Author Topic: [IC] SA Espresso - GB is live! Ending May 14th  (Read 96728 times)
Offline JPoc
« on: Wed, 19 August 2020, 10:59:00 »
SA Espresso
A keycap set inspired by the rich colors of an espresso, from the dark brown of coffee beans to the caramel-like layer of crema that rises to the top of a perfect shot.
April 13th - May 14th 2021
Vendors
US: Kono
EU: MyKeyboard
OC: DailyClack
Asia: zFrontier
CA: Ashkeebs
Pricing
Estimated lead time: 12 months after group buy
Kits
Renders
J-02 by Proto[Typist] Keyboards
Haus by Hand Engineering
Black Haus for the render.
GMMK PRO case. Model by Elmo, design by GPCGR.
Colors
Consider this image just a reference, as viewing the HEX on a screen is not accurate. I think these colors will work great, but I do have alternatives that are less/more saturated or a slightly different hue, in case the samples turn out a bit off and to make sure the subtle gradient is respected.
Deskmat
Collaborations
THOK x SA Espresso
RocketCables x SA Espresso
To-Do
  • Finish color matching
  • Collaborations
  • Get in contact with vendors
  • Make more renders
  • Modify the set / add more options based on feedback
  • Possible novelties and deskmats
Huge thanks to the Keycap Designers discord and r/keycapdesigners for all the great feedback. This is my first set, so all the help was crucial.
Special thanks to thatkoaladoe, shota_irl, NoPunIn10Did and Swishy, and also to konstantin for the very detailed advice on the kits.
Updates
  • 8/23/2020 - Moved the alphas out of base and ortho kits. Improved compatibility for many layouts, added NorDe and Ergo kits.
  • 9/16/2020 - Added novelties, deskmat and vendors. Updated kits to improve support and reduce unnecessary keys.
  • 3/11/2021 - Added GB date, pricing, collaborations and colors.
« Last Edit: Tue, 13 April 2021, 07:38:37 by JPoc »
Offline VXQN
Re: [IC] SA Espresso
« Reply #1 on: Wed, 19 August 2020, 11:16:14 »
Love the colours, I just wish it was DSA and not SA. GLWIC!
Offline Lizcuits
  • KAT PBJ
    • KAT PBJ
« Reply #2 on: Wed, 19 August 2020, 11:20:51 »
I like this a lot! I do have a few suggestions though:
  • Add a novelties kit (I'm sure you already are working on this)
  • Consider adding a few cream-colored keys as accents either into the base kit or novelties
  • Consider icon mods, they help it look less generic. Bonus points if you design them yourself!
  • Consider a custom font, not sure how easy this is for SA but if it's possible it'd give it a ton more personality
  • I would personally tone down the orange just a bit.  It feels too saturated to me.
  • I'd also prefer a profile other than SA, but you should do what you want!
For deskmats I'd love a simple "coffee liquid" plain design that looks like you're "underwater" in coffee. Think something like GMK Grape Soda's mats but with a bit more elegance to it... Just an idea!
« Last Edit: Wed, 19 August 2020, 11:23:15 by Lizcuits »
Offline TheMartes
« Reply #3 on: Wed, 19 August 2020, 11:34:50 »
I love this, I would also love DSA profile over the SA but it doesn't matter that much really.
Offline nasp
« Reply #4 on: Wed, 19 August 2020, 11:38:27 »
NB4 it's a gradient Chocolatier
Regardless, I do like seeing more SA sets
Offline mudcakehoney
« Reply #5 on: Wed, 19 August 2020, 11:59:13 »
I'm a big fan of this. SA Chocolatier is my all time favourite SA set and this compliments it nicely. I think since you've already added the 1.75u Shift to the base you should also add the R4 Fn key to make it compatible with 65% boards, otherwise theres almost no point having the short shift at all as you'd still be missing a key, adding one key to base will get alot more buyers than removing the short dhift and putting in the non standard imo.
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #6 on: Wed, 19 August 2020, 12:11:50 »
i LOOOOOOOOVE this. espresso is my go to and the subtle gradient is just so swell, such an awesome theme and really great execution. definitely following, and would love to pick up an ortho kit
Offline dom
  • allergic to hypocrisy
« Reply #7 on: Wed, 19 August 2020, 12:16:19 »
This is pure gold, LOVE IT 🙌 ♥️
Offline ddrfraser1
  • RIP Neil
« Reply #8 on: Wed, 19 August 2020, 12:20:00 »
One of the few gradient sets to look fairly good. You've certainly captured the essence of an espresso. Good job! :thumb:
Offline Dazon
« Reply #9 on: Wed, 19 August 2020, 12:42:01 »
in love with this, glwic!!
Offline frostykoala
  • consider Nightlight
    • Check out some Renders :)
« Reply #10 on: Wed, 19 August 2020, 12:45:09 »
Sign me up for a spot already
Offline lush_bunny
« Reply #11 on: Wed, 19 August 2020, 12:53:31 »
This is one of the more unique yet simple sets I've seen. Eyeing this closely.
Offline Bachoo
« Reply #12 on: Wed, 19 August 2020, 13:14:28 »
Not a fan of the how the profile looks, but this set really makes me wanna try it out  :thumb:
Offline Shiro
« Reply #13 on: Wed, 19 August 2020, 13:17:23 »
this is very lovely
Offline croatoanlp
« Reply #14 on: Wed, 19 August 2020, 13:30:42 »
So tasty....
Offline stevenopoly
« Reply #15 on: Wed, 19 August 2020, 13:49:51 »
so good. I wish it was Cherry profile  :(
Offline Hell-es
« Reply #16 on: Wed, 19 August 2020, 13:53:34 »
Looks nice , reminds me more of caramel ;)
Offline jdecker
« Reply #17 on: Wed, 19 August 2020, 13:56:47 »
reminds me more of a chocolate caramel bar but still looks tasty nonetheless
Offline JPoc
« Reply #18 on: Wed, 19 August 2020, 14:54:10 »
Lots of great feedback so far! Super excited about it.
This will be the next thing I fix, as a lot of people agree with you. Thanks for the input!
Offline hottrout
  • I'd Hit Dat Key
« Reply #19 on: Wed, 19 August 2020, 15:54:12 »
IN, simple as that.  Thank you for UK ISO and the great colour scheme.  I love my Chocolate sets and this is a nice take on it.  I would search out a board specifically for this set, in fact I think my white BEAR will love it.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline NotFai
« Reply #20 on: Wed, 19 August 2020, 16:08:22 »
Not the biggest fan of SA, but I definitely am a fan of what you have so far and am excited to see further developments. Good luck  :thumb:
Offline IOVERCALLHISTIOCYTES
« Reply #21 on: Wed, 19 August 2020, 17:56:08 »
I saw this first on my phone and liked it, and then just saw again on my most color accurate monitor and liked it even better. Hope to see this move along.
Offline Owl
« Reply #22 on: Wed, 19 August 2020, 18:17:05 »
Colors are absolutely fantastic. Unfortunately I am not on the SA train myself but this is still a banger.
Offline cijanzen
« Reply #23 on: Wed, 19 August 2020, 18:21:22 »
While I commented on the Reddit thread that this was similar to SA Chocolatier I am thinking more and more that this stands out enough with the gradient alphas. And generally, while I’m not a gradient fan, this is really well done.
My suggestion would be to split the alphas out of the ortho and tkl kits. This has the potential to allow for a higher alphas MOQ and therefore lower prices and more flexibility.
Offline maharuto
« Reply #24 on: Wed, 19 August 2020, 18:58:09 »
this might just be my first SA set!
Offline heliar_mk
« Reply #25 on: Thu, 20 August 2020, 20:18:13 »
Need some nov kit:D :D :D. Definitely in.
Offline Pyk_
« Reply #26 on: Thu, 20 August 2020, 22:46:34 »
Really pretty. Makes me sad my 40% can’t make full use of vertical gradients.
Offline fabijolo
  • I like expensive plastic.
« Reply #27 on: Thu, 20 August 2020, 23:55:25 »
Depending on how this develops, it can really see myself getting into this :thumb:
Offline stevenopoly
« Reply #28 on: Fri, 21 August 2020, 10:43:28 »
i keep coming back to look at this! The colors are just so smooth!!!   :thumb:
Offline MoonOperator
« Reply #29 on: Fri, 21 August 2020, 11:47:30 »
Yes. Just yes. I've been eyeing this forum for months now for an aesthetic SA keycap set and damn.. This is the one.
« Last Edit: Fri, 21 August 2020, 12:02:46 by MoonOperator »
Offline Emolokz
« Reply #30 on: Fri, 21 August 2020, 22:03:54 »
First time posting here, but this, this is amazing.  I am very interested!
Offline phinix
« Reply #31 on: Sat, 22 August 2020, 06:41:24 »
Woooooooooooow, what colors!  BEAUTIFUL!!!
and I thought nobody is gonna come up with nice SA set anymore...
I'm in.
Offline Bax
« Reply #32 on: Sat, 22 August 2020, 17:53:08 »
Lovely. Mornings would be so mellow with these.
Offline PseudoLlama
  • Ṗ̵̡̝̀̓e̸͉̲͛̔̓͝p̵̢̳̦̲̬̌͊̃̑͝e̷̯͔̾g̶̢̡̳̀̑̋a̶͕̺͆͌͒
« Reply #33 on: Sat, 22 August 2020, 23:51:03 »
God, that mix of those dark and rich browns with those almost golden keys is a heavenly combo, (I also love coffee, so this one strikes a chord with me)
Offline phinix
« Reply #34 on: Sun, 23 August 2020, 03:01:33 »
I hope SP will be able to reproduce those colors accurately.
Offline JPoc
Re: [IC] SA Espresso - Update 2 (23/8) - New kits
« Reply #35 on: Sun, 23 August 2020, 15:17:54 »
Hey everyone, huge thanks for all the support on the first days of the interest check!
I got lots of feedback, and after going through it I decided to take the advice of cijanzen, and split the alphas out of the base and ortho kit, looking at sets like SA Skyriter and SA Godspeed as reference. This should make the set more flexible and give you support for many layouts. I also improved Ortho and 40s support, and added NorDe and Ergo kits.
Also received lots of ideas for novelties and deskmats, will start to work on that.
Hopefully you will like these changes. Be sure to let me know in the new form if you're interested: https://forms.gle/UnisnB8cs5cxnAcx8
« Reply #36 on: Sun, 23 August 2020, 22:02:44 »
Neat idea with the ergo kit dark brown alphas
My TKL / split self is good with all this too.
Offline lush_bunny
« Reply #37 on: Mon, 24 August 2020, 15:37:28 »
I bet this would look nutty on black cases. But unless there are more renders to come, I'd never really know. 👀
Offline drfranco
« Reply #38 on: Mon, 24 August 2020, 19:35:58 »
I like this a lot and definitely will love to see the novelties. SA is not my favorite profile and that introduces a bit of decision for me. :thumb:
Offline Emolokz
« Reply #39 on: Tue, 25 August 2020, 11:38:26 »
Alas, if this goes through, maybe the colorway can be taken to other profiles as well?
Offline hottrout
  • I'd Hit Dat Key
« Reply #40 on: Tue, 25 August 2020, 14:08:10 »
Loving the updates, I am buying everything in this set.  Have you had any cool retro deskmat ideas.  The colours are pure 1970 retro baby.
Systems -
  Keyboards -
Offline Bubblegum
« Reply #41 on: Tue, 25 August 2020, 14:27:18 »
This looks great! Love the addition of a NorDe kit. Hoping that ISO Enter and 1.25u shift gets added to the NorDe kit, so NorDe users don't have to buy the UK kit also for 2 modifier Keys:)
Offline JPoc
« Reply #42 on: Tue, 25 August 2020, 14:41:30 »
Thanks! I will consider it
I would love to take this to other profiles in the future if people wanted it.
Very glad to hear that! Yeah I'm playing with a couple of ideas, one that might be kinda retro, but still lots of work to do.
« Last Edit: Tue, 25 August 2020, 14:44:40 by JPoc »
Offline lush_bunny
« Reply #43 on: Tue, 25 August 2020, 14:49:15 »
what is your rough ETA to a GB? 2021?
Offline mrvco
« Reply #44 on: Tue, 25 August 2020, 14:57:15 »
I like the colors quite a bit.  I agree that 'cream' accents could be a nice addition.  Not sure on SA Profile, I have a set coming to try it out.
Offline Bubblegum
« Reply #45 on: Tue, 25 August 2020, 15:01:32 »
Thanks, keep up the good work!
Offline JPoc
« Reply #46 on: Tue, 25 August 2020, 15:20:10 »
I want to spend a few months improving what I have and adding more stuff, so 2021 seems likely. Nothing certain tho.
Offline phinix
« Reply #47 on: Tue, 25 August 2020, 16:55:43 »
Would it be possible to split Specialty from TKL? Or they need to be together?
EDIT: naaah, maybe it should be there...
« Last Edit: Fri, 28 August 2020, 06:48:11 by phinix »
Offline lush_bunny
« Reply #48 on: Tue, 25 August 2020, 22:01:03 »
Good luck man. I've decided I wanted to throw money at this set when it's ready.
Offline sendrim
    • Instagram
« Reply #49 on: Fri, 28 August 2020, 06:42:19 »
Love it, take my money!
I like SA
