Author Topic: Tactile Switches  (Read 9563 times)
Offline Error213
Tactile Switches
« on: Sun, 16 August 2020, 12:53:24 »
Hello. I’m trying to find tactile switches in between 2.40$ - 7$ for 10. Please comment if you have any suggestions and I am willing to combine 2 switches
Offline Error213
Re: Tactile Switches
« Reply #1 on: Sun, 16 August 2020, 12:55:10 »
Also Mx compatible is best
Offline Leslieann
« Reply #2 on: Sun, 16 August 2020, 23:57:46 »
Those are rather specific prices...
While out of stock, novelkeys has a ton you can look through, often with springs rates and other info.
A lot of switches are difficult to get right now so your options also may be limited. Chinese sellers are saying early November for purchases at this point but I suspect reality will be closer to December.
Bang for the buck, if you have switch lube (Krytox/Finish line) and don't mind the hassle, Kailh Pro Purple are quite good, but they absolutely must be lubed. Once lubed I'd say they rival 62g Zealios V2 (without being lubed), maybe not exact but darn close. However, if you don't have lube then you need to include that in the cost, and while still a lot cheaper than Zeal there's a lot of other choices in between. Unfortunately like a lot of switches, they too are hard to get right now.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline femalesnest
    • super mario bros
« Reply #3 on: Mon, 17 August 2020, 02:36:34 »
Holy Chickies are pretty snappy. They like to snap back up too, so very responsive.
Offline lakeboredom
« Reply #4 on: Mon, 17 August 2020, 03:28:59 »
Lol this is literally my exact comment in another thread. You first comment here is a copy paste from someone else? I smell a bot.
« Last Edit: Mon, 17 August 2020, 03:30:31 by lakeboredom »
Offline femalesnest
    • super mario bros
« Reply #5 on: Mon, 17 August 2020, 07:45:35 »
same? Maybe they copy me haha! Just kidding, I'm a normal user, not a bot  ;D ;D
Offline CaesarAZealad
  • Racc
« Reply #6 on: Tue, 25 April 2023, 23:39:37 »
Tape two zealios together
One, Two, Three, Four, Five, Six, Seven, Eight, Nine, Ten, Eleven, Twelve, Thirteen, Fourteen, Fifteen, Sixteen, Seventeen, Eighteen, Nineteen, Twenty... Yeah that seems about right.
"Ask your mother how good I can use more than two fingers." - Caesar, 2023
Offline Sup
« Reply #7 on: Wed, 26 April 2023, 01:22:01 »
Gateron milky top with black bottom using MX clear stem with 58.5g springs lubed with 3204. Better then the Zealios i have tried.
current
Coming soon
Offline Rhienfo
  • GOTHETIGES
« Reply #8 on: Fri, 14 July 2023, 07:09:20 »
That's not suspicious at all...
