Author Topic: [IC] GMK JIS | Last Week | Live until December 14th  (Read 414001 times)
Offline Hyperdimension
Re: [IC] GMK JIS (Japanese Industrial Standards) WoB (Render Update)
« Reply #150 on: Sun, 14 November 2021, 17:52:38 »
does this set use standard gmk black and white colors? or are they custom ones?
Offline 2Moons
« Reply #151 on: Sun, 14 November 2021, 17:56:18 »
Just the standard. There are many new legends and a new spacebar mold.
Offline 2Moons
« Reply #152 on: Sun, 14 November 2021, 17:56:53 »
Can we have a price table? :)
I'm working on this now.
Offline inixity
Re: [IC] GMK JIS Live now 11/14 - 12-14
« Reply #153 on: Sun, 14 November 2021, 18:36:37 »
What's the Pantone for the white spacebars in this kit?
Offline 10peaches
« Reply #154 on: Sun, 14 November 2021, 18:39:26 »
[mention]2Moons [/mention] Love your work on this set and would like to build a keyboard in the JIS layout so the set will be use in full potential.
I know you dabbled in PCB design as well. Is it possible that you design TKL pcb (like the H88 or H87) to fit the JIS layout?
That would so cool!
Offline 2Moons
« Reply #155 on: Sun, 14 November 2021, 19:53:02 »
All pricing up on the IC
That would so cool!
Actually YES. There will probably be 2 JIS TKL pcbs and a 60 percent coming out during or soon after the GB. 4.5u stabilizers will be a thing coming soon as well.
Offline Arithmetics
« Reply #156 on: Sun, 14 November 2021, 22:47:14 »
That would so cool!
whoa this would be cool
Offline tmc_2269
« Reply #157 on: Mon, 15 November 2021, 22:53:00 »
Very cool set. I ordered a few kits. What do the rings with the three arrows mean? I haven't been able to find out from image search.
Offline 2Moons
« Reply #158 on: Mon, 15 November 2021, 23:13:53 »
Same as 無変換 Muhenkan and 変換 Henkan. You can usually find them on Filco and Realforce JIS keyboards. Filco and Realforce said they were an open source design so I included them.
Offline Wolff._.
  • Machinist
Re: [IC] GMK JIS | Week 2 | Live until December 14th
« Reply #159 on: Mon, 06 December 2021, 17:50:18 »
Someone asked this earlier, but it doesn't look like its been answered anywhere...
What white are the set gonna use. A new Patone white or a GMK preset like WS1 or WS2?
Offline konstantin
  • Formerly constexpr
« Reply #160 on: Mon, 06 December 2021, 18:25:32 »
It's WS1 on CR.
