Author Topic: [IC] EV65 - Render update  (Read 101856 times)
Offline MaiTheSan
« on: Wed, 22 April 2020, 08:15:23 »
Hello, This is my first time I post something in Geekhack and hopefully, my ideal is not duplicate ~ (sorry for my english :3)
 What do you think about this?
Case: 5 Degree
Layout
Thank you~
Maybe i'll add nametag in prototype :3 hope you enjoy it.
#update
And that all the part my keyboard :3
##Update
Added WKL layout
Preview~
[Prototype soon]
[6.5 degree preview]
If you like it, support me by putting this in your forum signature! ♥
Code: [Select]
[url=https://geekhack.org/index.php?topic=105898.0][img]https://sanpj.tonikaku.photos/i/kqct.png[/img][/url]
« Last Edit: Sat, 06 June 2020, 05:33:53 by MaiTheSan »
Offline eniigma
    • Storefront:
Re: [IC] EV65
« Reply #1 on: Wed, 22 April 2020, 08:28:12 »
I really like the look of it. That is quite an interesting engraving, although it doesn't seem centered, which is odd. You should center it in relation to the surface that contacts the ground, not the board itself. Bumpon cutouts seem too close to the brass accents, and some more mounting info would be nice. Good luck!  :thumb:
Offline CrazyAssMonkey
Re: [IC] EV65
« Reply #2 on: Wed, 22 April 2020, 09:21:43 »
I like the design quite a bit as well, but like was mentioned the bumpon cutouts are pretty close to the accents. I like the engraving and its positioning, where is it not centered? Maybe I just am not seeing it. Also how would the plate be mounted?  :thumb:
Offline Ultimatum
Re: [IC] EV65
« Reply #3 on: Wed, 22 April 2020, 09:23:44 »
I’m in. ;D
Offline Lil
    • designedbydark
Re: [IC] EV65
« Reply #4 on: Wed, 22 April 2020, 10:13:22 »
Enligma means it is not vertically centred if the bottom of the board was completely facing the viewer
Re: [IC] EV65
« Reply #5 on: Wed, 22 April 2020, 10:51:58 »
Ahhhhh, I was thinking it might have been that but I do like that positioning. I was thinking he had seen some sort of sideways offset that I couldn't see.
Offline IOVERCALLHISTIOCYTES
Re: [IC] EV65
« Reply #6 on: Wed, 22 April 2020, 11:34:28 »
Seems like an elaborate setup for ligma
I like the board
Offline MaiTheSan
Offline tofulo
Re: [IC] EV65
« Reply #8 on: Thu, 23 April 2020, 13:10:46 »
Looks very cool. Would like a better look at the engraving
Offline lz2019
Re: [IC] EV65
« Reply #9 on: Thu, 23 April 2020, 21:02:42 »
Simply beautiful! I like it not feeling too simple or too bulky while not having that many decorations at the same time.
Yes, please.
Offline MaiTheSan
Re: [IC] EV65
« Reply #10 on: Thu, 23 April 2020, 21:16:01 »
Yes, please.
Thank you~~
Re: [IC] EV65
« Reply #11 on: Thu, 23 April 2020, 21:54:46 »
Woah! That purple with brass looks really nice, actually it looks gorgeous. Are you considering that a color for the board?
Offline yuuS0cut3
  • Stay young
Re: [IC] EV65
« Reply #12 on: Thu, 23 April 2020, 22:03:12 »
I assume this is sandwich mount.
Offline yuuS0cut3
  • Stay young
Re: [IC] EV65
« Reply #13 on: Thu, 23 April 2020, 22:07:56 »
Pm me if you need support. I can help you with posting since we are compatriot  :))
Re: [IC] EV65
« Reply #14 on: Thu, 23 April 2020, 22:18:35 »
It looks that way true, I'm not really picky on mounting system. It is all about the noise and aesthetic for me.  :thumb:
Edit: Tbh just aesthetic lol. I always wear headphones.
Offline MaiTheSan
Re: [IC] EV65
« Reply #15 on: Thu, 23 April 2020, 23:44:02 »
I will update after i have prototype :V, can you suggest some color?? :3
Offline MaiTheSan
Re: [IC] EV65
« Reply #16 on: Thu, 23 April 2020, 23:47:38 »
Of Course =)))
Offline fabijolo
  • I like expensive plastic.
Re: [IC] EV65
« Reply #17 on: Fri, 24 April 2020, 00:22:40 »
I realize the nice and "stealthy" vibes this board gives me  :thumb:
Offline Rejeckted
  • Fe, Fi, Fo, Fum... I smell Kraft dinnah
Re: [IC] EV65
« Reply #18 on: Fri, 24 April 2020, 00:43:30 »
I know it's played out but that dark purple render makes me want an EVA-01 scheme
Offline MaiTheSan
Re: [IC] EV65
« Reply #19 on: Fri, 24 April 2020, 01:57:39 »
like this??? :V
Re: [IC] EV65
« Reply #20 on: Fri, 24 April 2020, 08:04:43 »
like this??? :V
Jajajajaja, that render is awesome, those two weights allow for a decent amount of interesting color play. I am starting to wonder how it would look with racing stripes. Maybe a red or blue main color with white weights or even racing green with white weights.
Offline MaiTheSan
Re: [IC] EV65
« Reply #21 on: Fri, 24 April 2020, 08:57:04 »
like this??? :V
Hmmm, i'll try :v, that's amazing :3
Re: [IC] EV65
« Reply #22 on: Fri, 24 April 2020, 08:59:02 »
like this??? :V
I'm definitely interested if you are trying those out, I don't think i have seen a color scheme like that yet, especially if you do either white with blue weights or blue with white weights, either of those two would be awesome.  :thumb:
Offline MaiTheSan
Re: [IC] EV65
« Reply #23 on: Sat, 25 April 2020, 01:03:17 »
like this??? :V
Blue, Dark Blue or Cyan?? :3
Re: [IC] EV65
« Reply #24 on: Sat, 25 April 2020, 01:09:27 »
like this??? :V
Well I was thinking something that might match GMK Classic blue or Masterpiece. But it hit me what would you think about a dark green like PBT GRÆN with brass?
Offline Romutulus
Re: [IC] EV65
« Reply #25 on: Sat, 25 April 2020, 22:19:14 »
A fan of this design. White with gold/black weights would look pretty classy just saying. That said if I personally would like to see an orange and white combination.
Offline MaiTheSan
Re: [IC] EV65
« Reply #26 on: Sat, 25 April 2020, 22:41:36 »
hmmm, i think i'll try orange if i can anode this color :3
Offline jjoejimmy
Re: [IC] EV65 - Render update
« Reply #27 on: Fri, 01 May 2020, 13:47:04 »
New renders look awesome! Looking forward to seeing the actual prototype
« Reply #28 on: Fri, 01 May 2020, 14:00:00 »
Yes!!! That looks awesome. I quite like the WKL option you mocked up.
Offline Romutulus
« Reply #29 on: Fri, 01 May 2020, 16:45:43 »
New renders look good. The edges look like it could hurt someone sharp though. I assume they would be rounded out in the actual product?
Offline RedBeardDog
« Reply #30 on: Fri, 01 May 2020, 21:45:28 »
Looks awesome.
But 5 degrees... :-(
Offline lys.nordique
  • Formerly 'scatology'
« Reply #31 on: Fri, 01 May 2020, 22:20:39 »
5 degrees and it looks pretty thick, what is the front height?
Offline Vaudevi77ain
« Reply #32 on: Fri, 01 May 2020, 23:37:09 »
Interested. Any estimate on a price?
Count me in if it's hotswap that also comes in rose gold
Offline RedBeardDog
« Reply #33 on: Sat, 02 May 2020, 01:02:54 »
Yea. Hotswap would be nice
Offline xEP
« Reply #34 on: Sat, 02 May 2020, 02:11:52 »
The front looks a little thick.
Offline MaiTheSan
« Reply #35 on: Sat, 02 May 2020, 02:14:03 »
Looks awesome.
but why??
Offline MaiTheSan
« Reply #36 on: Sat, 02 May 2020, 02:35:16 »
hmmm
but I don't know how to draw hotswap
Offline RedBeardDog
« Reply #37 on: Sat, 02 May 2020, 03:43:16 »
hmmm
Too flat. But it’s just my opinion.
Offline Vireca
« Reply #38 on: Sat, 02 May 2020, 03:54:17 »
I dont know why but I feel the name remind me other keyboard
I like the design, maybe 6° will atract more people. Also, idk what to think about the little brass weight on the bottom, that just increase the price and I dont think it make much difference. Whats the mount system?
Offline MaiTheSan
« Reply #39 on: Sat, 02 May 2020, 14:07:23 »
i think it top mount <(")
Offline SoraNoTenshi
« Reply #40 on: Sun, 03 May 2020, 08:40:07 »
Interesting! Looks good to me :)
One thing: I personally prefer the USB being in the middle, I don't know if you like it that way too, so you have to decide it.
But it does look very nice, looking forward to see the protos of it in the future!
Offline MadeByMuscles
« Reply #41 on: Mon, 04 May 2020, 08:06:19 »
Love the look and placement of the weights!
Offline MaiTheSan
« Reply #42 on: Tue, 05 May 2020, 09:03:45 »
It so hard because I draw my pcb from Voyager65 by AI03 :>
« Reply #43 on: Tue, 05 May 2020, 11:20:35 »
Is that top right blocker in the wkl version a possible addition? I like the way it looks.
Offline MaiTheSan
« Reply #44 on: Tue, 05 May 2020, 11:59:47 »
Hmmm, i like WKL so i'll add it :>
« Reply #45 on: Tue, 05 May 2020, 12:00:50 »
Awesome but also what about that top right blocker that removes that key?
Offline MaiTheSan
« Reply #46 on: Tue, 05 May 2020, 12:52:34 »
maybe... no? XD
« Reply #47 on: Tue, 05 May 2020, 13:00:38 »
maybe... no? XD
Jajajajaja alright.
I like the board regardless and I am definitely excited to see what the prototype looks like.  :thumb:
Offline reaLFX
« Reply #48 on: Fri, 22 May 2020, 23:42:08 »
Not bad at all! hot swap option? Interested
Offline MaiTheSan
« Reply #49 on: Wed, 27 May 2020, 03:57:32 »
Maybe~~
