Author Topic: [IC] GMK Norse | GB March 2-30 / Final Kits and Pricing!  (Read 235524 times)
Offline Tyson
Re: [IC] GMK Norse
« Reply #50 on: Fri, 24 July 2020, 14:16:24 »
Offline Skok
Re: [IC] GMK Norse
« Reply #51 on: Fri, 24 July 2020, 14:28:05 »
Geekhack keeps giving me a 413 error resulting in my IC to not have pictures. Should be fixed now
Sent from my SM-G975U using Tapatalk
Offline KeebOnMe
Re: [IC] GMK Norse
« Reply #52 on: Fri, 24 July 2020, 14:59:58 »
Love the base and spacbar, can't wait to see what other concepts you come up with.
Offline Skok
Re: [IC] GMK Norse
« Reply #53 on: Fri, 24 July 2020, 15:11:56 »
Submitted a form but thought I'd mention it here:
How would you feel about having more novelties which relate to viking combat? I personally would have to have a selection of novelties for things like weapons (swords, axe, bow etc.) a shield, a helmet. The novelties for the gods are great. I think that would be pretty cool.
Also, one last thing: This may get hated on...but I personally love sublegends. I think having a set with Latin Alphas and Rune sublegends would be sick! Please consider it as an add on...or even the base set if popular enough!
Hope you'll consider the suggestions and love the colour scheme personally, I reallt hope it goes through to GB.
I am considering adding a few more novelties including weapons of some sort. As for my response for the Rune alphas/sublegends. Since this is GMK they would have to make new molds for each sublegend which would be incredibly expensive. I would also have to go in and design them from the ground up to avoid any licensing/copyright issues. Now I am not opposed to it completely but a lot more work needs to be done before I go all in on the idea. Based on the responses in my IC form I'll look into it. Thank you!
Offline Sabin
Re: [IC] GMK Norse
« Reply #54 on: Fri, 24 July 2020, 15:34:41 »
Awesome looking forward to seeing the new novelties. Ah I understand. I would be interested in paying more for them as it'll make it a truly unique set, but understand if it is not feasible! Appreciate the reply.
Offline Skok
Re: [IC] GMK Norse
« Reply #55 on: Fri, 24 July 2020, 16:14:48 »
Thank you! Make sure to come back in the next week or two as I'll be making changes based on community feedback.
Offline konstantin
  • Formerly constexpr
Re: [IC] GMK Norse
« Reply #56 on: Fri, 24 July 2020, 17:47:55 »
It's recommended to use Imgur (or another image hosting service of your choice; Imgur has some limitations) rather than upload images directly to Geekhack. It makes the browsing experience better on both desktop and mobile (Tapatalk).
Offline konstantin
Re: [IC] GMK Norse
« Reply #57 on: Fri, 24 July 2020, 18:01:41 »
Suggestions for the updated base kit:
  • Change second R4 1u Ctrl to Alt — one of each is required.
  • Change Prt Sc to Print — looks cleaner.
  • Change R3 1u #~ to \|.
  • Change R4 1u <>| to <> (remove sublegend).
  • Remove R4 1u \| — only one R4 ISO key is needed.
  • Add R3 Pg Up, R4 Pg Dn — extended 65%/75% support for some popular layouts.
  • Add R4 1.75u Shift — required for many different layouts, a must.
  • Add mod-colored R2 1.5u \| — alternative to regular \|, similar to mod-colored `~.
  • (optional) Change Scroll↲Lock to Scroll or Lock, and Num↲Lock to Num — looks cleaner.
Offline Skok
Re: [IC] GMK Norse
« Reply #58 on: Fri, 24 July 2020, 18:07:07 »
Making these changes as we speak. Thank you
Offline Skok
Re: [IC] GMK Norse
« Reply #59 on: Fri, 24 July 2020, 21:42:01 »
Omg, this is my dream set. Please, introduce runic keycaps! I am begging you.
Updated IC. Runic caps are being designed as we speak.
Offline Stanley.Bishop
Re: [IC] GMK Norse
« Reply #60 on: Sat, 25 July 2020, 02:24:42 »
Was going to propose runic caps, but I see that somebody already did.
Also would you consider novelty cap for a spacebar?
Offline Sabin
Re: [IC] GMK Norse
« Reply #61 on: Sat, 25 July 2020, 04:52:34 »
I know you're working hard on the Rune alphas/sublegends but also thought I'd suggest a rama cap if it's something that interests you and others?
Offline Eagle Bearer
Re: [IC] GMK Norse
« Reply #62 on: Sat, 25 July 2020, 06:32:18 »
Count me in! Though I would really like an extra B in the spacebars set for alice-layout compatibility.
Offline Skok
Re: [IC] GMK Norse
« Reply #63 on: Sat, 25 July 2020, 08:36:08 »
Yeah I would for sure be interested in a RAMA collab. From what I have heard you need a full list of vendors before they work with you. But I will definitely try to make that happen!
Offline Nudd
Re: [IC] GMK Norse
« Reply #64 on: Sat, 25 July 2020, 10:17:25 »
Very nice
Could you sort your pics though, two base kits showing different keys :P
If this has full UK ISO i'm in.
Love that rune mat, may have to get a spare or two :)
Offline Skok
Re: [IC] GMK Norse
« Reply #65 on: Sat, 25 July 2020, 10:59:00 »
Very nice
Yeah I gotta edit it when I get back home from work tonight. Sorry about that. I was fixing the ISO support and forget to remove the old image. Thank you and theres another deskmat in the works!
Offline Nudd
Re: [IC] GMK Norse
« Reply #66 on: Sat, 25 July 2020, 11:09:50 »
Very nice
Skál!
Offline kai0
Re: [IC] GMK Norse
« Reply #67 on: Sat, 25 July 2020, 11:18:46 »
100% following this.  :eek:
Offline Techlet
Re: [IC] GMK Norse
« Reply #68 on: Sun, 26 July 2020, 15:02:37 »
Am I missing something obvious or is there still not a 1.75u Shift in the updated base kit?
I see 1.25u, 1.5u, 2u, and an extra 2.25u, but no 1.75u.
Offline konstantin
Re: [IC] GMK Norse
« Reply #69 on: Sun, 26 July 2020, 15:32:07 »
Looks like it. 1.5u should be replaced with 1.75u.
Offline Owl-
Re: [IC] GMK Norse
« Reply #70 on: Sun, 26 July 2020, 15:40:20 »
Need novelty that says Valhalla to replace capslock. In Latin or Runes
Capslock novelty is hella underrated. Just saying..
Offline lazergician
Re: [IC] GMK Norse
« Reply #71 on: Sun, 26 July 2020, 17:18:09 »
Oh man, I need to be pretty conscious with my wallet these days but for the right price I'd jump on these for sure. One of my favorite themes for sure and I love the colors. I'd likely rock it with the grey spacebar and green return, personally. Great work here.
Offline juice_pouch
Re: [IC] GMK Norse
« Reply #72 on: Sun, 26 July 2020, 17:40:44 »
No gold 7U spacebar in the base kit?
Offline Skok
Re: [IC] GMK Norse
« Reply #73 on: Sun, 26 July 2020, 21:17:04 »
hmmmmmm. duly noted
Offline Skok
Re: [IC] GMK Norse
« Reply #74 on: Sun, 26 July 2020, 21:23:11 »
I can't believe I messed that up again. I thought I had it right. I was stuck at work all day. I'll go back in tomorrow and fix it as well as clean up the rest of the IC.
Offline kiwoli
Re: [IC] GMK Norse
« Reply #75 on: Sun, 26 July 2020, 22:24:19 »
As it looks in the renders, love the colour combo in this set.
I understand the complexity of going by rgb images on a monitor, however, I have a few question marks on whether the RAL colours are quoted/rendered correctly?
  • 9004 & 7040 looks warmer than the actual colour?
  • Is the accent colour meant to be RAL 60 50 10? Saturation looks light
Offline Skok
Re: [IC] GMK Norse
« Reply #76 on: Mon, 27 July 2020, 11:24:15 »
Good catch. Will fix in next update
Offline Sabin
Re: [IC] GMK Norse
« Reply #77 on: Mon, 27 July 2020, 18:13:32 »
Regarding the Jult 26th Update: "Runic Alphas are in the works"
Does that mean no Runic sublegends on the Latin alphas?
Offline Skok
Re: [IC] GMK Norse
« Reply #78 on: Mon, 27 July 2020, 18:32:49 »
Both are in the works, when those are finished and the IC is a bit more polished I'll make a post on reddit to drive more people to this thread fill out a form deciding between the alphas vs subs.
Offline Sabin
Re: [IC] GMK Norse
« Reply #79 on: Mon, 27 July 2020, 18:52:51 »
Ah okay, sounds good!
Offline iwanoo
Re: [IC] GMK Norse
« Reply #80 on: Tue, 28 July 2020, 09:16:55 »
Can't wait to see how the runic alphas will turn out! Is there any plan for ortho/obscure kit?
Offline Skok
Re: [IC] GMK Norse
« Reply #81 on: Tue, 28 July 2020, 09:49:12 »
To be honest I'm not sure yet. The google form I posted has had a 80/20 split between not having ortho versus having it. It was 138 who said no to ortho/40s and 31 that said yes. Once I get the Runic alpha renders, I'm going to post on Reddit to hopefully drive more people to fill out the form so I can get a better idea.
Offline BapoDonu
Re: [IC] GMK Norse
« Reply #82 on: Tue, 28 July 2020, 10:24:57 »
Desk mat reminds me of a song i used to listen when i was younger
Would you consider a white on black variant ?
Offline Skok
Re: [IC] GMK Norse
« Reply #83 on: Tue, 28 July 2020, 10:36:46 »
I was considering a black deskmat with beige text. to match the accent color
Offline dantambok
Re: [IC] GMK Norse
« Reply #84 on: Tue, 28 July 2020, 10:38:07 »
i like it!
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline Skok
Re: [IC] GMK Norse
« Reply #85 on: Tue, 28 July 2020, 10:41:25 »
i like it!
Thank you! Stay tuned for Runic Alphas!
Offline ebastler
Re: [IC] GMK Norse
« Reply #86 on: Tue, 28 July 2020, 12:27:14 »
The fact that you rendered the Isometria in isometric projection is honestly an amazing play on words.
Pretty set, I really like both the colors and the fact that you offer a NorDe set (well, would be kinda odd not to include scandinavian layouts in a scandinavian themed set^^).
Best of luck with the IC, and I hope to see this in GB soon  :thumb:
Offline Skok
Re: [IC] GMK Norse
« Reply #87 on: Tue, 28 July 2020, 12:33:03 »
Haha I wasn't thinking that when I did it. Also thank you for making the render files available, the set looks fantastic on your case!
Offline ebastler
Re: [IC] GMK Norse
« Reply #88 on: Tue, 28 July 2020, 12:52:30 »
It really does, one of the best fitting GMK sets I've seen so far! May I post them over in my project thread? (or do you wanna do it yourself?)
No problem, It makes me happy see people actually use my design for renders. Great feeling to see others appreciate your work.
I just hope I'll get the prototypes done soon-ish. I really wanna see the board outside of renders ._.
Offline rezachman
    • reza h
Re: [IC] GMK Norse
« Reply #89 on: Tue, 28 July 2020, 19:08:27 »
Hope it'll be a deskmat for this, with a green accent
« Last Edit: Tue, 28 July 2020, 19:17:27 by rezachman »
Offline Skok
Re: [IC] GMK Norse
« Reply #90 on: Tue, 28 July 2020, 19:28:08 »
Yeah post them. Sounds like a win win for the both us. Thank you!
Offline VagueOrigin
Re: [IC] GMK Norse
« Reply #91 on: Thu, 30 July 2020, 20:00:17 »
Can't wait for this one, already planning around it
Offline ideus
  • Björkö.
Re: [IC] GMK Norse
« Reply #92 on: Thu, 30 July 2020, 20:46:30 »
The 6u space bar is off centered right? I mean, it should support all the 1800's out there.
Offline surreal19
Re: [IC] GMK Norse
« Reply #93 on: Thu, 30 July 2020, 20:53:43 »
can we get a canadian vendor when gb is ready :)
Offline Skok
Re: [IC] GMK Norse
« Reply #94 on: Thu, 30 July 2020, 21:02:23 »
There is one already! Will announce vendors soon once I finalize everything.
Offline phedd
Re: [IC] GMK Norse
« Reply #95 on: Thu, 30 July 2020, 22:25:15 »
I'd really avoid using the valknut since it's so associated with nazis. Sad, but true.
Would it even be legal for GMK to produce that in Germany? "Hate symbol".
Yeah, we can try to reclaim it as a normal symbol but come on.. is this the time and place? Same as like the swastika isn't inherently a nazi symbol but that's what people associate it with.
Otherwise you might as well throw in the Odal rune and everything...
Great otherwise. I'd change / to ÷ on the numpad, especially since that's the symbol used in the Nordics.
And personally I don't think a down arrow for Caps Lock makes any sense. That would be like the symbol for "Lower Case Lock". But that seems to be only me. Text would be more in line with what's traditionally used on Caps Lock in the Nordic countries (the rest of the modifiers are "traditional" so having just Caps Lock be the odd one out seems like a missed opportunity). Or this:
« Last Edit: Thu, 30 July 2020, 22:32:12 by phedd »
Offline Skok
Re: [IC] GMK Norse
« Reply #96 on: Thu, 30 July 2020, 22:41:43 »
You bring up a good point. I had some premonitions about including it but I thought that since this is a Norse themed set with symbols representing their beliefs/culture that it would not be taken out of context in that way. I'll axe it, pun intended, and replace with a different novelty. Also if you take a look at GMK Icon mods the caps lock is typically a downwards arrow, therefore I included it in my set. Thanks for the feedback!
« Last Edit: Thu, 30 July 2020, 22:43:31 by Skok »
Offline konstantin
Re: [IC] GMK Norse
« Reply #97 on: Fri, 31 July 2020, 07:37:51 »
As far as I know, all modern PCBs with 6u space (1800, 66-key, 60% etc.) support at least centered stem, but not all of them support off-centered stem. The reverse is true on OG 1800 Cherry PCBs, but probably not much else. Ideally the kit would include both 6u options, but if there's only room for one, I think centered stem is better.
Offline konstantin
Re: [IC] GMK Norse
« Reply #98 on: Fri, 31 July 2020, 07:41:24 »
Down arrow Caps Lock is a good choice, not because it makes any sense (spoiler: it doesn't), but because it's a versatile, fairly generic-looking icon that can even work as Fn or Ctrl in a pinch.
Don't forget to also change * to × in this case.
« Last Edit: Fri, 31 July 2020, 07:54:03 by konstantin »
Offline hallzy
Re: [IC] GMK Norse
« Reply #99 on: Fri, 31 July 2020, 08:19:40 »
Any chance for UK ISO to be included in base??? What a set, well done
