Author Topic: Making Mech Cable - What Solder temp and tip to use for the usb connectors?  (Read 2272 times)
Offline dman777
I am going to try and make my own mech cable. For soldering the wires to the usb plug, what is the recommended tip type and also what is a good temp to use?
Offline Leslieann
General rule, get the wire tinned and hot, touch it to where it's going and heat it just long enough to get it to flow.
This works with pretty much anything, don't worry too much about the temp, your goal is always to use as little as you can.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
