Author Topic: [IC] SP SA Carbon R3  (Read 59919 times)
Offline Argan12345
Re: [IC] SP SA Carbon R3
« Reply #100 on: Tue, 25 August 2020, 10:42:44 »
Did you really drop the windowed caps for the lock keys? I can't believe it.
Offline xzaclee
« Reply #101 on: Fri, 04 September 2020, 19:19:43 »
when can we put our reservations down?
Offline cijanzen
« Reply #102 on: Fri, 04 September 2020, 19:20:32 »
Probably November 2020
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« Reply #103 on: Sat, 05 September 2020, 09:31:18 »
Update
- Added new kits
Bones Modifiers kit
Bones Numpad kit
Rolling Bones
Ergodox kit
Exactly. Most probably it will drop in November 2020.
Offline IOVERCALLHISTIOCYTES
« Reply #104 on: Sat, 05 September 2020, 09:48:22 »
The greatest child kit in the history of caps returns
Offline hottrout
  • I'd Hit Dat Key
« Reply #105 on: Sat, 05 September 2020, 09:50:22 »
Really love all of the mats.  Might have to buy one of each.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline Capsy
« Reply #106 on: Sat, 05 September 2020, 10:06:41 »
Yesssssss bone base
Offline UggNot
« Reply #107 on: Sat, 05 September 2020, 12:09:41 »
Some comments on the ergo kit.
First let me say that i understand that this is an SA profile which will not lend itself to the flexibility of a KAT kit, but a fair amount of research has been done recently into what the key layout of an ergo KAT kit should be.
Now my notes on this ergo kit.
1. it may need some extra R3 1.5u keys.  As it is, if you are a user of a boardwalk, sol, zen, mun (or a few other boards i can't think of right now), you will have to use all 4 of the R3 1.5u mods as the bottom row of those boards has 1.5u corners.
2. doesn't the alphas kit come with a 1.5u pipe/backslash key?  that shouldn't have to be in this kit.
3. an r1 1.5u tilde key would be a nice addition for those of us who DON'T put escape on the top row. (I believe it is becoming more common to move it from there)
4. an r3 1.5u enter key would also be very welcome as a number of people replace the quote key with enter. and some people (like me, put enter on the bottom row)
5. an r3 1.5u function/layer key is VERY common in place of caps lock.  (personally i use escape on r3 but i overload it with a layer so function works for me)
You should at least take a look at the KAT ergo guide (https://geekhack.org/index.php?topic=105714.0)  put together by NoPunIn10Did.  He did a lot of research on ergo layouts for that guide.
Another note is that on a number of ergo boards (that are NOT the ergodox) the center columns can be 4 1u keys instead of a 1u and 2x 1.5u vertical keys.  I'd love to see that considered here, but i get it if that's just too many keys, I almost never have those columns in the right profile anyway and they vary a LOT with personal preference.
As for what would make this an ideal ergo set for ME (i use an RGBKB sol and RGBKB sol2):
* add r1 1.5u tilde key (my upper left 1.5u)
* remove r2 1.5u backslash/pipe key
* add r3 1.5u escape key (function or layer would do in a pinch)
* add r3 1.5u enter key (my bottom right corner is enter.)
* add an extra r3 1u alt key (i have 2 in my bottom row)
* add an r3 1u delete key (i have one on my bottom row)
* add an r3 blank or 2 for really bizarre layouts (my bottom row has an extra .> key which i don't expect ANY keyset to match)
and in my DREAM set, there would be an R1 1u print screen, R2 1u F5 key, R2 1u pause/break key, R3 Insert key, and R4 delete key, in addition to the notes from above.
I'm not sure about usage of the upper keys on the thumb cluster of an ergodox as i haven't used one, but is it common for the thumb clusters to BOTH have ctrl and alt?  Also, does the top row of those clusters need to be R2?  If it was R3 there would be a lot more flexibility in the kit.
If you've read this far I'd also like to say that since before i got my first keyset, SA Carbon has been one of the sets that interested me the most, and i've always particularly liked how it looks on ergo boards.
Thanks for reading my ramblings.
Offline Morgan3Wheeler
« Reply #108 on: Sat, 05 September 2020, 12:15:48 »
Could you add R4 2U'shift' for 60% with Arrow?
KMAC Happy red HHKB / KMAC Mini red / KMAC 2 86 / 45-ATS cerakote white / Matrix Noah avocado green / Matrix2.0 WKL yellow / Matrix2.0 WKL red / Matrix2.0 add WKL / Matrix Abel X RX-78 / Matrix Abel X Eva / Matrix1.2 OG WKL purple blue / Percent BOOSTER yellow /  Percent CANOE yellow / Percent Canoe2 casio / Percent SKOG mao / TGR 910 CE pink / TGR Jane CE WKL olive green/ TGR Jane V2 WKL blue gray/ TGR Jane V2 CE WKL / TGR Alice red / Keycult No. 2 Rev. 1 / EXENT65 black / GRAYCOD 67 mao / CA66 e-white / Think6.5 V2 LE / Think6.5 V2 robocop / Think6.5 V2 snow white / SPACE 65 R1 black / Typewriter68 e-white/ E6.5 pc / E7-V1 mao white/ E8.5 WKL e-white/ Voclano660 e-white / Moon by EVE WKL carbon / JER-Mini gray / JER80S NCR WKL geekhack / JER80S NCR WKL Korean / Dolumina65 black / Elephant S7 R2 e-white / Bear 65 ergo e-white, black, blue, pink, PC / Fox key65 e-white / Cyberboard purple / Saturn-60 moondust / Saturn-60 supernova / Infinitum / Rama M65a e-white / Rama Jules navy / Rama Zenith ouro / Rama U80-A Seq2 soya / Primus75 / 7V blue / / Cajal gray / Cajal e-white / SQUARE.X 6ea / Time 80 Reforged WKL e-white / J-01 rev1 Black / J-02 LE Poker e-white / OTD 356 Mini R1 red / LZ-CE red / LZ-CE gray / LZ-CLSms silver/ LZ-PhysiX gray / LZ-SQ SE titan gray / LZ-EX titan gray /  LZ-ST silver / LZ-FE WKL silver/ LZ-CLS WKL silver/ LZ-CLS WKL black / LZ-MP gray / LZ-MX SE titan gray / LZ-CP black-blue / LZ-CP red-red SE / LZ-RV gray / Light Pad silver / Light Pad gray / Octagon V2 gray / Orion V2 WKL silver-red / Orion V2.5 WKL gray / Dol Pad dolch / Dolinger 2017 dolch / Dolinger RE yellow/ Dolinger RE PC / Whale-Fe / Dolphin V3 dolch / Montage PC WKL / F1-8X WKL gray / F1-8X WKL navy / F1-8X WKL burgandy / AL.BOK WKL silver
Offline blutoin
« Reply #109 on: Sat, 05 September 2020, 12:57:26 »
really love the bone kits,I'm in !
Offline gaustin
« Reply #110 on: Sat, 05 September 2020, 17:43:09 »
Thank you so much for the bone kits! Seriously. So excited.
Offline Preußens Gloria
« Reply #111 on: Sat, 05 September 2020, 19:43:34 »
Could you consider adding a NorDe kit similar to the one offered in SA Skywriter?
I understand you are apprehensive because of the history of NorDe and ISO kits not hitting MOQ. I ask because SA Skywriter had a smaller following than SA Carbon, yet this kit hit MOQ naturally. This kit drops the tertiary legends many international layouts have for a smaller, cheaper kit. I think this strikes a good balance between providing international support and making a kit that can reasonably be expected to hit MOQ.
I also happen to think losing tertiary legends is more aesthetically pleasing on SA keycaps. They are too cluttered otherwise. :)
Credit to cijanzen for the kit. I claim no ownership, but I love your work!
Offline pcire
« Reply #112 on: Sun, 06 September 2020, 01:58:51 »
Thanks for adding the Bone kits!
Offline Gimbal
« Reply #113 on: Sun, 06 September 2020, 04:41:05 »
Yes pretty PLEASE!
Especially now that the bone modifiers are in.
Light Alphas and Bone modifiers in SA are on top of my most wanted kits list. But I do need the Norde kit for a complete keyboard. It would be beautiful.
Offline T0mb3ry
    • Flickr
« Reply #114 on: Sun, 06 September 2020, 10:43:50 »
I will replace the R2 1.5u |\ key with {[ .
For all other points i can not support that. If everyone starts to come with their special layout then its a never ending story. I can only support the default layout (from Infinity Ergodox) with little bit variations which are already included. As alternative you can always use keys from Novelties or Rolling Bones as any key.
Offline violeaf
« Reply #115 on: Sun, 06 September 2020, 11:01:29 »
Any chance of considering a novelty ISO enter?
Offline UggNot
« Reply #116 on: Sun, 06 September 2020, 13:05:54 »
This is fair, the only other consideration I would ask for with this in mind is an R1 1.5u novelty or blank In one of the sets. R1 is the only row I can’t get an alternative to the legends provided.  Alternately include the tilde character as 1.5u in that top row
Offline MKUltraCorp
    • MKUltra Corporation
« Reply #117 on: Sun, 06 September 2020, 13:50:37 »
I fully support all of Uggnot's thorough explanation of why the 'classic' ergo kit is no longer viable in today's ergo environment. Ergodox is no longer the primary target for ergo kits - keyboards like Boardwalk (over 500 sold w/another 600 on order), upcoming Boardrun (400 PCBs on order), Sol/Zen/Pan/Mun (hundreds sold) are your primary customers for these kits. Do some polling or, reference polls that have already been done by others.
251198-0
If designers continue to ignore this quickly growing subset of the community, they will be (and have been) forced to make their own versions to fill the void. Nobody owns colors.
Offline T0mb3ry
    • Flickr
« Reply #118 on: Sun, 06 September 2020, 14:30:19 »
Update
Ergodox kit
- Replaced legends on R2 1.5u from |\ to {[
ISO UK
- Added Bones compatibility keys
Offline LXVRGS
« Reply #119 on: Sun, 06 September 2020, 18:18:19 »
thinly veiled threats of ripping off peoples work is an interesting business tactic, dont you need to be catching up on orders or something.
« Reply #120 on: Sun, 06 September 2020, 19:06:37 »
If a vendor continues to ignore this quickly growing subset of the community, they will be (and have been) forced to make their own versions of foam that actually ship to customers
Offline Vizir
« Reply #121 on: Sun, 06 September 2020, 19:29:17 »
@LXVRGS @IOVERCALLHISTIOCYTES please stay out of this thread if you cannot keep it civil. Your personal attacks have no place here.
@Tomb3ry thank you for adding and then modifying the ergo set when Uggnot posted some suggestions. If you take anything away from mkultra's post, let it be that ergo layout is now outdated since a lot more ergo keebs are out which need a few extra keycaps. He is just telling you that there are LOTS of these users out there and there is a void in the offering. He is merely warning you to not let someone else take this as an opportunity.
KAT designers have enthusiastically started supporting these layouts. And if you check, even Matt3o added support for them with the last run of mt3 /dev/tty. You can also look at the sales numbers of various KAT kits as a reference.
Do not let some toxic members derail the conversation here.
Sent from my Pixel 4 XL using Tapatalk
Offline jorgenslee
« Reply #122 on: Mon, 07 September 2020, 06:26:11 »
Update
- Added new kits
Bones Modifiers kit
Bones Numpad kit
Rolling Bones
Ergodox kit
Can you add an extra R2 TAB in the modifier kit? The modifier kit can support TKL and HHKB layout which could be a plus for users who use both layout or for those looking to split it to their friends.
Offline T0mb3ry
    • Flickr
« Reply #123 on: Mon, 07 September 2020, 06:40:25 »
Update
- Added new kits
Bones Modifiers kit
Bones Numpad kit
Rolling Bones
Ergodox kit
Maybe in some sort of extra kit. Otherwise people will be forced to buy two tab keys and that will rise many questions during GB.
Offline T0mb3ry
    • Flickr
« Reply #124 on: Mon, 07 September 2020, 10:48:20 »
Update
Ergodox kit
has been changed to assembly style which is more versatile and cost effective.
Offline Vizir
« Reply #125 on: Mon, 07 September 2020, 10:53:41 »
Update
Ergodox kit
This makes a lot of layouts a lot easier!
Can you please add 2x 1.5u R3 for the bottom row outermost columns? Oblotzkys oblivion set had the same issue.
Offline T0mb3ry
    • Flickr
« Reply #126 on: Mon, 07 September 2020, 10:55:12 »
Update
Ergodox kit
Yeah I thought about it already and will look into it.
Offline konstantin
  • Formerly constexpr
« Reply #127 on: Mon, 07 September 2020, 11:48:03 »
An extras kit like in GMK Yuri R2 would be nice to see.
Offline MKUltraCorp
« Reply #128 on: Mon, 07 September 2020, 13:03:33 »
Update
Ergodox kit
This solution solves a lot of issues, thank you for looking into it and making adjustments - a lot of ergo customers will be happy to see this flexibility.
The only thing it could use are those bottom row R3 1.5u keys as well as some solution for middle column 1u keys. Not everyone uses vertical 1.5u on their middle columns and some ergo boards flat out don't support it - hotswap Boardwalk (releasing this week) is 1u only for example, as well as others.
I appreciate you taking the time to dig into a layout I'm guessing you don't use and have to rely on feedback to get right. We just want to make sure designers are aware that the ergo landscape is and has been changing, and the old 'classic' layout is no longer sufficient to meet the needs of current trends and usage. What you do with that information is up to you, so thank you for listening.
Offline jmg123
« Reply #129 on: Mon, 07 September 2020, 14:36:52 »
Update
Ergodox kit
ISO UK
Thank you for the proper uk ISO support (my wallet does not thank you, as now I will be forcing it to pay for bones as well)
Offline nhtrung0607
« Reply #130 on: Tue, 08 September 2020, 10:28:30 »
I would really appreciate if you can add  "Page Up" R3 for the modifer kits just like in Round 2. Thanks alot.
« Last Edit: Tue, 08 September 2020, 10:31:36 by nhtrung0607 »
Offline T0mb3ry
    • Flickr
« Reply #131 on: Wed, 09 September 2020, 12:18:50 »
Update
GB will probably happen in October
Basically next month.
Bones Modifiers kit
- Added three bones alpha accents. Since Bones modifiers has less keys than other two modifier kits, this will make its pricing more even.
Ergodox kit
- Added two 1.5u R3 LOOP keys.
Xtra kit
- Introduction
Offline konstantin
« Reply #132 on: Wed, 09 September 2020, 14:32:41 »
Xtra kit
- Introduction
Lovely, thanks!
Offline nethowler
« Reply #133 on: Wed, 09 September 2020, 16:51:38 »
Super excited for this.  Any idea on price?
Offline nhtrung0607
« Reply #134 on: Wed, 09 September 2020, 22:55:47 »
Update
Bones Modifiers kit
Ergodox kit
Xtra kit
- Introduction
Thanks alot for the extra kit. Can't wait for the GB.
Offline Gimbal
« Reply #135 on: Thu, 10 September 2020, 02:55:11 »
Now that the GB has grown to include loads of special kits why not also add a small NorDe kit, perhaps one identical to SA Skyriter as Preussens Gloria suggested?
I promise, this is the last time I ask for it.  :-X
Offline aterix
« Reply #136 on: Thu, 17 September 2020, 11:55:01 »
Sign me up!
I honestly can't find a better looking set of caps.
Offline smoochara
« Reply #137 on: Fri, 18 September 2020, 10:24:25 »
Made an account here just to say that I also find this to be the best looking keycap set overall and cant wait to buy it!
Anyone with experience from R1/R2 has any input on best case color pairing with this set?
I got black keeb so far but will be expanding in the future. White would be another safe choice I guess, and orange could work but could be weird if not color matched to caps well. Any other case colors that really pop with this?
Offline T0mb3ry
    • Flickr
« Reply #138 on: Fri, 18 September 2020, 10:34:12 »
Kits are finalized!
We are looking right now for the optimal pricing. Thus the kits are finalized and there will be no changed unless we'll encounter some errors in the kit constellation.
As i said previously the GB will happen during this October.
Offline aterix
« Reply #139 on: Fri, 18 September 2020, 11:05:38 »
Wooo! Go T0mb3ry!
Looking forward to finally using these timeless classics.
Offline ChrisJoy
« Reply #140 on: Fri, 18 September 2020, 20:37:52 »
Wooo! Go T0mb3ry!
Great! Look forward to it badly!!!
Offline aterix
« Reply #141 on: Sat, 19 September 2020, 08:35:37 »
Update
- Added new kits
Bones Modifiers kit
Bones Numpad kit
Rolling Bones
Ergodox kit
Would you ever consider making these in a low profile cap format?
Offline T0mb3ry
    • Flickr
« Reply #142 on: Sat, 19 September 2020, 09:46:21 »
I am only interested in Cherry profile made by GMK. Someday there will be another round for GMK Carbon. I don't have interest for other profiles.
Offline BachNgocLaoHo
« Reply #143 on: Mon, 21 September 2020, 01:07:38 »
I really really love SA SP Carbon from you - Mr T0mb3ry. Currently, I am collecting a full set of Carbon round 2, which is missing flex kit and number row kit. I see that round 3 does not include these two kits. Can you review and add these two kits, I am willing to pay for that, everyone will agree with me on this !! plz
Offline aterix
« Reply #144 on: Mon, 21 September 2020, 09:10:46 »
T0mb3ry has explained why he's not doing a full set.
Personally, the sets he is making fill much more than my needs.
What is specifically missing that you need, or do you just want to have more keys in your key museum?
« Reply #145 on: Mon, 21 September 2020, 20:53:51 »
I really like to put the kits together. This will create visual effects - the inspiration at work for me.
Offline Vizir
« Reply #146 on: Tue, 22 September 2020, 00:40:39 »
I can't claim to understand genius or inspiration but that makes little sense here in business terms. Not that I want to belittle you, perhaps you are looking for inspiration in the wrong area.
Or, perhaps, you might want to explain in other words? I can see that english isn't your native tongue...
« Last Edit: Tue, 22 September 2020, 00:42:55 by Vizir »
« Reply #147 on: Tue, 22 September 2020, 01:33:45 »
Yes, my english is not good, can not to explain clearly what i mean. But SA Carbon always is my favourite keyset. I like to collect all kits possibly, then mix them, waiting to look at them when going to office. :)
Offline T0mb3ry
    • Flickr
« Reply #148 on: Tue, 22 September 2020, 01:35:35 »
Hello,
this IC is open since July and there was plenty of time to make suggestions. Right now the kits are final and will stay as they are. We requested already the quotes and are preparing for the gb.
Also as i understand you want that kit in order to complete your R2 Carbon and thus i like to quote myself where i explain - why its better to get original R2 kits.
Important Info
The colors will stay the same.
However if someone wants to mix R2 with R3, when one should be aware of possible shade differences which might happen - because SPs plastic supplier is notorious for inconsistency from batch to batch. As example see SP SA Strong Spirit, which was made from different plastic batches and has noticeable shade differences. As another example my alphas from Carbon R1 and R2 differ slightly in shade too. Because of this i specifically pointed out for Yuri to make it from one single plastic batch and did not introduced glorious keys for other existing SP SA sets.
So it should be avoided to mix keys from R2 and R3 with the same base color. For example mixing R2 mods with R3 mods. But things like mixing Alphas/Dual Alphas from R3 with Mods from R2 should work just fine. Anyway i highly suggest for someone who is missing a kit from R2 to search for it on mechmarket. AFAIK finding most of the R2 kits on mechmarket should not be a problem.
« Last Edit: Tue, 22 September 2020, 02:03:11 by T0mb3ry »
« Reply #149 on: Tue, 22 September 2020, 03:58:33 »
Hello,
Important Info
Thank you Sir!
