Author Topic: Spray Lubing Novelkey Creams?  (Read 2716 times)
Offline Rhythm
« on: Fri, 14 August 2020, 12:54:42 »
From past keyboards I spray lubed with SuperLube 31110. Just coming here because I don't know if its different with nk creams with the POM housing. Will it damage the switch?
Offline clik_clak
Re: Spray Lubing Novelkey Creams?
« Reply #1 on: Fri, 14 August 2020, 13:04:59 »
You can go look at the tech specs yourself, but they do say their compatibility with POM is excellent.
Offline Sup
« Reply #2 on: Fri, 14 August 2020, 15:53:52 »
Advise don’t spray lube please apply krytox or other proper lube manually for consistency and not to overlube... i don’t think it will damage it but I heard that people switches are starting to chatter later when the lube dries out.
« Last Edit: Fri, 14 August 2020, 16:44:04 by Sup »
current
Coming soon
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #3 on: Fri, 14 August 2020, 16:05:12 »
Advise don’t spray lube please apply it manually for consistency and not to overlube... i don’t think it will damage it but I heard that people switches are starting to chatter later when the lube dries out.
^^^^ This 100%! I realize you can get away with spray lubing switches, but don't expect the results to stay consistent over time with such a method.
Offline treeleaf64
    • treeleaf64
« Reply #4 on: Fri, 14 August 2020, 21:04:45 »
Tell me how you like that lube . I'm thinking about getting some myself.
Everyone must pay the cat tax
Offline Leslieann
« Reply #5 on: Fri, 14 August 2020, 21:52:29 »
Spray lubing switches is a bad idea.
Spray lube is meant to be used in places where you can use it to flush out contaminants and coat with lube. There's no way to flush out contaminants in a switch without taking it apart.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
