Author Topic: TKL PCB with per-key RGB?  (Read 9732 times)
Offline robotictomato
« on: Fri, 29 May 2020, 21:45:07 »
I'm looking for a TKL PCB with per-key RGB (underglow optional) for making a custom keyboard or swapping into a case.
QMK is a must, VIA would be a big bonus.
Any thoughts?
Offline walie
Re: TKL PCB with per-key RGB?
« Reply #1 on: Fri, 29 May 2020, 22:28:14 »
u80-a
Offline mode
« Reply #2 on: Sat, 30 May 2020, 02:13:22 »
Offline Leslieann
« Reply #3 on: Sat, 30 May 2020, 02:47:12 »
u80-a
Not available and probably never will be again.
LFK-TKL
Backlit, not backlit RGB
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Sup
« Reply #4 on: Sat, 30 May 2020, 05:53:14 »
I legit think there is 0 custom TKL PCB's out there that have RGB backlit and QMK in one sentence that you can buy now. I only know underglow RGB is common these days.
current
Coming soon
« Reply #5 on: Sat, 30 May 2020, 11:27:00 »
Thanks for the responses. I will keep looking, but it sounds like there might not be anything out there right now...
Offline Leslieann
« Reply #6 on: Sat, 30 May 2020, 23:01:02 »
I've been looking for a while and not found anything.
Companies have all but sold out of current inventory while they redesign for rgb which is too new.
It's not really new, but the keyboard industry is small and very slow moving.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline NightFox99
« Reply #7 on: Sat, 13 November 2021, 04:12:48 »
Hey, any luck on finding one ever since ?
Offline illusixn
  • Formerly illusixn
« Reply #8 on: Mon, 15 November 2021, 11:03:18 »
Gondolindrim's Apollo87H exists, but is still in development phase. Also, it's hotswap only so if you prefer solderable, you'll have to make some adjustments.
Repo: https://github.com/Gondolindrim/Apollo87H
Docs: http://acheronproject.com/pcbs/apollo/apollo87h/
Offline Amanda-Topfast
« Reply #9 on: Sun, 05 December 2021, 21:24:29 »
we have such TKL, do you still need
Offline not_irc
« Reply #10 on: Mon, 06 December 2021, 02:28:40 »
Do you have an ISO tkl hotswap compatible with qmk or via?
Offline not_irc
« Reply #11 on: Mon, 06 December 2021, 02:52:56 »
ansi only though :-(
Offline Adqam64
« Reply #12 on: Wed, 15 December 2021, 19:31:36 »
Difficult to buy standalone maybe but the CapsUnlocked CU80's PCB is a TKL with bright per key RGB and at least QMK support.
