Author Topic: In-stock DIY kits?  (Read 2913 times)
Offline Shpigford
    • joshpigford.com
In-stock DIY kits?
« on: Thu, 30 April 2020, 18:19:02 »
I'm looking for a DIY kit to dip my toes in the water. I'd like to assemble everything myself (including soldering), but I'm just looking for a kit that comes with all the parts I need so I don't spend ages piecing things together myself.
I've seen lots of recommendations but everything I'm finding is out-of-stock. So...is anyone aware of in-stock DIY kits?
Ideally a 65% layout, but I'm not too picky at this point as I'm really just looking for a kit to learn how all the things work.
I'm US-based and my budget is $200, though I'd prefer less.
Offline Leslieann
Re: In-stock DIY kits?
« Reply #1 on: Thu, 30 April 2020, 22:33:23 »
Check KBDfans and Krepublic as well as YMDK on Ali Express.
Keep in mind all of these are Chinese so even if in stock it's going to take a while to get it as shipping is slow boat only and they are short staffed in many cases.
$200 is a start and there is stuff well below that, but don't be surprised if you go over a little. My advice, if you are borderline if you want to spend it, spend the extra. It's easier to spend an extra $20 now than you spend another $60 and a few hours undoing work you already did. Do it right the first time.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline nevin
« Reply #2 on: Fri, 01 May 2020, 08:24:30 »
keeb.io has some great, inexpensive kits. most are not your standard keyboards though. they make a bunch of split/ergo boards.
most high end boards are sold through group buys.
Offline Shpigford
    • joshpigford.com
« Reply #3 on: Fri, 01 May 2020, 08:38:34 »
Thanks for the recommendations. I definitely don't need anything fancy...just looking for a starter kit of some sort. I care more about actually being able to find *something* in stock rather than it being the greatest, fanciest board to ever get built. :)
Offline abstractkb
    • Abstract Keyboards Homepage
« Reply #4 on: Sun, 03 May 2020, 12:14:18 »
I agree with getting something from either KPRepublic or Keeb.io, I got my first 2 boards from them and like both of them, as well as it being a good learning experience.
