Author Topic: 65% DIY KB help  (Read 1788 times)
Offline rodgadala
65% DIY KB help
« on: Sun, 16 August 2020, 21:43:25 »
Hello,
Hope everyone is doing well!
I am interested in building my first keyboard and i have selected a few parts and I wanted to know if they where compatible. also if you guys know any other case
suggestion.
Case: https://kbdfans.com/products/kbdfans-tada68-aluminum-case?variant=2403415588877
Plate : https://kbdfans.com/products/65-cnc-aluminum-plate?variant=21806645608496
PCB : https://kbdfans.com/products/dz68rgb-hot-swap-rgb-pcb?variant=28530592415792
Switches :  https://novelkeys.xyz/products/novelkeys-cream-switches?variant=15400236777565
KeyCaps (Already Have) : Seamless Doubleshot Keycap Set - Joker (Ducky)
Stabs : Need recomendations
Thank you!
Offline Leslieann
Re: 65% DIY KB help
« Reply #1 on: Sun, 16 August 2020, 22:24:10 »
Yes, those all work together.
If you look at the DZ pcb description it specifically links to that case and plate.
Stabs: Durock, Zeal, Zug, Everglide.
Honestly though, I haven't seen any I couldn't make work decent (note I did not say great) with a little effort (lube!).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline rodgadala
Re: 65% DIY KB help
« Reply #2 on: Mon, 17 August 2020, 00:29:15 »
Thanks for the help! do you know where i can get other case options?
Offline Leslieann
Re: 65% DIY KB help
« Reply #3 on: Mon, 17 August 2020, 01:15:01 »
You're welcome.
That's pretty much it.
60% has lots of choices, but it's an oddity, almost all others have little to no options other than color.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
