Author Topic: [WTB] DSA Scientific TKL & Speciality | CA66 HHKB | 60% HHKB PCB  (Read 5475 times)
Offline gnho
  • Trade Count: (2)
See title
« Last Edit: Fri, 22 May 2020, 23:31:22 by gnho »
  • Trade Count: (0)
Re: [WTB] Model F XT 84 Replacement Cable
« Reply #1 on: Thu, 14 May 2020, 10:42:43 »
Approval bump :thumb:
Offline Maledicted
  • Trade Count: (1)
« Reply #2 on: Thu, 14 May 2020, 16:27:07 »
Hi all-
I am suspecting that my cable is faulty. Does anyone has a spare cable you don't use?
Why do you think that the cable may be bad? IBM's old cables are pretty well made. The F XT can flip out if the grounding wire isn't securely screwed down. I bought my F XT with a cut cable and just bought a nice HOSA MIDI cable to splice in as a replacement.
Offline FRANCO
  • Trade Count: (0)
« Reply #3 on: Fri, 15 May 2020, 10:42:28 »
Are you able to use the same cable that the AT uses? If so, here you go:
https://www.redmarket.store/product-page/nos-at-cable
edit: literally says that you can't (without additional splicing) on the page...lol sorry!
Offline gnho
  • Trade Count: (2)
« Reply #4 on: Sun, 17 May 2020, 01:17:52 »
Hi all-
You're right. I fixed the problem. It's not the grounding wire but that screw on top of the controller... On that note, do you know where I may be able to get a case?
Offline gnho
  • Trade Count: (2)
« Reply #5 on: Sun, 17 May 2020, 01:18:45 »
It says on the page that it won't work with XT without splicing but thanks!
Offline Maledicted
  • Trade Count: (1)
« Reply #6 on: Mon, 18 May 2020, 10:21:43 »
Hi all-
That's good to hear.
https://www.ebay.com/itm/IBM-Model-F-Keyboard-Top-Frame/193467722516?hash=item2d0b932b14:g:vi0AAOSwLu5etlwt
I spotted that a few days ago. No bottom portion though. I would love a beat up old lower casing for an AT myself so I can modify it for a removable cable with my conscience intact.
Offline gnho
  • Trade Count: (2)
« Reply #7 on: Mon, 18 May 2020, 21:49:07 »
Offline gnho
  • Trade Count: (2)
Re: [WTB] DSA Scientific TKL & Speciality | CA66 HHKB | 60% HHKB PCB
« Reply #8 on: Fri, 22 May 2020, 23:31:51 »
I just realized people just change title here... hahaha
