Author Topic: [IC] KAT Crusader | GB: Jan 1st - Feb 1st  (Read 77606 times)
Offline harlekein
Re: [IC] KAT Crusader
« Reply #50 on: Wed, 27 May 2020, 10:09:42 »
Love the colours and I've been looking out for a KAT profile kit that supports JIS layout :-D
This kit comes very close to having everything required for proper JIS layout support; it is only missing one key. That is the ー key, used to extend syllables as in the word "keyboard", 「キーボード」.  With the addition of this key it is possible to type Japanese using kana input. It belongs to the right of the number row, next to the backspace.
JIS users also need a 1U backspace key in order to make space for it, but I see you already have that in your 40s/Ortho set.  You also have correctly-positioned む and ろ keys available, which is great to see!
Overall, great work on the relatively comprehensive JIS layout support!  Please consider the inclusion of this one additional key in order to take it over the finishing line.  See Masterpiece and Sumi for examples of this key in use (albeit in GMK sets), and its correct positioning.  Thanks!
I thought the Japanese legends were just for aesthetics. Do people actually use them for JIS layouts? I see the argument for compatibility coming up recently, but I'm wondering how many people need that compatibility.
Offline duckadence
« Reply #51 on: Wed, 27 May 2020, 12:51:38 »
Hey everyone, thank you for the amazing feedback on this set! Right now I am working on trying to get an update out, but for now I'm a little concerned that not everyone is on the same page about the colors of the set, I've received an alarming number of comments on the google form from people thinking that the main modifier color is yellow, this is not correct. Just to be clear, the base mod color is Orange, where as the alpha legend color and dark kits legend color is yellow. It seems like just from looking at the renders it's hard to tell that they are different colors, I want to make sure that everyone knows the correct colors and isn't under the impression that the colors are different.
Huh... Gonna be honest, not sure how I feel about that cuz I was really excited for orange. I for one didn't notice the yellow at all. But then again, if they blend so much that I don't notice, it should be fine?
Offline kidviddy
    • 駄日記
« Reply #52 on: Wed, 27 May 2020, 23:41:31 »
This is actually a surprisingly complex question which I and others on the forum have been trying to get to grips with.  Lurking behind the apparently simple problem of whether people actually type using the kana input method whereby each key produces the kana character rendered on that key is the more complex problem of JIS support in general, which as far as I can tell has not received a huge amount of attention on this forum until recently.
To answer the first, simple question: yes, there are people that use the hiragana input method when typing Japanese (I am one of them), but it is also true that they are a minority, even in Japan.  The romaji input method, whereby you might type the letters “t” followed by “a” and they would automatically be converted to “た”, is the more common way of inputting Japanese, even amongst native speakers of the language.
However, it is also true that within Japan at large, the vast majority of people use a JIS-layout keyboard. This is a similar problem to ISO support, Norde kits, take your pick — the location of many of the punctuation symbols is different from US-ANSI, and if that is your preferred layout it immediately rules out a huge range of keysets, since JIS support has traditionally been extremely lacking in the community.  The only keyset I’ve found so far which really does it justice is /dev/tty’s “Japan” set, which offers a remarkable level of support at the cost of adding a large number of extra keys.
Now, I would like to see full JIS support kits become commonplace not just for sets which involve kana monolegends or even sublegends, but for *all* kinds of sets, including sets which contain only Latin alphas.  ISO and Norde have been an uphill battle for a long time but seem pretty commonplace now, and perhaps one day this will be the case for JIS, too.  However, I understand that the ~9 extra alpha keys and 4 extra modifier keys required for full JIS support is a lot to ask.  By comparison, supporting JIS alpha layouts fully on a monolegend set like this one is quite easy: all that is required is one extra key.  From the people I’ve spoken to so far, this does not add much if anything to the overall cost of the set, and it opens it up to a whole class of users who might not otherwise have considered it.
Admittedly, I have a dog in this fight.  This whole campaign started for me when I bought GMK WoB Hiragana, naively assuming it would have all the keys I needed, and I had to sell it on the day it arrived because I couldn’t use it with my (JIS) keyboard.  I am trying to be reasonable about it, though — I understand that keyset designers have to balance a lot of trade-offs and they can’t satisfy everybody.  That’s why I’ve so far focused my energy on kits in which supporting JIS layouts is both relatively easy and clearly justifiable; namely, kana monolegend sets. I don’t expect everyone to go along with it, but I do hope people can at least consider it, because I suspect that the lack of support so far has had as much to do with lack of awareness of what is required for JIS support as it has to do with the actual feasibility of including it.  If I can help designers with the first issue so that they can make their own judgment regarding the second, then that is all I can ask for :-)
I hope that helps to answer your question!  Feel free to follow up either here (if it won’t derail this thread too much), via DM or on Discord.  I am on Tyson’s server as well as Keycap Designers and some others, and I’m eager to do what I can to help raise awareness generally of what’s involved in supporting JIS layouts!
Offline phxrbn
  • tech. design. real estate.
« Reply #53 on: Thu, 28 May 2020, 13:37:13 »
+1 for the light alphas
Offline harlekein
« Reply #54 on: Fri, 29 May 2020, 04:14:54 »
That makes a lot of sense, as a niche user, I fully understand that. And how frustrating it is to just be one or two keys away from having compatibility.
Personally I gravitate towards non-Latin alpha kits, because of two reasons: Colemak DHm is often not supported (different story with KAT fortunately) and I like the novelty kits. Hiragana is overdone by now imo, but I've yet to see my first Katakana kit. I am not a big fan of text mods, unless they're novelty mods, like Godspeed kits. Then I will pick Latin+Colevrak.
As for this kit, I don't know the anime character, but it reminds me of the modern Deus Ex games. Having Katakana + mods could make for a good look approaching that aesthetic.
243781-0
Offline Tyson
« Reply #55 on: Fri, 29 May 2020, 14:33:08 »
I can definitely see Deus Ex vibes hahahaha, I never really thought about that. I've had someone think it was a JoJo inspired set based off of Dio's colors.
Offline RtS_Clack
« Reply #56 on: Mon, 01 June 2020, 07:11:17 »
goddamn i just spent my money into the KAT Explosion and just learned about this IC right after I placed my order
I guess that's one more I need to prepare for
Offline thediller
« Reply #57 on: Thu, 18 June 2020, 18:40:49 »
Is this set still alive?
Offline konstantin
  • Formerly constexpr
« Reply #58 on: Fri, 19 June 2020, 05:58:09 »
Have you considered using the updated icon mods seen in Hyperfuse, Iron and Monochrome?
Offline Primal
« Reply #59 on: Fri, 19 June 2020, 06:30:23 »
Not a weeb stuff fan but ngl those colors look great
Offline Tyson
« Reply #60 on: Fri, 19 June 2020, 18:32:14 »
Yeah, my next update for the set is in the works, right now I have been trying to find a job since I was laid off, as soon as I can I will post an update for this set :)
I have not, I will take a look into the mods and potentially see. There hasn't really been any interest in my google form for those icon mods but I will look into it.
Offline L8T
« Reply #61 on: Fri, 19 June 2020, 21:46:52 »
Lalatina best girl!
Offline Tyson
« Reply #62 on: Mon, 22 June 2020, 15:50:28 »
Quick Update:
- Removal of orange 2 and 3 key from UK ISO Kit
- Fix Ergo Kit
- Add ____ Novelty to both Novelty kits
- Add White Latin Alpha and Katakana Alpha kits, WS1 White with same legend color as the other alpha kits
- In talks with a US Vendor to run this set, more updates on this to follow :)
Offline konstantin
« Reply #63 on: Mon, 22 June 2020, 16:24:00 »
As mentioned earlier in the thread, the katakana kit is missing a R4 1u ー key.
The ù٪ and ٭µ keys in the French kit can be removed as they are not used in practice to any noteworthy degree, and are essentially duplicates of the ù% and *µ keys.
The sizing of the alphas also seems a bit off in the French kit.
Edit: The orange '@ key in the UK kit seems unnecessary too, like the orange 2" and 3£ that you removed. And I guess you want to keep the orange R2 #~, \| and R1 \| keys in order to allow ISO users to have mods in the V shape if they want?
« Last Edit: Mon, 22 June 2020, 16:32:59 by konstantin »
Offline William_S_Jones
  • Best Prime Ever!!!
« Reply #64 on: Thu, 02 July 2020, 01:24:02 »
Just joined KAT explosion today; definitely will being Crusader. I'm glad that Konosuba is receiving MKB love!
Offline Tyson
Re: [IC] KAT Crusader | Vendor Announcement
« Reply #65 on: Thu, 23 July 2020, 18:16:34 »
Just wanted to do a quick update for you guys and let you know that we have secured a NA vendor for this set! :D I am currently working on getting vendors for other regions and will update you as soon as proxy's are secured.
NA Vendor: CannonKeys
CA Vendor: DeskHero
AU Vendor: DailyClack
Date of GB: Q1 2021
« Last Edit: Thu, 23 July 2020, 23:48:46 by Tyson »
« Reply #66 on: Thu, 23 July 2020, 18:51:42 »
Date of GB: Q1 2021
Great, I'll be ready for the GB, it'll look great by KAT Explosion too. I'm enjoying the konasuba love!!
Offline Daniel
« Reply #67 on: Sun, 02 August 2020, 09:20:46 »
That CannonKeys Brutal60 WKL render is so classy  :p
Offline Tyson
« Reply #68 on: Fri, 14 August 2020, 21:36:38 »
Currently in talks with a deskmat designer to work on some designs for mats for the set! Will post pics once we have everything done!
Offline Emolokz
« Reply #69 on: Sat, 22 August 2020, 01:47:27 »
Definitely interested, orange and black are my favorite colors.  The yellow legends don't bother me at all, they compliment the orange and black nicely.
Offline lemmebuildthings
  • Why did I get into this god forsaken hobby
« Reply #70 on: Mon, 31 August 2020, 21:15:35 »
Super interested! If you end up doing the rest of the squad after this one my bank account is gonna be non-existent
Offline Ireojimayo
  • Yo dayo
« Reply #71 on: Tue, 01 September 2020, 00:13:05 »
Surprise there are a lot of other existing konosuba sets
KAT Lich, based off Wiz, designed by eskimojo and is planned to ship in October
KAT Explosion, based off Megumin, designed by Rensuya and the GB ran in June and is planned to ship in February
Kat Goddess, based off Aqua, also designed by Rensuya and the GB is planned to run in Q4 2020
Offline Normanthenormie
« Reply #72 on: Tue, 22 September 2020, 16:31:47 »
Will this be PBT? And would you consider running custom Rocket Cables for this GB as well?
Offline randomlamer
« Reply #73 on: Thu, 24 September 2020, 05:44:17 »
Would love to see a blank alpha kit
Offline Tyson
« Reply #74 on: Thu, 24 September 2020, 08:53:07 »
Yes! Every KAT set is PBT! And as for Cable vendor, I am good friends with Space Cables so cables will be ran through him! :)
« Reply #75 on: Mon, 28 September 2020, 16:01:19 »
Sounds good. Ty!
Offline Tyson
Re: [IC] KAT Crusader | GB set for Dec 2020!
« Reply #76 on: Fri, 30 October 2020, 23:50:26 »
New Update!
- Group Buy Date is December 2020
- New Deskmat Design currently in the works by 1stGarden
- Black on White Alphas will be added as a kit for those of you who have been waiting for white alphas!
- UK-ISO & Ergo Kits are getting adjusted
- Adding a new novelty to the novelty kit! Vanir's Mask will be added to the novelties!
I want to apologize for the lack of updates on this project, I've been working on this along with other keysets and have been having some personal life stuff get in the way. I can't wait for the group buy to start on this one! I'll be sure to update as soon as I have the adjustments made!
Offline Ireojimayo
  • Yo dayo
« Reply #77 on: Sat, 31 October 2020, 02:34:41 »
Super excited for this and glad to see it finally has a date for GB
Love Konosuba but more than that I like the colourway as well as the look of the novelties in this set (Can't wait to see Vanir's mask)
I'll probably get black alphas, but im interested to see how the bow ones will look.
« Reply #78 on: Sat, 31 October 2020, 17:38:03 »
Thanks for the update [mention]Tyson [/mention] I’ll be ready for the GB: alphas, both 40, and some additional kits for me!
Offline mlacabrera
« Reply #79 on: Sun, 01 November 2020, 09:14:32 »
I shall not pass this up after I neglected megumin !
Offline Tyson
« Reply #80 on: Wed, 04 November 2020, 14:34:25 »
MAJOR KIT UPDATE!!!!
I've added the White alphas for both the latin alphas and the katakana alphas! Adjustments have been made to the novelties to include the new Vanir mask novelty in 1.5u and 1u R1 caps, changes were also made to correct the ISO kit along with the Ergo Kit. These are the final changes to the set! We are sending these out for quotes right now, will update you guys when I get more info on the deskmat along. There's one more surprise for this set but I am not ready to announce it yet. Stay tuned!
Re: [IC] KAT Crusader | Finalized Kits!
« Reply #81 on: Wed, 04 November 2020, 17:03:55 »
I love the white alphas & updated novelty kits; I’m looking forward to 12/20!!!!
Offline MattVortex
« Reply #82 on: Sun, 15 November 2020, 07:15:29 »
Is this ISO kit now considered final? It seems odd to include black-on-yellow versions of ['@] [#~] [\|], given that's the colour of the mods rather than the alphas, and not include black-on-white ISO keys so ISO users can use the black-on-white alphas.
Offline Tyson
Re: [IC] KAT Crusader | GB starts January 1st! Rama Collab & Deskmat Update!
« Reply #83 on: Tue, 01 December 2020, 23:50:10 »
Good Evening everyone! I just wanted to update everyone to let them know that the GB date for KAT Crusader is confirmed to be Jan. 1st, 2021! Starting the year off with a banger! :D
I also wanted to update you guys to let you know that there will be a Rama Collab for the set! Along with another Deskmat Design, Gamer Lala by 1stGarden! The deskmat artwork is not fully done yet, the artist is still working on it, what we currently have is a progress pic to give you guys a general idea of the direction of the deskmat! Hope you guys like it! Can't wait to launch the GB next month!
RAMA Collab
Gamer Lala Deskmat By 1stGarden
ARTWORK STILL IN PROGRESS SAMPLE PIC BELOW
Offline Tyson
« Reply #84 on: Sun, 20 December 2020, 15:58:16 »
Hey guys,
Just wanted to post a new update for the Gamer Lala Deskmat, hope you guys enjoy it! I also wanted to let you guys know that we have the quotes in from Keyreative, I'm working with all the vendors to get the pricing all figured out for each region, once I do that I'll update yall again!
Have a happy holidays!
Offline Tyson
« Reply #85 on: Sun, 27 December 2020, 20:19:37 »
As we ramp up for the start of the GB, who would you guys like to see for Artisan collabs? I have only contacted Artkey so far but I would love to contact others! And if you are an artisan designer and would like to collab for the set feel free to contact me and we can definitely work something out!
Offline plut0nium
« Reply #86 on: Tue, 29 December 2020, 07:21:05 »
Hi
Really like this set, especially the White/Orange combination  :thumb:
Any plans to have the other Alphas sets in white ? (i.e. I'm thinking about French & Colevrak)
And no R2 Enter in the Ergo set ?
Thanks
Offline peachie
  • keycap enthusiast, dreams of designing
« Reply #87 on: Thu, 31 December 2020, 16:23:29 »
Damn I was really hoping this would be Stardust Crusaders (as in part 3 of JoJo's Bizarre Adventure, my favorite manga) themed hahah, damn it. even with the newest anime adaptation, why can't my favorite series be more popular hahah
despite that-- and not knowing the source material Konosuba-- I think this set is objectively visually appealing and well executed, though! GLWGB~ :>
Foxlab Key65       TMO50          MOJO60
Offline Tyson
« Reply #88 on: Thu, 31 December 2020, 16:30:51 »
I actually have a Jojo set that I've been working on, GMK Deathly Queen, I'm currently waiting on new renders for the set so I can fully revamp it, kind of like when Killer Queen got Bite the Dust added ;)
Offline Tyson
Re: [IC] KAT Crusader | GB: Jan 1st - Feb 1st
« Reply #89 on: Thu, 31 December 2020, 19:07:24 »
Reported GB post and now waiting to be approved, locking thread. Will link to GB post once it gets approved.
