Author Topic: Spacebar problem  (Read 1537 times)
Offline Bubson
Spacebar problem
« on: Fri, 15 May 2020, 15:22:18 »
Hello. Im new here. Im coming to you guys, because I can't find answer anywhere.
Im the owner of durgod k320 taurus.
The problem is registered on camera:
So... My speaker felt on  my keyboard (on spacebar) and from this moment the problem occurs.
If I take the board out from the case, everything is ok, but if its in the case and I push that plastic frame, spacerbar wont work.
I was trying to correct solder  but it did nothing.
Should I just switch switch?
Can you help me please?
Kind regards
Jacek
Offline IronCheeks
Re: Spacebar problem
« Reply #1 on: Fri, 15 May 2020, 19:58:58 »
Hello Bubson and welcome to the GH community.
I think you'd fare better in finding out what help fellow keyboard enthusiasts have offer in the "Keyboard" thread. If you start a thread there, you'll more than likely have someone who's willing to help you out. Otherwise, good luck in finding all the answers you need.
Offline Bubson
« Reply #2 on: Sat, 16 May 2020, 04:59:40 »
Ok. Thank you :)
Greetings
