Author Topic: [IC] Slice, QMK Cleared, GB Live Now  (Read 47871 times)
Offline 2Moons
« on: Fri, 31 January 2020, 09:49:57 »
Group Buy Thread:https://geekhack.org/index.php?topic=105390.0
Availability: https://www.basekeys.com/shop/
Interested in a slice? Contact: https://www.basekeys.com/contact
Meet Slice
60 Percent Split Keyboard by 2Moons
The Alice has been split.
Affordable and Beautiful
Designed to be elegant, yet cost effective. This is a true DIY keyboard but uses nearly all SMD components. Even the RGB version which includes dual OLED displays and is based on the Corne, uses mainly surface mount components. Initially in acrylic and stainless steel, the curves give it style, the build makes it a challenge, and the parts make it affordable for anyone. Though not ground breaking initially, upgrades have been made. The non-RGB version is simple and easy to build.
Specifications
Plate: 3mm Acrylic
PCB: Soldered (non-hotswap), powered by 2 Pro micro controllers.
Alpha Key Angle: 8 degrees
Key Count: 74 keys
Layouts supported:
Unit Quantity: 30 Units
Price: To be announced
Vendors: basekeys.com
Included Items:
PCB x2 (White or Blue)
3mm acrylic top plates x2
3mm acrylic bottom plates x2
Pro micro x2
M2 Spacer x20
M2 screws x40
Diode x75
TRRS Jack x2
Reset Switch x2
TRRS Cable x1 (white)
15% off Coupon to Zap cables for a custom TRRS Cable
Current Status:
QMK Completed.
Group Buy Date: 4/1/2020
Price: ¥13,000 Shipped
About the Designer:
I am a keyboard enthusiast living in Japan who also has a passion for split keyboards.
« Last Edit: Tue, 31 March 2020, 10:04:45 by 2Moons »
Offline 2Moons
Re: [IC] Alice Split 60
« Reply #1 on: Fri, 31 January 2020, 09:54:52 »
Slice RGB
Specifications
Plate: 3mm Acrylic
Key Count: 71 keys
Layouts supported:
Vendors: TBA or booth.pm/en
Included Items:
Pro micro x2
OLED x2
YS-SK6812MINI-E LED x71
M2 Spacer x20
M2 screws x40
Diode x71
0.1uF x37
510 Ohm x2
TRRS Jack x2
Reset Switch x2
Current Status:
QMK Completed.
Price: ¥20,000 Shipped
« Last Edit: Fri, 27 March 2020, 01:44:42 by 2Moons »
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #2 on: Fri, 31 January 2020, 09:55:35 »
I really like this idea, but I think you should consider changing the name. It's not even like a pun on Alice, it's literally just Alice.
Offline 2Moons
« Reply #3 on: Fri, 31 January 2020, 10:04:25 »
I honestly didn't know what to call it initially so I used my wife's name instead. I'm totally open to names. I thought of Alice as a type of keyboard and not a specific keyboard in and of itself so I figured I would just call it that.
Offline heyjaykay
« Reply #4 on: Fri, 31 January 2020, 10:04:45 »
How about... Slice
Offline 2Moons
« Reply #5 on: Fri, 31 January 2020, 10:08:07 »
How about... Slice
That's actually a cool name.
Offline wixxzblu
« Reply #6 on: Fri, 31 January 2020, 10:10:33 »
I agree that Slice is a good name
Offline ThePanduuh
  • Discord @thepanduuh
« Reply #7 on: Fri, 31 January 2020, 10:27:12 »
I like slice.
can possibly mix in 'the best thing since sliced bread.'
I have some keyboards, mostly resin.
I like CAD. Making things is fun. [W] Projects
Offline KingOfMemes
« Reply #8 on: Fri, 31 January 2020, 10:31:19 »
Are you considering adding a right side 'B'?
Offline 2Moons
« Reply #9 on: Fri, 31 January 2020, 10:33:03 »
Right side B has been added to both the regular and RGB/OLED version of the designs. Rev1 will include the right side B.
Offline AegisAndAtrophy
Re: [IC] Slice, an Alice Split 60
« Reply #10 on: Fri, 31 January 2020, 10:49:23 »
My morning showerthought today was that the next iteration on the Alice design should be a split, and here we are. Interested in seeing how this progresses.
Offline 2Moons
« Reply #11 on: Fri, 31 January 2020, 11:20:31 »
I like slice.
This will be etched into the back of the right side board now. Also looking for more quotes. :)
Offline catamscott
« Reply #12 on: Fri, 31 January 2020, 14:18:19 »
very interested, have really been wanting to build another split keyboard and this looks really slick.
Offline Tymm0
    • Teal Technik
« Reply #13 on: Fri, 31 January 2020, 16:12:07 »
Slice is the perfect name for this. Id like to see what case options there are for this it is a great idea!
« Last Edit: Fri, 31 January 2020, 16:13:42 by Tymm0 »
tealtechnik.com
Offline helborne
« Reply #14 on: Fri, 31 January 2020, 16:57:03 »
Yeah dude, in! I like the rename
Offline abbabon
  • I’ve got 99 Zilents and a THOCK ain’t one
    • I make “video games” with all these keyboards
« Reply #15 on: Sat, 08 February 2020, 14:03:04 »
I'm in.
Offline kindakeyboards
  • hi! im Milo and i make keyboards.
    • kinda.be
« Reply #16 on: Sun, 09 February 2020, 08:51:32 »
damn
Offline nicole_loke_richards
« Reply #17 on: Mon, 10 February 2020, 04:44:55 »
Yes, I like this! I want to build a split keyboard that in this kind of staggered layout so this is perfect!
Offline 2Moons
« Reply #18 on: Mon, 10 February 2020, 05:39:21 »
Update:
Thank you so much everyone. Google form has been added. New pics of black acrylic but let me know what colors you would like to see. Layout picture has also been adjusted. Questions about layout in the google form.
Offline nathanchere
« Reply #19 on: Mon, 10 February 2020, 09:39:03 »
Update:
Damn... with split right-shift and split backspace this would be insta-buy worthy.
Offline 2Moons
« Reply #20 on: Mon, 10 February 2020, 18:48:46 »
Update:
Looks like everyone wants it as well. Layout has been updated. As far as colors and thickness go, looks like blue pcb and 3mm clear acrylic. That's going to look spectacular.
« Reply #21 on: Mon, 10 February 2020, 19:27:53 »
Will you include a trss cable in the kit as well?
Offline 2Moons
« Reply #22 on: Mon, 10 February 2020, 19:51:05 »
That's a really good question.
There are two options here I could do if you want an included TRRS. I can include a very cheap and short TRRS. I could possibly have an option where you specify color and design of your TRRS and ask Nillpo on twitter if he wants to custom build them. That will add about $30 onto the price. They will include the gold ends shown, inside color, outside color, and a heatshrink color. Let me ask Nillpo about it.
« Reply #23 on: Mon, 10 February 2020, 20:07:13 »
Yes, nice custom trss cable as an optional purchase with the kit sounds good. I’ll be copping for that!
Offline harlekein
« Reply #24 on: Tue, 11 February 2020, 09:26:40 »
nvm
« Reply #25 on: Tue, 25 February 2020, 14:19:06 »
Is the non-rgb one has no oled screens? It’s not listed in the spec list...
Offline nathanchere
« Reply #26 on: Wed, 26 February 2020, 02:40:37 »
Offline 2Moons
« Reply #27 on: Wed, 26 February 2020, 04:26:27 »
The non-rgb version has no OLED. However, both will now have an acrylic cover over the pro micro areas. The rev1 pcbs have been ordered and their on the way. I'll set the group buy date after a final version has been assembled. Let's do this!
« Reply #28 on: Wed, 26 February 2020, 14:38:32 »
I’m excited for this... can you also publish instructions on how to put it together and flash it. This is not my first through hole soldering keyboard project but I don’t feel comfortable doing it if I don’t have instructions.
Offline luvSIK
« Reply #29 on: Thu, 27 February 2020, 07:47:42 »
count me in
Offline ninetynein
« Reply #30 on: Thu, 12 March 2020, 13:37:09 »
I created an account here just to try to get my hands on one of these....
Offline _rubik
« Reply #31 on: Thu, 12 March 2020, 14:58:08 »
Fun idea! I'm interested
Offline 2Moons
Re: [IC] Slice, an Alice Split 60 QMK Cleared
« Reply #32 on: Fri, 27 March 2020, 02:22:06 »
QMK has cleared. Website has finished. Build guide for both versions has been added. Thanks for waiting.
Other thoughts:
QMK keymap will be needed for configurator.
QMK split left space will need to be updated.
Notes:
Default is MASTER_LEFT but EE_HANDS will allow both usbs to function. To use EE_HANDS you'll need to use the QMK command line.
Questions: Should I remove the "Slice" cursive on the front of both sides?
Website will open for pre-orders 4/1/2020.
« Last Edit: Fri, 27 March 2020, 02:37:36 by 2Moons »
Offline jjoejimmy
Re: [IC] Slice, QMK Cleared, Pre-order:4/1/2020
« Reply #33 on: Fri, 27 March 2020, 10:16:15 »
This is probably too late to make a request but I just saw this thread and had a question. Is there a reason why you did not have the TRRS Jack's facing upwards? With them on the side, the board cannot be put together. Excited for the preorder!
« Reply #34 on: Fri, 27 March 2020, 10:32:19 »
Want to get my hands on it, but somewhat scared of soldering diodes. How difficult is it for someone who never done it?
Offline KingOfMemes
« Reply #35 on: Fri, 27 March 2020, 10:50:23 »
This one seems like its going to be a little more difficult than usual since there are no through-holes for the diodes. There are just flat solder pads. Truth be told, this is preferred imho because it looks way cleaner, but it's still going to be a bit more difficult
« Last Edit: Fri, 27 March 2020, 11:11:23 by KingOfMemes »
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #36 on: Mon, 30 March 2020, 11:30:03 »
Depends on how comfortable with your hands, honestly I don't think I'm all that great at soldering but this was pretty easy for me.
Flux makes things a lot easier but as long as you have tweezers and a chisel tip you should be fine.
GON NerD TKL DTA Edition
Offline 10peaches
« Reply #37 on: Mon, 30 March 2020, 16:41:31 »
I hope someone will eventually make a high pro case for this... like the Discipline 65. It will be so cool!
I don’t normally like low pro board but this project is so interesting so I will cop for it.
Offline 2Moons
Re: [IC] Slice, QMK Cleared, GB Live Now
« Reply #38 on: Tue, 31 March 2020, 10:06:09 »
