Author Topic: Need a PCB to match with a keyset  (Read 2501 times)
Offline epoch
« on: Wed, 06 May 2020, 01:31:42 »
Hi GeekHack!
I was wondering if you could give me a helping hand. I'm a bit new in this world, and after a week looking at the /r/mechanicalkeyboards and looking at the Internet and such, I'm still not quite sure about what I want to do.
I'm looking for a spanish keyboard. Now, the problem is that the TKL world in Spain is a bit non-existent, and the Ducky TKL is not available, so I'm looking forward to build the keyboard. It's not for me, but for a gift.
Now, the only keyset I found to be 100% spanish is this: https://www.aliexpress.com/item/4000130061265.html?spm=a2g0s.imconversation.0.0.109c3e5faDeopw. Switches are easy to find, Gateron or Cherry MX Brown, I don't mind about that.
The problem is I don't find the rest of the materials: case, PCB, etc. I don't know how to find them. I don't mind to spend a weekend soldering the keyboard and learning how to flash it, because I understand the board has to be programmed to be the ISO Spanish layout (the EUR key, the enter key, etc).
If you need a budget, let's say I was thinking in about 100-120€, and if the keyset receives an approval, that's almost 30€.
I'm open to suggestions :)
Thank you very much!
Offline Maledicted
Re: Need a PCB to match with a keyset
« Reply #1 on: Wed, 06 May 2020, 11:36:08 »
That's a tight budget in terms of things that are programmable.
You could try using one of these with any old TKL you happen to find: USB to USB keyboard converter
I'm no expert on the LEGO boards, but I don't think that there are many options out there for TKLs vs the more popular, more tiny layouts. You might be best served trying to find a used Cooler Master QuickFire with MX browns, and replace the controller with a programmable one, if you can even still find them: Replacement controllers
You could try this as well: XD87
A Reddit post I found on it seems to suggest that the plastic case for it sucks. Might want to try the stainless one.
Hopefully others will have better ideas.
« Last Edit: Wed, 06 May 2020, 11:39:54 by Maledicted »
Offline epoch
« Reply #2 on: Thu, 07 May 2020, 01:10:11 »
Well... As far as I saw in reddit and the Internet, the ISO spanish layout requires a keymap to handle the eur symbol, the bit enter key, the ñ... Or I'm a bit confused and just setting the language to Spanish Spain is enough in Windows/Linux/Mac and it's not necessary to have a TKG keyboard.
And about the tool you linked, sorry, but I don't quite understand the use of it, sorry :(
I don't know what LEGO means, but assuming it's about making a custom keyboard, I was thinking on getting a Ducky TKL, but there's not in Spain the one I want...
Yeah, I was looking for it yesterday. The problem is that I contacted the vendor but they didn't really solve my questions. I can get only the board there and the case in another place, that's not a problem, my real problem is the keyboard layout and the keyset. I can learn how to test the board, how to solder the switches, how to flash with the tool they put in the description (and I know how to solder, that I don't need to learn!).
Thank you for your reply!
« Reply #3 on: Thu, 07 May 2020, 07:05:07 »
Any ISO board will work if you tell your OS you want to use Spanish, It's only the keycaps that are different :)
Caps look good but allow plenty of time for them to ship an Enter key if they 'forget' to include one.
For that budget I'd be looking prebuilt, but I have no current recommendations.
Offline el_murdoque
« Reply #4 on: Thu, 07 May 2020, 09:14:49 »
This. The Board will simply submit to the computer which key is pressed. Your OS will interpret that accordingly. So when you've set your board to spanish, you will get all the keys like they are on a ISO Spanish board, no matter what is printed on the keycaps.
I do have the same trouble with ISO-DE boards.
Offline Maledicted
« Reply #5 on: Thu, 07 May 2020, 09:22:18 »
For some reason, I was thinking about having to change the language on every single computer you connect it to (without programmability), but you obviously wouldn't have to worry about that with computers that are all in Spain.
The gist of it is that it acts as an additional external keyboard controller, which you can program, so that everything you connect to it will have the same mapping.
I call the enthusiast kit boards LEGO boards, since you're not really building anything custom (that makes me think of hand wiring, designing PCBs and cases, modifying an existing design, etc), just picking and choosing parts and assembling them. Not that that's bad either, it is wonderful to have options like that available.
From KPrepublic? The stainless case is on the same website. I imagine they both ship from China, but maybe not?
[/quote]
You're welcome.
Is this more a supply thing specific to Spain then? People seem to order a lot of things from China, regardless of where they live.
Did you not want the cap set that you did find?
Offline epoch
« Reply #6 on: Fri, 15 May 2020, 01:23:30 »
You're welcome.
[/quote]
Hey guys!
I bought a Ducky TKL. The official distributor in Spain had stock, so I bought it. It's a really good keyboard!
Thank you for your advice! I'll take into account the next time I'll buy a keyboard!
