Author Topic: [GB] GMK Boneyard (CLOSED)  (Read 40392 times)
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« on: Fri, 05 June 2020, 09:17:13 »
GMK Boneyard
Group Buy is active from June 5th 2020 to July 3d 2020
Est. Shipping Dates will be between February and April 2021
Hello everyone and welcome to Group Buy for GMK Boneyard. GMK Boneyard was an optional colorway offered in GMK Carbon R2 in 2018 and it was quite expensive to get, if you consider that you had to get a base kit and the boneyard alphas. So in order to make it more accessible i decided to run it as standalone set with more competitive pricing ;)
Additionally it offers some unique novelty variations which were not available in GMK Carbon R2. You should also keep in mind that those novelties can be combined to some extent with previous version of GMK Carbon and partially with GMK Oblivion (Oblvion mods base color is the same as used in Carbon). So all in all there is some room for mix and match available ;)
Link to GMK Boneyard Interest Check thread.
Vendors:
Base kit
The base kit offers only the necessary key for 60%, 65%, TKL, WKL, 100% and 1800er layouts. I do expect the base kit to get very competitive pricing.
40% kit
This kit is also designed to be affordable. Thus it includes only necessary keys for most 40% layouts and it contains all currently available spacebars for layouts with split spacebars. Additionally it includes extra B key for layouts like TGR Alice.
Novelties kit
Most of all my sets do offer some sort of novelties and Boneyard is not an exception. The theme is here obvious. Its about Pirates/Buccaneers which adds some adventurous touch to it.
Domino kit
This kind of novelties was introduced in GMK Carbon R2/SP SA Carbon R2 and here it is available in the Boneyard colorway which sets it apart from the previous runs. Anyway if you want to display the number keys on your keyboard in a different way then this is the kit you should get ;)
« Last Edit: Tue, 28 July 2020, 13:47:16 by T0mb3ry »
Offline T0mb3ry
    • Flickr
Re: [GB] GMK Boneyard
« Reply #1 on: Fri, 05 June 2020, 09:17:41 »
Some real life photos of Boneyard from GMK Carbon R2.
Comparison from OG Carbon colors to N9/L9
Renders by Oblotzky
Render from GMK Carbon R2 (note the icon only extension is not available in this GB)
GB Renders by Oblotzky
« Last Edit: Fri, 05 June 2020, 09:45:04 by T0mb3ry »
Offline logo4poop
  • Talk to me on discord @logoooo
« Reply #2 on: Fri, 05 June 2020, 09:44:39 »
pog
LCK75 so lit
« Reply #3 on: Fri, 05 June 2020, 09:44:57 »
Approved :thumb:
FYI, the beige text is really hard to read with the Austere theme :confused:
Offline T0mb3ry
    • Flickr
« Reply #4 on: Fri, 05 June 2020, 09:51:05 »
Approved :thumb:
I'll just make it default white then ;)
Offline mydens
« Reply #5 on: Fri, 05 June 2020, 10:00:04 »
DAMN, nice black face......trying to start a riot?
« Reply #6 on: Fri, 05 June 2020, 10:10:06 »
You could always embrace your inner WordArt and give it a nice glow effect.
Offline T0mb3ry
    • Flickr
« Reply #7 on: Fri, 05 June 2020, 10:34:24 »
I don't have the theme but the Title is now glowing and has shadows which might help to distinguish it better from back ground.
Offline chits
« Reply #8 on: Fri, 05 June 2020, 13:54:59 »
nice set, i'll be joining.
just a heads up the base kit lists the second 2.25u shift as a 1.75u. Might wanna edit to avoid confusion.
Offline pcire
« Reply #9 on: Fri, 05 June 2020, 13:56:34 »
Definitely in!
but...
No hope for deskmats?
Offline IOVERCALLHISTIOCYTES
« Reply #10 on: Fri, 05 June 2020, 15:14:57 »
Kraken buccaneers and bones made their way to deskmats, I’d probably buy both...
Offline pcire
« Reply #11 on: Fri, 05 June 2020, 15:20:20 »
Same!
Offline thornkin
« Reply #12 on: Fri, 05 June 2020, 16:28:34 »
Would the gray here match the gray in oblivion alphas? Could I use the dice keys with oblivion or would they stand out?
Offline asspennies
« Reply #13 on: Fri, 05 June 2020, 21:54:53 »
the skull and bones or the skull/octopus would make a great accompanying deskmat, any plans?
« Last Edit: Fri, 05 June 2020, 21:56:58 by asspennies »
« Reply #14 on: Fri, 05 June 2020, 22:38:50 »
I just packed up my oblivion and carbon sets or I’d show you. Boneyard is darker than oblivion alphas and is close-ish to mods. I’ve sat them next to each other and they don’t look bad, but the alpha-mod difference is pretty low.
Offline deathwalker113
« Reply #15 on: Fri, 05 June 2020, 23:25:01 »
I'm still using GMK Carbon r1 and planning to join in so i can mix the alpha/mod. Therefore, my question is: Can i mix them to create bone base kit like GMK Carbon r2 ?
« Reply #16 on: Sat, 06 June 2020, 00:09:24 »
I had GMK Carbon r1 and boneyard alphas and they were good together. Whether or not the grey keys have any shine or not is a bigger difference than batches of the grey color. I think using your alphas with these mods would look great.
Pedantic-Carbon bone base from GMK Carbon R2 uses R0 f row and R5 base. So the profile here is different but the colors are essentially the same.
Offline Sunhwan Jeong
« Reply #17 on: Sat, 06 June 2020, 00:52:00 »
Oblivion mods & Boneyard use same color "officially", not alphas.
Offline T0mb3ry
    • Flickr
« Reply #18 on: Sat, 06 June 2020, 01:52:08 »
Boneyard and Oblivion mods use the same gray base color. So basically its open for mix and matching. I also mentioned this in the first post of this topic (see in the description).
GMK (or rather their plastic supplier) is also very consistent in colors from batch to batch. I can for example mix and match different GMK Carbon rounds without noticing any discrepancies in colors.
Of course you can do that. Actually i never thought of this combo but you got it ;)
« Last Edit: Sat, 06 June 2020, 01:54:23 by T0mb3ry »
Offline thornkin
« Reply #19 on: Sat, 06 June 2020, 02:32:14 »
Thanks all. I see the answer to the oblivion question was in the description text. I didn't think such a question was likely to be answered there but such an expericed gb runner was thinking ahead.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #20 on: Sat, 06 June 2020, 12:21:48 »
Was bummed I sat out in the first round. Tempted to pick this up for sure.
Offline FTR_Beat
« Reply #21 on: Sun, 07 June 2020, 00:41:04 »
Alright bro, my order is in for base + novelties!
Oh and don't forget beezarre... you nailed the orange tone on that one =)
Offline matrixzj
« Reply #22 on: Sun, 07 June 2020, 02:01:24 »
So grey base color is also #575d5e, and alpha is #e3d9c6. Am I right?
Discord:Matrix#6203
HHKB Fanatics
SA/GMK Keycaps Info
Offline T0mb3ry
    • Flickr
« Reply #23 on: Sun, 07 June 2020, 03:45:39 »
Yep that would be the colors.
Offline konstantin
  • Formerly constexpr
« Reply #24 on: Sun, 07 June 2020, 10:42:57 »
Excited to see this run! GLWGB!
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #25 on: Sun, 07 June 2020, 12:03:27 »
Fantastic set 🙏
Offline oldcat
  • 65% is Life
« Reply #26 on: Sun, 07 June 2020, 13:41:07 »
It appears real life pictures are way lighter than the renders, I would assume the boneyard is not using GMK base colors right?
Offline T0mb3ry
    • Flickr
« Reply #27 on: Sun, 07 June 2020, 13:55:52 »
Its using custom colors which were used in GMK Carbon and in partially in GMK Oblivion.
If you take the picture in the first post then it appears to be lighter - yes. Because the light was pretty bright on that day. In each environment it will look different. Today i made this photo outside.
Here it appears darker.
Offline oldcat
  • 65% is Life
« Reply #28 on: Sun, 07 June 2020, 15:14:07 »
Thanks! It is basically different lightings create different visual effects :)
Amazing set!
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #29 on: Mon, 08 June 2020, 10:25:13 »
<-- progress
« Last Edit: Wed, 10 June 2020, 00:48:40 by dvorcol »
Offline dvorcol
« Reply #30 on: Wed, 10 June 2020, 00:47:59 »
<-- progress
« Last Edit: Thu, 11 June 2020, 12:34:09 by dvorcol »
Offline Mr_BeastQuake
    • Reddit
« Reply #31 on: Wed, 10 June 2020, 12:14:26 »
I like these single base color sets, just which we can get some windows on these fools!
Pretty sure I'm buying this regardless.
Offline flow3rz
« Reply #32 on: Wed, 10 June 2020, 18:00:50 »
love the set! ordered the base, novelties, and couldnt let the dominoes go by too. Countdown to february!
Offline dvorcol
« Reply #33 on: Thu, 11 June 2020, 12:33:37 »
<-- progress
« Last Edit: Sun, 14 June 2020, 13:09:20 by dvorcol »
Offline dvorcol
« Reply #34 on: Sun, 14 June 2020, 13:08:50 »
<-- progress
« Last Edit: Tue, 16 June 2020, 03:48:46 by dvorcol »
Offline T0mb3ry
    • Flickr
« Reply #35 on: Mon, 15 June 2020, 10:37:54 »
Same!
In the next possible Group Buy for Carbon - i will offer matching deskmats for Boneyard (probably there will be even two versions), Carbon and probably Beezarre too.
« Reply #36 on: Mon, 15 June 2020, 12:48:26 »
Same!
So this would be SA, Finally
    • WTB/WTTF Thread
« Reply #37 on: Mon, 15 June 2020, 12:51:35 »
Same!
I don't think it's smart to make that assumption
« Reply #38 on: Mon, 15 June 2020, 12:56:49 »
Same!
Ay, dreambreaker
Offline FTR_Beat
« Reply #39 on: Mon, 15 June 2020, 16:20:10 »
Same!
Cool!!
Offline dvorcol
« Reply #40 on: Tue, 16 June 2020, 03:46:44 »
<-- progress
« Last Edit: Wed, 17 June 2020, 15:21:18 by dvorcol »
Offline T0mb3ry
    • Flickr
« Reply #41 on: Tue, 16 June 2020, 08:40:19 »
Just for the info. All kits will go into production  :thumb:
« Reply #42 on: Tue, 16 June 2020, 11:51:17 »
>I also prefer SA > GMK, even the production time of SP is much >longer than GMK
Whether the lack of difference between gmk and SA times persists after covid dies down is unclear, but right now I might give SA the edge
Offline dvorcol
« Reply #43 on: Wed, 17 June 2020, 15:20:47 »
<-- progress
« Last Edit: Fri, 19 June 2020, 02:39:04 by dvorcol »
Offline FTR_Beat
« Reply #44 on: Wed, 17 June 2020, 16:17:18 »
Awesome news!!!
Offline dvorcol
« Reply #45 on: Fri, 19 June 2020, 02:38:37 »
<-- progress
« Last Edit: Wed, 24 June 2020, 16:54:37 by dvorcol »
Offline dvorcol
« Reply #46 on: Wed, 24 June 2020, 16:54:13 »
<-- progress
« Last Edit: Fri, 26 June 2020, 14:40:27 by dvorcol »
Offline dvorcol
« Reply #47 on: Fri, 26 June 2020, 14:39:46 »
<-- progress
« Last Edit: Sun, 28 June 2020, 16:43:40 by dvorcol »
Offline pott
« Reply #48 on: Fri, 26 June 2020, 17:35:44 »
I just got a Base kit + Dominos. The Dominos can also double as more interesting Ortho modifiers. I wish there had been an Alphas kit, it'd have gone well with the recent N9 ortho mods kit.
That being said, I love seeing more interesting 'default' color kits. This will go with more cases than WoB for example, while staying elegant and simple. Thanks for that!
Offline dvorcol
« Reply #49 on: Sun, 28 June 2020, 16:42:58 »
<-- progress
« Last Edit: Thu, 02 July 2020, 03:00:05 by dvorcol »
