Author Topic: [GB] Fox Lab - Time 80 Reforged  (Read 351587 times)
Offline noideawhatsgoing
Re: [GB] Fox Lab - Time 80 Reforged
« Reply #150 on: Thu, 03 September 2020, 16:13:29 »
Yep, I went down the rabbit hole of the China GB and it does look like hotswap is 7u only. So it is just like the Key65 in that respect. Hopefully that also means we can solder underglow! Hype. Now to forget about this until February 2021.
Offline Brixzz
« Reply #151 on: Thu, 03 September 2020, 17:45:39 »
Do you know wether the plate supports 6,25u? I got a solder pcb so that shouldn't be the problem.
Offline 3yatt
« Reply #152 on: Thu, 03 September 2020, 18:19:09 »
So the solder pcb and plate supports 6.25?
Offline Curin Derwin
« Reply #153 on: Thu, 03 September 2020, 18:48:48 »
A design so nice I bought it twice. Plus like 6 plates because I need to try them all to see what matches best.
Offline alleneentrekin
    • j
« Reply #154 on: Thu, 03 September 2020, 19:34:25 »
I can't believe I missed this. I had like two whole days. Welp guess I'll have to find something else
Sent from my Pixel 4 XL using Tapatalk
Offline senter
« Reply #155 on: Thu, 03 September 2020, 19:47:10 »
The hot swappable PCB supports only WKL layout with 7u spacebar.
The solder PCB supports WK/WKL, split BS, split left/right shift, ISO, ALPS.
This is the setup I use on almost all 80% keyboard designs, and I believe it's the best and the most correct settings.
The plate supports both WK and WKL. It doesn't support ISO and ALPS tho.
I also believe it's the best setting in general for a GB.
(Edit: The hot swappable PCB doesn't support 6.25u spacebar. It supports [1.5u 1u 1.5u 7u 1.5u 1u 1.5u] bottom row, which means it does support 1u Win keys.)
« Last Edit: Sat, 12 September 2020, 13:46:48 by senter »
Offline akibaki
« Reply #156 on: Thu, 03 September 2020, 20:19:37 »
super awesome design, bought one and extra PCB set with a split plate. thanks
Offline tngpq
« Reply #157 on: Thu, 03 September 2020, 21:12:01 »
I also belive it's the best setting in general for a GB.
I ordered a regular kit with hotswap pcb. Then will I have empty space not covered by blockers? If so, hotswap shouldn't have been an option for regular..
Offline senter
« Reply #158 on: Thu, 03 September 2020, 21:15:16 »
To make it clear, when I say WKL layout, it includes the layout with 1u Win keys.
Not sure how I should call it. I guess Tsangan is also not correct.
Offline tngpq
« Reply #159 on: Thu, 03 September 2020, 21:37:28 »
Oh got it. I guess it's an ANSI with only bottom row as Tsangan?
Offline Phantom_Nyan
« Reply #160 on: Thu, 03 September 2020, 21:59:59 »
So anyone wonders how many kits were overall purchased? since the keeb was open for 24 hrs it might be over 1000, wonder if they will manage to have the 5 months delivery window with good qc and this amount of orders
Offline senter
« Reply #161 on: Thu, 03 September 2020, 22:32:43 »
Not that many. I haven't counted yet I think there are around 500 orders after excluding the canceled ones. Some people ordered more than 1 kits so the number of kits is more than 500.
I always post the GB numbers on my website like this: https://fox-lab.github.io/gbs/Key-65.html
Sorry for the ugly formatting but I hope everyone GB participant can know how unique his/her board is and how many same kits are out there.
Edit: I'll post the number for Time 80 RE when I'm available, not anytime soon.
Offline outerspace
« Reply #162 on: Thu, 03 September 2020, 22:39:11 »
I think the bottom row will be 1.25U 1U 7U 1.25U 1U 1.25U, like RAMA Works' U80-A.
Offline Lufenia
« Reply #163 on: Thu, 03 September 2020, 22:41:55 »
@senter
Do you have any other pictures showing what your anodized pink looks like for the time pieces?
Offline 24kpurehandsome
« Reply #164 on: Thu, 03 September 2020, 22:59:14 »
Will there be a discord chat for this GB?
It would be nice to check updates and discuss about the board.
Offline tngpq
« Reply #165 on: Fri, 04 September 2020, 01:09:26 »
U80-A has a 1.5U 1U 1.5U 7U 1.5U 1U 1.5U Tsangan bottom row. This should be it.
Offline outerspace
« Reply #166 on: Fri, 04 September 2020, 10:23:15 »
You are right ... silly me, I have a U80-A right in front of me ;-)
Offline lazergician
« Reply #167 on: Fri, 04 September 2020, 11:07:12 »
There plate files for this somewhere? No worries if not, just eager to plan it out!
Offline Vigrith
« Reply #168 on: Fri, 04 September 2020, 11:42:02 »
The original Time is one of the best and most well designed boards I own. That is all.
PS: buying white.
« Reply #169 on: Fri, 04 September 2020, 23:26:51 »
Yes I am interested in making an ALPS brass plate.
Also: As the brass plates for the GB coated?
Offline isaackang7
« Reply #171 on: Sat, 05 September 2020, 08:02:43 »
I still have not received a reply from the email that I sent 2-3days ago. Please reply thanks
Offline cicatriz
« Reply #172 on: Sat, 05 September 2020, 10:42:11 »
How did people get over the paypal issues on the site? Paypal wasn't letting me process the payment and haven't had an email reply in several days.
Offline Seydoux
« Reply #173 on: Sat, 05 September 2020, 11:05:21 »
Hi, i i dont have any confirmation of the order. payment has been done. just to double check on this.
Offline wybaugh
« Reply #174 on: Sat, 05 September 2020, 13:14:47 »
@senter what email is best to ask a question about my order?
Thank you!  Email received.
« Last Edit: Sat, 05 September 2020, 14:51:47 by wybaugh »
Offline senter
« Reply #175 on: Sat, 05 September 2020, 15:07:34 »
I have processed your request and sent you a confirmation email two days. Please pay your balance asap otherwise your order will be canceled.
Offline senter
« Reply #176 on: Sat, 05 September 2020, 15:08:41 »
The option was called Brass - E-Clear so yes it's coated.
Offline senter
« Reply #177 on: Sat, 05 September 2020, 15:09:58 »
Please check your spam folder. The confirmation emails were sent to everyone automatically.
Offline Minam
« Reply #178 on: Sat, 05 September 2020, 15:31:53 »
Thanks for the awesome work Senter!
« Last Edit: Sat, 05 September 2020, 18:04:03 by Minam »
Offline isaackang7
« Reply #179 on: Sun, 06 September 2020, 03:50:13 »
I checked through all my spam folders and I could not find it. Please send to isaack7@naver.com (or isaackang7@hotmail.com) again. Thanks
« Last Edit: Sun, 06 September 2020, 03:55:46 by isaackang7 »
Offline isaackang7
« Reply #180 on: Sun, 06 September 2020, 04:00:52 »
To make it clear this is WKL?
« Reply #181 on: Sun, 06 September 2020, 08:26:20 »
I was a bit confused by that as well, but I assumed senter was talking about the PCBs in the part that you quoted.
WKL on a case has always meant what you pictured.
Offline antcrm
« Reply #182 on: Sun, 06 September 2020, 09:35:34 »
excellent product
Offline Despuhration
« Reply #183 on: Sun, 06 September 2020, 18:46:47 »
Anyone know what the pantone codes for the boards are? I got a blue one and am trying to get some keycaps lined up probably going to go with Shoko though.
Offline antcrm
« Reply #184 on: Mon, 07 September 2020, 02:22:16 »
very good
Offline Brixzz
« Reply #185 on: Mon, 07 September 2020, 02:26:50 »
Don't know the pantone codes, but shoko will look great on the blue board if it's anything close to the renders!
Offline shansoft
« Reply #186 on: Tue, 08 September 2020, 00:24:05 »
The blue color does not look like render, it looks like a real photo....  :eek:
« Reply #187 on: Tue, 08 September 2020, 00:58:51 »
That's a photo series, as Senter describes it, not a series of renders. Also you can see the little fingy sneaking in, in one photo. But yea, that blue/shoko photo almost made me change my decision from black to blue. Kat Comet coming up also seems like it would potentially be a nice match, always hard to say ahead of time though.
Offline isaackang7
« Reply #188 on: Tue, 08 September 2020, 23:34:11 »
Still nothing
Offline Olaipai
« Reply #189 on: Fri, 11 September 2020, 16:32:38 »
Oh man! I just learned about this case after I found Minterly on YouTube. Will there be extras??? Please say there will be extras! Fell in love with this board.
GLWGB
« Reply #190 on: Sat, 12 September 2020, 10:12:53 »
Just confirming,
The hotswapp PCB only support 7U spacebar right?
I think I purchase the wrong stablizers.
Offline senter
« Reply #191 on: Sat, 12 September 2020, 13:45:27 »
Just confirming,
Yes
Offline Clyde1
« Reply #192 on: Sat, 12 September 2020, 14:55:41 »
Oh no, I just missed the GB. FEELS BAD
Offline SekaiJutsu
    • GeekHack
« Reply #193 on: Sun, 13 September 2020, 02:24:44 »
Is there a discord server for this board?
Offline //gainsborough
  • MATRIXの日常
« Reply #194 on: Sun, 13 September 2020, 15:46:29 »
negatory on the discord
« Reply #195 on: Tue, 15 September 2020, 07:56:51 »
Just caught up on reading the IC thread and saw this post on the new powder coating process: https://geekhack.org/index.php?topic=107276.msg2931493#msg2931493 (also finally had time to watch minterly's video and wow e-white looks amazing)
Is there going to be anything different with how e-white is done?
Offline Surefoot
« Reply #196 on: Tue, 15 September 2020, 09:12:49 »
E-white is not powder coating - the process is electro-chemical not unlike anodization actually. I think the powder coat is only for certain colors on this GB.
« Reply #197 on: Tue, 15 September 2020, 12:15:28 »
Yeah I understand that e-white isn't being powder coated, I was wondering that since the powder coat is being done differently if there was also something different with the electroplating this time.
I ordered e-white and another color that is powder coated so I was really just curious.
Offline Teriyako
« Reply #198 on: Wed, 30 September 2020, 17:35:56 »
Will there ever be another group buy of this or a round 2
Offline DukeEsquire
« Reply #199 on: Thu, 01 October 2020, 00:49:26 »
There is no point in asking when this round hasn't even come close to delivering yet.
