Author Topic: Lubing gateron clears  (Read 3289 times)
Offline Merranza
« on: Wed, 05 August 2020, 08:41:49 »
I have some extra gateron clears laying around. I have never lubed switched before so it would be a first to me. Since they are pretty cheap and easy to find, I think they would make a good first attempt in case I mess them up.
is it a good idea to lube gateron clears though? Since they are so light, would I see any benefit in lubing them? Would they even become "too fluid" to use?
I'm in the process of understanding the method/type of lube also so any advice in that matter is really appreciated.
Offline treeleaf64
    • treeleaf64
Re: Lubing gateron clears
« Reply #1 on: Wed, 05 August 2020, 10:39:44 »
Thin lube good
Thick lube cause problems on light spring
205g0 may not work
U should try Trybosis 3203 maybe , or krytox  103, 104 , 105
~ ~ ~ tree leaf ~ ~ ~
Everyone must pay the cat tax
Offline Merranza
« Reply #2 on: Wed, 05 August 2020, 11:00:20 »
Thin lube good
205g0 may not work
Amazing thanks!
Should I apply this principle (thin lube on light spring) for tactile switches also or does this mainly apply to linear?
Offline Leslieann
« Reply #3 on: Wed, 05 August 2020, 23:12:24 »
Do NOT lube the legs, that will make them linear.
What you lube the spring itself with matters little.
Thin lube on light springs is for the sliders, anything thick will make them sluggish. With thick springs you can use thicker lube on the slides and not notice.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline pixelpusher
« Reply #4 on: Thu, 06 August 2020, 00:10:38 »
Strange as it seems, gateron clears are actually linear.  An ultra light linear switch.
Offline Leslieann
« Reply #5 on: Thu, 06 August 2020, 00:35:20 »
Ahh okay, I really hate how it's become the wild west in terms of color codes.
In which case, lube the legs.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
