Author Topic: [IC] BOX75: A 75% Keyboard. A Box that Provokes. GB Live!  (Read 107893 times)
Offline dks
« on: Sat, 15 August 2020, 16:03:36 »
    BOX 75
    "A box that provokes."
    dks | Lin Design Studio
    PREFACE
    The BOX75 began as a project to design a keyboard I would use personally.
    The name, "Box", pays homage to a response from Japanese architect Tadao Ando. When asked what architecture is to him, he replied "Chohatsu suru hako," or "the box that provokes"; and the BOX75 seeks to do just that: a black box measuring 20mm thickness lifted by a series of interlocking thin frames.
    The frame as a structural expression that is part of the keyboard also supports the keyboard itself. My hope is that one looks at it and wonders how it comes together.
    SPECS
    • Type Angle: 7°
    • Construction: Top Mount/O-ring Burger Mount. Plate and Case Foam.
    • Case Materials: Anodized or E-Coated Aluminum Body. Mirror-Polished or Black PVD Stainless Steel Accents.
    • Colors: Black, White
    • No External Screws
    • Plate Materials: 1.5mm Aluminum, Black Smoked PC.
    • PCB: Designed by Gondolindrim with QMK/VIA support, ESD protection. Solder only.
    • Layout Supports:
      • 1.25u - 1.25u - 1.25u - 6.25u - 1.5u - 1.5u
      • 1.25u - 1u - 1.25u - 7u - 1.25u - 1.25u
      • 1.5u - 1u - 1.5u - 6u - 1.5u - 1.5u
      • Split Backspace
      • Stepped Caps Lock
      • ISO Support (PCB Only)
    PRICING + GB Live!
    PHOTOS
    RENDERS
    SPECIAL THANKS
    To Gok for the endless deskcrit sessions. Brazilian genius Gondolindrim. Kevinplus for the render comments. Virtual, his kind words and sharing our project. Dan Ringer from Ringerkeys for his support. Geist for all the advice and discussions. The great Kabocha for working on the website together and playing Where's Waldo with me.
    To everyone else who helped make this project a reality.
    Photo Credits to @xrehpargotohp.
    CONTACT
    Instagram: @lin_designstudio
    Discord: dks | Lin Design Studio
    Website: www.lindesign.studio
    [/list]
    « Last Edit: Fri, 22 January 2021, 21:49:14 by dks »
    Offline pngu
    • send noots
    Re: [IC] BOX75: A 75% Keyboard. A Box that Provokes.
    « Reply #1 on: Sat, 15 August 2020, 16:05:35 »
    Ok but where are the renders?
    Offline dks
    « Reply #2 on: Sat, 15 August 2020, 16:06:14 »
    Trouble shooting right now with the links, will fix asap
    Offline DukeEsquire
    « Reply #3 on: Sat, 15 August 2020, 16:09:20 »
    Cool design (saw your photos on Insta).
    Just as a suggestion, you may consider changing the name of your studio to something different.
    There is already a very well known designer that goes by Linworks. Calling yourself Lindesignworks is going to be confusing.
    Offline Bl4ck
    « Reply #4 on: Sat, 15 August 2020, 16:19:59 »
    Depending on the price ofc, I might be up for it! Really looking into different 75s and this looks nice.
    Edit: Ne ISO avail? :S
    « Last Edit: Sat, 15 August 2020, 16:24:51 by Bl4ck »
    Offline dks
    « Reply #5 on: Sat, 15 August 2020, 16:20:54 »
    Images updated. Thank you.
    « Reply #6 on: Sat, 15 August 2020, 16:22:46 »
    It's a really nice and simplistic design as I've seen on your insta. I'm really curious to see how it is built. However 50 units will most likely cause the price of the kit to be very expensive and not sure if i'm willing to spend a lot for this design.
    Offline packman86
    • Morning Coffee
    « Reply #7 on: Sat, 15 August 2020, 16:24:26 »
    This looks so crazy! I love it!
    Good luck with the IC!
    Keyboard Collection:
    TGR Jane V2 | TGR Jane V2 CE | TGR Alice | TGR Dolice | TGR 910 | TGR x Singa UNIKORN 60 | Matrix 8XV 2.0 Korea Version | Matrix 8XV 2.0add | LZ CLS s h x | Duck Jetfire | TX-CP | QXP | Noxary X65 | RAMA M60-A | Model F62 "Kishsaver" | Daji OC 2XL FnF Black
    Offline gok_nz
    • Enjoy your PBT
      • Website
    « Reply #8 on: Sat, 15 August 2020, 16:25:31 »
    Very unique. I love that form and function are related through the stainless steel legs.
    Offline yui_
    « Reply #9 on: Sat, 15 August 2020, 16:26:55 »
    the accent bars are very interesting, it's refreshing actually seeing unique design elements.
    ne iso avail? just on pcb would be fine, and then iso buyers can source own plates.
    glwic.
    Offline pears
    • Sneezing is painful
      • Bad Produce
    « Reply #10 on: Sat, 15 August 2020, 16:47:17 »
    This is a very interesting design!
    Getting punched in the face was the best thing that ever happened to me.
    Offline fishbiscuit13
    • do you realize ???
    « Reply #11 on: Sat, 15 August 2020, 16:50:16 »
    [removed salty emptiness]
    « Last Edit: Sat, 15 August 2020, 16:54:48 by fishbiscuit13 »
    Offline powwu
      • Discord
    « Reply #12 on: Sat, 15 August 2020, 16:52:59 »
    Sections? more like sextions
    Offline dks
    « Reply #13 on: Sat, 15 August 2020, 16:55:56 »
    So you've copied the central element of the Church of the Light, but turned a beautiful expression of negative space into something resembling a coffee table with applied embellishments. I'm not sure what this is supposed to provoke, but I can tell you I don't think Ando would approve.
    Thanks for your comment. The design itself has nothing to do with the Church of light, or Tadao Ando in fact. The mention of Ando only relates to the use of "box". I am glad you are provoked nonetheless.
    Offline dks
    « Reply #14 on: Sat, 15 August 2020, 17:00:36 »
    glwic.
    Thanks for your comments. I will take ISO support into consideration.
    Offline foundpeasantry
    « Reply #15 on: Sat, 15 August 2020, 17:10:39 »
    Will the leg edges be slightly rounded as to not scratch/dig into a desk or deskmat? I like the nice flat even look for the legs but have concerns that if the board was accidentally shifted it would scratch the desk/deskmat.
    Offline FaKe_VirTual
      • Virtual Designworks
    « Reply #16 on: Sat, 15 August 2020, 17:14:54 »
    I love the Design. It''s outstanding in every aspect!
    Offline Bl4ck
    « Reply #17 on: Sat, 15 August 2020, 17:18:41 »
    ORRRR have a rubber end?
    Offline mahpsirhc
    « Reply #18 on: Sat, 15 August 2020, 18:09:02 »
    Really interesting board, interested in joining! There seems to be a layout disperenscy between the renders and the layout photo. The function keys are going to be 1/4/4/4/1 like the renders instead of the 1/4/5/3/1 right? I love how the lines go through the board; the structural expression you mention really sticks out to me.
    « Last Edit: Sat, 15 August 2020, 18:13:47 by mahpsirhc »
    Offline dks
    « Reply #19 on: Sat, 15 August 2020, 19:26:33 »
    Good catch. The function keys will be as the prototype photos and renders. Layout is updated as well. Thank you.
    Offline elkgrove
    « Reply #20 on: Sat, 15 August 2020, 19:32:21 »
    damn this looks clean. i love the stainless steel  :thumb:
    Offline eniigma
      • Storefront:
    « Reply #21 on: Sat, 15 August 2020, 21:40:59 »
    Looks great, love me some stainless!
    Offline kabocha
    « Reply #22 on: Sat, 15 August 2020, 22:12:37 »
    Those angles, those lines. Definitely stands out from the sea of keyboards I’ve seen thus far! Really neat inspiration you drew from the architectural world!
    Offline SlipperyPeteED
    « Reply #23 on: Sat, 15 August 2020, 22:57:08 »
    damn this board reminds me of my uncle
    Offline Jkush463
    « Reply #24 on: Sun, 16 August 2020, 00:49:04 »
    color me interested this is pretty.
    Offline CF73
    « Reply #25 on: Sun, 16 August 2020, 01:28:02 »
    definitely a unique design!
    visually pleasing but might suffer from hollow sound with no additional bottom weight and tall legs.
    do you have any plans to record a typing test with the prototype(s)?
    Offline Meowifier
    « Reply #26 on: Sun, 16 August 2020, 06:56:16 »
    Been commenting on your instagram posts like how I desperately want to pair this with some KAT Refined keycaps. :thumb: Made an account here just to show my support, as the design just absolutely hooked me and has got me willing to throw money at that keeb asap!
    GIVE ╰(*´︶`*)╯ KEEBS
    Offline NotFai
    « Reply #27 on: Sun, 16 August 2020, 07:27:26 »
    Wow this design looks absolutely amazing. Would you consider vendors to be part of this so that you can produce more than 50 units of this beautiful board? If yes, please don't forget us EU folks  :thumb:
    Offline mgsickler
    « Reply #28 on: Sun, 16 August 2020, 07:29:47 »
    Definitely will try and join.
    Offline ZavaZ86
    « Reply #29 on: Sun, 16 August 2020, 08:10:31 »
    Any chance of a brass option instead of the stainless steel? Also ISO support would be nice, i know it's been suggested  ;)
    Offline Poesjuh
    « Reply #30 on: Sun, 16 August 2020, 10:33:43 »
    Cool design! Are you considering to use different colored bars? Or just black
    Offline Shutter_Shock
    « Reply #31 on: Sun, 16 August 2020, 13:38:20 »
    I am extremely intrigued. Your design is refreshingly novel, and I love it. Black PVD on black anodized alu would be killer. I'll try to join if I can swing whatever the price ends up being. gl with gb either way. I'm very interested to see how the board sounds with this design.
    Offline Romutulus
    « Reply #32 on: Sun, 16 August 2020, 14:19:33 »
    I do like the design, however I do have concerns with the support system. All it takes is some unevenness on the legs or the surface and you could be typing on a wobbly keyboard. Additionally, I feels like I could scratch the legs if I don't use a deskmat, and if I do use deskmats it might introduce wobble because deskmats are squishy to a certain extent. Honestly I don't know how much these factors will come in play in reality, but I do think those are things to look out for.
    Offline dks
    « Reply #33 on: Sun, 16 August 2020, 16:04:08 »
    Thank you as always for your help and support.
    Offline dks
    « Reply #34 on: Sun, 16 August 2020, 16:06:33 »
    Thank you all for the comments!
    Offline dks
    « Reply #35 on: Sun, 16 August 2020, 16:14:16 »
    Bl4ck is correct, there will be die cut rubber bumpers to pad the legs to give it some grip and reduce vibration. In terms of the support system, the design actually utilizes 6 points of support instead of just the 4 legs (2 rear, 2 on the side, and 2 longer surfaces at the front). There was no wobble prior to installing the rubber pads, and after installing them I am quite confident that it would not be an issue.
    Offline dks
    « Reply #36 on: Sun, 16 August 2020, 16:15:33 »
    I definitely remember your comment! Thank you very much for your support.
    Offline dks
    « Reply #37 on: Sun, 16 August 2020, 16:25:42 »
    The accent pieces, "bars," are mirror polished stainless steel. Black PVD on black ano would be beautiful and is something I had in mind for a while. However, similar to Zava's comment on having a brass option for the accent, I am aiming to keep the options limited to reduce complexity. From a design standpoint as well, the original intent was and still is "stainless steel on black" to reproduce the contrast you see with a white on black setup: the black recedes to the background and emphasizes the accents.
    Offline KaosJ
    « Reply #38 on: Sun, 16 August 2020, 16:26:41 »
    Interesting for sure, are we sure that the keeb isn't going to wobble with these tiny feets  :eek:
    edit: for the same reason i'm concerned about sound, maybe a sound test would be cool when you can
    « Last Edit: Sun, 16 August 2020, 16:34:37 by KaosJ »
    Offline xondat
    • i'm not a star
    « Reply #39 on: Sun, 16 August 2020, 16:31:08 »
    For what it's worth, there's already an established maker using the name Lin. Maybe best to avoid confusion and change early on whilst you can? I don't personally care but just wanted to point out in case you didn't know.
    GLWIC - a unique board for sure :thumb:
    Offline dks
    « Reply #40 on: Sun, 16 August 2020, 16:42:43 »
    Thank you both for the reminder, I am aware of that! A name change is possible but unlikely. Lin is, literally, the name I was born with, and its great if it's another designer's name too, I like this name. However, we do have very different approaches to design and I hope the designs are enough to differentiate us.
    Offline Janoma
    • certified nerd
    « Reply #41 on: Sun, 16 August 2020, 18:38:46 »
    Loving these unique 75% designs lately. GLWIC
    Offline SojournShadows
    « Reply #42 on: Mon, 17 August 2020, 02:18:18 »
    I am certainly interested! This is very unique and I am a real fan of the design.
    Offline Lenux
    « Reply #43 on: Mon, 17 August 2020, 02:43:00 »
    Okay this is so aesthetic and design ! I love it !
    Count me in ! GLWIC :)
    Offline tiamo123654
    « Reply #44 on: Mon, 17 August 2020, 11:08:17 »
    That's rocks!
    waiting for the prototype. I am a little bit worried about the structure.
    Offline Zaum.Tech
    « Reply #45 on: Mon, 17 August 2020, 14:55:23 »
    Been following your progress on IG since currently I guess we are interested in everything 75% for obvious reasoins, your design stands out. Cant wait to see the prototypes
    Offline dks
    « Reply #46 on: Mon, 17 August 2020, 15:50:41 »
    That's rocks!
    The photos in the IC are of the actual R1 prototype—the shots with the wooden floor. What I meant was the album will be updated again once the pcb arrives, apologies if the wording was confusing, I’ve rephrased it.
    Offline Bl4ck
    « Reply #47 on: Mon, 17 August 2020, 16:07:12 »
    That's rocks!
    Thats cool! Can't wait to see a typing test! Didnt think it was the proto
    Edit: Could the corner be a rotary encoder?
    Offline hottrout
    • I'd Hit Dat Key
    « Reply #48 on: Wed, 19 August 2020, 04:04:27 »
    Interesting design, reminds me of trendy office furniture from the 1980's.  Would ISO be possible?
    Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
    Systems -
    Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
    Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
    Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
    Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
      Keyboards -
    IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
    Offline vilagefool
    « Reply #49 on: Wed, 19 August 2020, 07:07:50 »
    if IKEA designed a keyboard... (that I really like!)
