA
Do we have a date for GB yet?
Offline Oddstag
« Reply #132 on: Wed, 07 October 2020, 17:10:56 »
If you're referring to these switches, GB hasn't happened yet.
« Reply #133 on: Wed, 07 October 2020, 18:15:05 »
Yes, happy as hell. I thought I saw something about a GB on Reddit about 1/2 a month ago. Well, I was mistaken. Count me in for @ least 60.
« Reply #134 on: Wed, 07 October 2020, 20:24:01 »
There was one, but those were for Linear switches in the theme of Eva 01.
« Reply #135 on: Wed, 07 October 2020, 23:45:55 »
There was also a pre-order for "Crane Tactile" switches, which I think also use the RARA stem. That happened in the summer, I don't know if they've shipped yet.
Everyone is waiting eagerly for the Shogoki, rest easy, they haven't even gone to GB phase.
Offline Kyosurai
« Reply #136 on: Thu, 08 October 2020, 02:29:20 »
The gb should be happening in a week or two.
Once I get more details, I'll make a gb thread :D
Offline Fantaku
« Reply #137 on: Thu, 08 October 2020, 02:32:06 »
I'm assuming there will be a link poster here to the GB thread when it's live?
Offline Kyosurai
« Reply #138 on: Thu, 08 October 2020, 03:14:26 »
I'll link it to the gb thread when it's up!
Thanks :D
Offline lach64
« Reply #139 on: Thu, 08 October 2020, 20:00:19 »
the accent on top of the o is what makes it shogouki instead of shogoki
Offline kvswim
« Reply #140 on: Mon, 26 October 2020, 09:45:51 »
https://www.apexkeyboards.ca/collections/switches/products/gb-shogoki-tactile-switches
The page is up on ApexKeyboards, but the GB doesn't have dates yet. Get hype!
« Reply #141 on: Mon, 26 October 2020, 10:24:58 »
Just means we are getting closer!
Offline pandaemic
« Reply #142 on: Tue, 27 October 2020, 18:33:39 »
Dates are up on the product page, Oct 30 - Nov 29.
Expected to ship Jan/Feb 2021.
Offline Kyosurai
« Reply #143 on: Tue, 27 October 2020, 21:56:42 »
Hey there everyone,
This is the long awaited update.
The groupbuy will officially commence this coming Friday (30th Oct) and will last for a month.
The price will be $5.50 per 10.
The vendors are:-
US/Canada : ApexKeyboards
EU: MyKeyboardEU
UK: [Proto]Typist
Asia: ThicThock
Oce: DailyClack
We really appreciate everyone’s patience and unrelenting support. Thank you :)
« Reply #144 on: Wed, 28 October 2020, 18:55:50 »
woohoo - it's go time!!  :cool:
« Reply #145 on: Wed, 28 October 2020, 19:23:45 »
Yes!!!!!!will be in for @ least 70!
Offline Lyle88
« Reply #146 on: Sun, 01 November 2020, 02:48:30 »
[Update]
Enjoy!
Can you post a photo of the stem?
Sent from my SM-G970F using Tapatalk
Offline Meepergon
« Reply #147 on: Mon, 02 November 2020, 21:19:46 »
Any updates on the stabilizers? Are they happening?
Offline deaf
« Reply #148 on: Thu, 31 December 2020, 01:38:05 »
Any chance I can still get these? :/
Offline Lyle88
« Reply #149 on: Thu, 31 December 2020, 01:47:52 »
Probably not through the GB as it has ended but people will sell them on mechmarket after they arrive. If you're not specifically interested in this colour, these are pretty much just T1 switches so there are plenty of other colour variants that should feel about the same.
