Author Topic: [In Production] KK75 KEYBOARD KIT - Delivered  (Read 11347 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
« on: Mon, 15 June 2020, 05:35:44 »
Edit: July 20,2020
Name badge update: https://i.imgur.com/5KhXAmK.jpg
Hi Everyone,
Good day! The GB for the KK75 KEYBOARD KIT is NOW LIVE on the Website here.
IC post: https://geekhack.org/index.php?topic=106596
Musical rhythm (Another model, Just layout is different): https://imgur.com/ebBbCip
KK75 Keyboard kit Album: https://imgur.com/a/4FVnEHa
Join our discord server here.
Spec:
Aluminum 6063
Type-C
Wired
Single backlight (Need to purchase and install switch LED yourself)
KK75 Software
-Remap keys
-Macro
-Musical rhythm
Keyboard Angle: 4 degrees
Keyboard size: 327 * 170 * 32mm
Weight of the kit: 1.6 kg
The standard kit comes with:
Aluminum alloy case * 1 (top mount)
Non-hot-swap PCBA * 1
Aluminum Plate * 1
PCB Mounted Stabilizers
Default or custom name badge (PVD brass, shiny, screwed in, Size: 45.2*23.6 mm)
Price: US$170 + US$40 ( International DHL express) + PP fee. All prices included when placing order.
GB Open: June 12, 2020 – June 30, 2020.
MOQ: Already met at this moment in a small GB, so it’s not a problem
Estimated Delivery: Middle September 2020
Add on explanation
1. Upgrade Brass Plate: US$19.99 (No aluminum plate, but only one brass plate )
2. Extra Brass Plate: US$27.99 (One more brass plate plus aluminum plate / upgrade brass plate)
3. Extra PCB: US$29.99
Pls check and follow Custom name badge (PVD brass, Shiny) guide
1. Leave a note of the name badge option when placing order.
Option A: default letters “KK75”
Option B: custom to letters you want. No extra cost.
Option C: custom to image with extra US$10 (need to add “image name badge to cart”)
Option D: leave name badge blank
2. Send us JPG/PNG file with your order number (Order 8765 for example).
Filename: “Order 8765 custom name badge. jpg”
Email Subject: Order 8765 custom name badge
Email to: leonor@velocifiretech.com
If you have any questions, please feel free to comment. Thanks for everyone's support!
« Last Edit: Thu, 22 October 2020, 04:55:37 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] KK75 KEYBOARD KIT
« Reply #1 on: Wed, 17 June 2020, 07:35:19 »
Approved
Offline john08099
  • Velocifire MK
« Reply #2 on: Thu, 18 June 2020, 09:04:05 »
Offline oom
« Reply #3 on: Fri, 19 June 2020, 04:04:47 »
The price on this is pretty great. Almost like I feel there has to be a catch. Probably gonna pick one up.
Offline john08099
  • Velocifire MK
« Reply #4 on: Mon, 29 June 2020, 04:09:09 »
Thanks  :thumb:
Offline kickaboob
Re: [GB] KK75 KEYBOARD KIT Left 2 days
« Reply #5 on: Mon, 29 June 2020, 13:00:59 »
Would be interested if there was QMK supported.
Offline parablol
« Reply #6 on: Mon, 29 June 2020, 15:36:53 »
This is a beautiful design
Offline john08099
  • Velocifire MK
« Reply #7 on: Mon, 29 June 2020, 21:54:10 »
  it's a pity. We need to reach 100 MOQ for QMK.
