Author Topic: Solder pads seem to be gone, best fix?  (Read 1347 times)
Offline Bulliba
« on: Thu, 13 August 2020, 10:17:38 »
I noticed the \| switch isnt working so I took the board apart and desoldered the switch, looks like this underneath. What would be the best fix? I can't activate the key using tweezers either. I've briefly read about bridging but I'm not sure what I would bridge it to in that case.
Re: Solder pads seem to be gone, best fix?
« Reply #1 on: Thu, 13 August 2020, 10:40:00 »
The bottom pad goes to the top of the diode labeled D11, the diodes connect across the rows so I guess the top pad would connect to the top pin of the A switch.  Short the top pin of A to the diode for /| to check before soldering :)
Offline Bulliba
« Reply #2 on: Thu, 13 August 2020, 10:55:55 »
Thank you!  :D
