Author Topic: Need PCB, pls help :<  (Read 2099 times)
Offline MaiTheSan
« on: Wed, 29 April 2020, 02:48:49 »
I need PCB 65% for my keyboard, where I can asking to design this. Thank you~
Offline rp_Neo2000
Re: Need PCB, pls help :<
« Reply #1 on: Thu, 30 April 2020, 09:28:35 »
So are you fixed on a PCB for your case or you can use an existing PCB and modify your case?
https://keeb.io/collections/split-keyboard-parts/products/quefrency-60-65-split-staggered-keyboard
If you are looking specifically for a PCB designer, then I too would love to know the answer.
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #2 on: Thu, 30 April 2020, 11:04:55 »
you might want to check: Gondolindrim's PCB design services (not sure if the designer is available at the moment)
Offline rp_Neo2000
« Reply #3 on: Tue, 05 May 2020, 18:32:53 »
This is great thank you!
