Author Topic: Cheap hotswap pcb?  (Read 2516 times)
Offline Walshware
Cheap hotswap pcb?
« on: Fri, 10 July 2020, 20:17:02 »
Hello :) I think this is where I should post this. I am looking to test out a bunch of switch variations and a switch tester just isn’t quite enough; so I was wondering if there is somewhere I can buy a hotswap pcb for relatively cheap that works. Preferably works with both choc low profile and normal mx style (not sure if thats even possible)
Offline Leslieann
Re: Cheap hotswap pcb?
« Reply #1 on: Fri, 10 July 2020, 20:43:37 »
Doing both is not possible.
As for cheap, check out the GMMK, you can get it without switches or caps. You might find a pcb for a few bucks cheaper but not by much and this way you get something you can actually use.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Walshware
« Reply #2 on: Fri, 10 July 2020, 20:57:56 »
Thank you :)
Offline Reimu_64
    • KeebWorks
« Reply #3 on: Mon, 13 July 2020, 08:45:03 »
You should also check out the GK61 (non-optical version). It's similar to the GMMK, but it supports PCB mounted switches instead of just plate mounted ones. It's also significantly cheaper iirc.
