Author Topic: MT3 'fillers'?  (Read 3469 times)
Offline EyalRo
  • Smol Dino
MT3 'fillers'?
« on: Sun, 14 June 2020, 01:52:57 »
I've recently received my /dev/tty! Unfortunately, I've since discovered the wonders of less standard layouts. Namely, split spacebar and ortholinear.
For these layouts, I need to add some keys I don't have, I think all in the bottom row (spacebars). 1u, 2u for ortho. and 1.25u, 2.25u, 2.75u for split spacebar.
Usually I would hop onto PMK or something and get the missing spacebars however I can't seem to find anywhere that has MT3 profile keycaps. Anybody know where I can find any?
Offline Tom_Kazansky
  • Oblivion Knight
Re: MT3 'fillers'?
« Reply #1 on: Tue, 16 June 2020, 05:02:41 »
MT3 is (Mass)Drop exclusive, only available on Drop.com, and I think you just missed a group buy of the said set. (which includes split spacebars)
you can lurk the aftermarket for your need, Classified or r/mechmarket
Offline EyalRo
  • Smol Dino
Re: MT3 'fillers'?
« Reply #2 on: Tue, 16 June 2020, 23:25:51 »
I didn't know MT3 was an exclusive! ... at least it's with drop, they seem to be releasing their stuff on a very regular basis. I'm sure /some/ set with spacebars will be available soon.
